Can't automate selector based on temp
MasMat
Domoticz version: 2025.1
Post by MasMat »
I have searched the net but I cant find why my script isnt working. And yes, I even asked AI to help! I'll provide more info if necessary.
The idea is to check every 20min two temps and control the A/C accordingly during the day (annoying beeps - IR blaster sending). So for all non-Finns, olohuone is living room, alakerta is downstairs :D
    active = true,
        timer = { 'Every 20 minutes at 11:00-22:30' }
    execute = function(dz, item)
        local OlohuTemp = dz.devices('OlohuoneKulma')
        local AlakTemp = dz.devices('Alakerta')
        local viilee = dz.devices('Viilennys')
        -- Log current temperatures for debugging
        dz.log('OlohuoneKulma: ' .. OlohuTemp.temperature .. '°C, Alakerta: ' .. AlakTemp.temperature .. '°C', dz.LOG_INFO)
        -- Cooling control with hysteresis
        if OlohuTemp.temperature > 25 and AlakTemp.temperature > 24.5 then
            if viilee.state ~= '10' then -- Only switch if not already on
                viilee.switchSelector(10)
                dz.log('Olohuone > 25°C and Alakerta > 24.5°C, starting cooling', dz.LOG_INFO)
                dz.log('Cooling already on', dz.LOG_DEBUG)
        elseif OlohuTemp.temperature < 24 or AlakTemp.temperature < 23.8 then -- Hysteresis: lower threshold
            if viilee.state ~= '0' then -- Only switch if not already off
                viilee.switchSelector(0)
                dz.log('Olohuone < 24°C or Alakerta < 23.8°C, stopping cooling', dz.LOG_INFO)
                dz.log('Cooling already off', dz.LOG_DEBUG)
            dz.log('No change in cooling status', dz.LOG_DEBUG)
One log entry:
2025-05-29 17:20:00.564 dzVents: ------ Start internal script: AutomViilee:, trigger: "Every 20 minutes at 11:00-22:30"
2025-05-29 17:20:00.579 dzVents: OlohuoneKulma: 29°C, Alakerta: 25.200000762939°C
2025-05-29 17:20:00.579 dzVents: ------ Finished AutomViilee
..and doesn't activate as can be read there.
The switch is a virtual one. Three positions: off-low-high, "selector levels: 0, 10, 20" - each sends/activates a bash script that makes the IR send certain codes. The switch works perfectly. Only this automation is not working.
I'm happy for any help here!
RonkA
Re: Can't automate selector based on temp
Post by RonkA »
In stead of:
Try:
        local OlohuTemp = dz.devices('OlohuoneKulma').temperature
        local AlakTemp = dz.devices('Alakerta').temperature
	local viilee = dz.devices('Viilennys').level
        dz.log('OlohuoneKulma: ' .. OlohuTemp .. '°C, Alakerta: ' .. AlakTemp .. '°C', dz.LOG_INFO)
Now try to use de values OlohuTemp and AlakTemp to make calculations and see if villee is working..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
MasMat
Post by MasMat »
Doesn't it "double up" later? Or should I remove the latter .temperature?
Also, I forgot to mention, it beeps every 20min so apparently this:
doesn't read correctly.
RonkA
Post by RonkA »
Yes, You get the values before you use the If-statement.
Not sure how to work with the selectorswitch but read in the dzVents wiki you can use .level..
MasMat
Post by MasMat »
Finally have it working after retries and a long break.
Hope this finds someone wrestling with the same problem.
The switch selectors are labeled Off, Low and High and correspond to 0, 10, 20 for levels.
    active = true,
        dz.log('OlohuoneKulma: ' .. OlohuTemp.temperature .. '°C, Alakerta: ' .. AlakTemp.temperature .. '°C, Fan status: ' .. viilee.state, dz.LOG_DEBUG)
        if OlohuTemp.temperature > 25.0 and AlakTemp.temperature > 24.5 then
            if viilee.state ~= 'Low' then -- Only switch if not already on
        elseif OlohuTemp.temperature < 24.0 or AlakTemp.temperature < 23.8 then -- Hysteresis: lower threshold
            if viilee.state ~= 'Off' then -- Only switch if not already off
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
for the reading it looks nicer if the numbers a rounded to 2 or 1 digits ?
        -- Round temperatures to 2 decimal places
        local oloTempRounded = tonumber(string.format('%.2f', OlohuTemp.temperature))
        local alakTempRounded = tonumber(string.format('%.2f', AlakTemp.temperature))
