I realise dzVents is far more versatile than Blockly however I just wondered if there was any difference in response times to a command. i.e if you had a simply blockly to toggle a light on each press of a button and the same in a script in dzvents would you notice a difference ?
Blockly or dzVents
- Domoticz version: 2026.3
Re: Blockly or dzVents
Should not be a noticeable difference I suppose.
Do you see differences?
Dave21w
- Domoticz version: Stable
I don't think so, I'm just slowly changing from blockly to dzVent and you know what it's like when you've swapped something and you start thinking was this like this before ?
You can see the reaction time of the scripts in the log. So look at the time difference between switching the switch and start time of the script. Not sure about Blockly but for dzvents scripts the start and end of the scripts are logged.
solarboy
- Domoticz version: 2026.4
I remember when I started moving from Blockly to dzvents it seemed like my cpu use went up. However dzvents is much much more powerful and I found I came up against Blockly's limits pretty quickly.
Tukker
- Domoticz version: 2023.2
Average executing time of dzVents scripts.
Voltage: 0.004090 seconden
EV Consumption: 0.004035 seconden
Airplane tracker: 0.000832 seconden
Electricity costs: 0.006317 seconden
Rain: 0.004822 seconden
Earthquake: 0.002424 seconden
Energy today: 0.001630 seconden
Energy tomorrow: 0.002460 seconden
Car charging: 0.001656 seconden
Car facts: 0.035710 seconden
Display 5 different text sensors: 0.016310 second
Bugs bug me.
