Axis break in graphs
Posted: Friday 30 May 2025 14:45
by mvdp
After the last update to the latest version (went smooth, thanks a lot!) I noticed that graphs are not having an axis break, ie. they all show a full y-axis scale starting at 0 to the values measured. I remember vaguely that this was not the case before.
See below for an examples without and with axis break.
As you can see the axis break allows to clearly see what is going on. But that might be a personal opinion, so would it be hard to show graphs with axis break as an optional (global) configuration item?
No axis break example:
Same data with axis break:
Re: Axis break in graphs
Posted: Friday 30 May 2025 19:53
I think this change has caused this https://github.com/domoticz/domoticz/co ... 83bd293822
You can play with the file www/app/log/RefreshingChart.js to change the behavior as you do not have to build anything.
Posted: Saturday 31 May 2025 10:02
by mvdp
Thanks! Reverting line 85 in www/app/log/RefreshingChart.js returns the broken axis view again.
The change (git sha f0cff38a70) was added recently on May 25th by GizMoCuz with message: 'Default area graph type for most day charts'.
Not sure which problem this fixes?
It is using boolean flag `isShortLogChart` for CounterLogChart that has been in since 2020.
Posted: Tuesday 03 June 2025 14:24
by gizmocuz
Are you the same person who created a Github issue?
Maybe an idea to mention this forum thread there?
The idea was to make a area spline as it looks better, but it should NOT start at zero indeed.
Could you make a PR to fix this? (keeping the area spline type!)
Posted: Tuesday 03 June 2025 14:34
by gizmocuz
I think I found the solution ...
threshold: null
Fixed in beta 16718
Posted: Wednesday 04 June 2025 9:02
by mvdp
gizmocuz wrote: Tuesday 03 June 2025 14:24 Are you the same person who created a Github issue?
No, I did not create the issue.
Posted: Wednesday 04 June 2025 13:26
by gizmocuz
Ahh then this was found by multiple users.
Anyway, solved in the latest beta!
Posted: Thursday 05 June 2025 8:21
by mvdp
Cool! Thanks for the swift fix!
