Domoticz version 2025.1 released
Posted: Monday 05 May 2025 9:52
by gizmocuz
It's about time for a new stable release!
This could not have happened without the help of everyone who contributed to make this happen!
Forum moderators, users, beta testers and specially all those who contributed with code! Thank you once again!!!
As always, PLEASE make a FULL backup of your Domoticz folder (or in case of an embedded system, your SD card!)
This way you can always return to the previous version you were running before this update!
Thanks to all volunteers who helped with the implementation! I know it was a lot of work with a lot of stress!
Here are the most important changes (there are way too many changes to list them all):
Version 2025.1 (May 5th 2025)
- Implemented: Battery level for Setpoint sensors
- Implemented: Charts, zoom option for 'Day' view
- Implemented: Data Pushers, added P1 actual value
- Implemented: EnOcean, now able to choose an optional base_id as sender_id instead of the chip_id (#6213)
- Implemented: Floorplan, Add support for stop button (Ventation blinds)
- Implemented: RFXCom, Updated SDK
- Implemented: Support for Honeywell Series 5/PIR
- Implemented: Text sensor, now posible to edit direct from the GUI
- Implemented: YouLess, added Water meter
- Implemented: More default icons
- Implemented: MQTT-AD, added support for Gas device class
- Implemented: MQTT-AD, added support for Text device class
- Implemented: MQTT-AD, better precision for kWh sensors
- Implemented: MQTT-AD, enabled 'device_automation' component to be compatible with upcoming (2025) Zigbee2MQTT version
- Implemented: MQTT-AD, handling single onoff color mode as a normal light/switch
- Implemented: MQTT-AD, power sensors for the Tuya SPM02
- Implemented: MQTT-AD, support sensors that report humidity but sends 'null' values
- Implemented: MQTT-AD, support for string field state objects
- Implemented: MQTT Push 'Retained' mode option
- Implemented: Rain devices can now be replacement with different types of rain devices
- Implemented: RFXCom, Falmec Support
- Implemented: RTL433, Support Generic Switch (Door) sensor
- Implemented: Tado, oauth2 support
- Changed: dzVents, possible to pass a Domoticz device ID in notify() through the extra parameter
- Changed: Energy Dashboard now also available for non-admin users
- Changed: Energy Dashboard, Text object clipping rectangle
- Changed: Google Firebase Cloud Messaging (FCM) alternative way to pass a Domoticz device ID through the extra field ('|Device=<devidx>')
- Changed: Internal webserver refactoring
- Changed: Netatmo Improved and automated login process for devices (to obtain client ID and Password with user selectable scopes)
- Changed: Removed Highcharts 'Download PNG/JPG/SVG' buttons until export server is fixed
- Changed: Using OpenStreetMap for Latitude/Longitude query in settings
- Changed: Hardware/User/Application/Variables setup page (update/delete/add buttons)
- Changed: Smoke Detectors are now able (internally) to use keep-alive timestamps
- Fixed: Application shutdown, solved possible crash (#6310)
- Fixed: AtagOne, fixed getting device_id and better debuginfo
- Fixed: Charts, dynamic title based on selected range
- Fixed: Computed Meter summation
- Fixed: Custom Icons, making sure they are valid and loaded OK
- Fixed: Floorplan, corrected open/close icon behaviour
- Fixed: Floorplan, now handles protected selectors
- Fixed: MQTT Push, making sure direct push is working
- Fixed: Possible mutex lock issue when logging
- Fixed: Pushers, corrected Gas value rounding
- Fixed: Python framework, invalid sValue when creating a General/kWh sensor
- Fixed: RFXCom 868 MHz Weather device
- Fixed: RFXCom, WS90 Weather device
- Removed: Thermosmart thermostat (Product no longer supported/available by the manufacturer)
- Removed: API: Old RType calls have been replaced (see also wiki https://wiki.domoticz.com/Domoticz_API/ ... and_newer) )
- Updated: HighCharts
- Updated: Self Signed Certificate (Valid till 2035)
- Updated: Translations
For a full detailed overview visit:
https://github.com/domoticz/domoticz/commits/master/
https://github.com/domoticz/domoticz/bl ... istory.txt
You can also update manually by going to your Domoticz folder and issue the following command: ./updaterelease
Up up and away :mrgreen: !
If you encounter update issues please start a new topic in the Bugs and Problems subforum viewforum.php?f=6
Re: Domoticz version 2025.1 released
Posted: Tuesday 06 May 2025 23:22
by user4563
Updated without issue from v2024.7 manually with ./updaterelease
Thank you to everyone involved!
Posted: Wednesday 07 May 2025 9:51
by Marathon2010
Updated from 2024.7 under Docker (running on NAS) without any issues. Thanks for the hard and good work all, appreciated :)
Posted: Thursday 08 May 2025 19:25
by rini52
Thanks, for the new release.
No issues after update from 2024.7 to 2025.1. Don't forget to empty cash in browser, otherwise no dashboards etc...
Using portainer to update in one stack with Domoticz,Z2M,Vscode,Musquitto etc.
Domoticz no probelem with updateing .Homeassistant had problem with P1-meter of HomeWizard.....
Regards,
Rini
Posted: Tuesday 13 May 2025 11:45
by lost
Hello, no issue as well: All went smoothly for a setup mostly OZW and Z4D based, with my own scripts that were already on par with previous APIs changes.
Thanks a lot for this release!
Posted: Tuesday 13 May 2025 16:06
by WouterO
Thank you for the this Stable Version. Update went without problems on my RPi4, using the web ui updater.
We discussed before about the relevance of new Stable Versions vs. Beta’s. One additional advantage of the release of a Stable Version which should not be underestimated, is the attention it gets on Tech Fora (like the Dutch Tweakers). So, please, keep publishing Stables, like, twice per year.
Posted: Wednesday 14 May 2025 14:51
by MasMat
Can confirm also an easy, successful update from GUI on Rpi4, Raspbian Buster.
Posted: Tuesday 27 May 2025 11:03
by Gonetolunch
Update from 2024.7 and no problems on Raspberry 3B+
Posted: Sunday 01 June 2025 22:15
by jacobsentertainment
I'm running 2025.1 #16682 and If I check for an upgrade then #16712 is available, but when I klick OK then it takes 100 seconds and domoticz gives the feedback "there was a issue during the download,check your internet connection" I gave this over a two week period some tries but it keeps doing the same. (As I can post this, clearly the internet connection isn't the isseu :lol: )
Posted: Monday 02 June 2025 8:29
Probably related to beta needing Openssl3 (and so an up to date OS), see viewtopic.php?t=43485
Posted: Monday 02 June 2025 8:47
Thats a good one, i hope to have some time tonight to dive in. Thanks!
