Moes ZM-105B-M dimmer don't switch on
Eugene
Post by Eugene »
Hi Guys,
I found out recently that i can't turn on the Moes ZM-105B-M dimmer anymore using Domoticz dimmer switch. I can switch it off, i can change level when but can't turn it on. I can also turn it on if i change the switch type in domoticz from "dimmer" to "on/off" but then i lose dim function which is weird.
As a workaround i created a dummy switch in domoticz which sends MQTT message to zigbee2mqtt/0xb0c7defffe1604c2/set {"state_l1": "ON"} but i would like to get my original domoticz dimmer type switch working fully if possible.
Any idea what is going wrong in my setup?
gizmocuz
Re: Moes ZM-105B-M dimmer don't switch on
Post by gizmocuz »
Maybe you should tell us what versions of Domoticz and Zigbee2MQTT you are running?
I have to assume you updated them both to the latest version?
If not, 99% sure that solves your issue
When you do, check if you have received new devices as well
Eugene
Post by Eugene »
Thanks, good point. Domoticz 2025.1 and Zigbee2MQTT 2.4.0.
I dont see any new devices, all the devices discovered are below. I made device re-discover/re-join recently while i was trying to resolve the issue
I don't use the dimmer often, but i suspect the issue started post Zigbee2MQTT upgrade.
