JSON API missing in Domoticz 2025.1 beta (16657)
Posted: Monday 28 April 2025 11:08
Hello everyone,
I'm currently running Domoticz 2025.1 (16657) because I need the Netatmo OAuth2 support (which is not available in the stable version yet).
Everything works fine when accessing the Domoticz web interface (e.g., http://192.xxx.x.x::8080/), but whenever I try to access the JSON API, I get a "Page not found" error.
For example, if I visit:
or simply
I get a "404 Page Not Found" error.
I checked that Domoticz is running without the --minimalwebserver flag.
I am not using any reverse proxy (I connect directly).
Domoticz starts normally, and the web GUI is accessible.
Tested both HTTP and HTTPS access — same issue.
I am not using any authentication settings that could block API access.
My question:
Is the JSON API intentionally disabled or missing in the current 2025.1 (16657)?
Will it be reintroduced soon, or should we expect it only in the next stable release?
Thank you for your help,
Alberto
http://192.xxx.x.x:8080/json.htm?type=devices&order=nameCode: Select all
http://192.xxx.x.x:8080/json.htmI checked that Domoticz is running without the --minimalwebserver flag.
My question:
Alberto
