Can't get Netfit Easy to run
Posted: Friday 13 June 2025 11:23
by hjzwiers
I can't get nefit easy to run, installed through dockge
services:
nefiteasy-http-server:
ports:
- 3000:3000
container_name: myNefitEasy
environment:
- NEFIT_SERIAL_NUMBER=XXXXXX
- NEFIT_ACCESS_KEY=XXXXXXXXX
- NEFIT_PASSWORD=XXXXXX
image: trafex/nefiteasy-http-server
networks: {}
It says in Domotics: Error: Nefit_Easy: Error getting http data! I don't know what to do anymore
Edit Waltervl: removed credentials
Re: Can't get Netfit Easy to run
Posted: Friday 13 June 2025 11:29
by eddieb
edit you access-key ...
Posted: Friday 13 June 2025 11:39
by hjzwiers
I don't understand, how must I edit the access-key?
Posted: Friday 13 June 2025 11:40
Does it run in Docker? What does the log of the docker say?
Did you stop the normal nefit-easy server on your system?
And stop posting credentials like ID and password/PIN codes on the internet!!!!!
Posted: Friday 13 June 2025 11:48
by hjzwiers
Sorry about the credentials ....
dockge says:
[email protected] start
myNefitEasy | > easy-server --host=0.0.0.0
myNefitEasy |
myNefitEasy | HTTP server listening on
http://0.0.0.0:3000
no other comments, I do wonder why its not sending on
http://127.0.0.1:3000? Can you put that in the docker file?
Posted: Friday 13 June 2025 12:03
That probably depends how the docker image has been created.....
Does it even work properly?
In the NefitEasy wiki page
https://wiki.domoticz.com/NefitEasy there is a troubleshooting part.
curl http://127.0.0.1:3000/api/status
It should give a valid JSON result.
You can also try
curl http://0.0.0.0:3000/api/status
or
curl http://<Domoticz Server IP>:3000/api/status
If one of these works then you have to change the settings accordingly in Domoticz.
If you run Domoticz also in a Docker you probably have to change the settings anyway as 127.0.0.1 is the localhost IP in the container and not of the Domoticz server.
Posted: Friday 13 June 2025 13:48
by hjzwiers
I know I have to change the settings .... but which
curl
http://127.0.0.1:3000/api/status:
{"user mode":"manual","clock program":"auto","in house status":"ok","in house temp":27,"hot water active":true,"boiler indicator":"off","control":"weather","temp override duration":0,"current switchpoint":32,"ps active":true,"powersave mode":true,"fp active":false,"fireplace mode":false,"temp override":false,"holiday mode":false,"boiler block":null,"boiler lock":null,"boiler maintenance":null,"temp setpoint":15,"temp override temp setpoint":17,"temp manual setpoint":10,"hed enabled":null,"hed device at home":null,"outdoor temp":30.3,"outdoor source type":"physical"}hjz@debian:/opt/stacks/domoticz/config/plugins/iDetect$
seems all fine
I checked internet and they all show the same settings in the docker file, which one to change?
Posted: Friday 13 June 2025 14:32
You are running Domoticz also in a docker?
Find the real IP of your Domoticz server by open up a terminal window and execute the command:
Then you have to change in Domoticz menu Setup - Hardware - NefitEasy hardware gateway
http://127.0.0.1:3000 into http://<Domoticz Server IP>:3000
Posted: Friday 13 June 2025 14:53
by hjzwiers
That was very simple ... but most things are if you know where to look.
Working!
Posted: Friday 13 June 2025 15:03
hjzwiers wrote: Friday 13 June 2025 14:53
Working!
It is more that you have to understand what is happening when you use docker.....
