Tuya ZWT198 wall thermostat, state missing from devices
Posted: Tuesday 15 April 2025 9:47
I have just purchased a Tuya ZWT198 wall thermostat.
This appears to be well supported by zigbee2MQTT, however one state value does not get picked up in Domoticz.
Here are the states as seen in Zigbee2MQTT:
From the above I would like to have access to "running_state" which swaps between "idle" and "heat" according to whether the boiler has been turned off or on by the thermostat. However this does not appear in the available devices in Domoticz. It definitely appears in the published data, viz:
I can't see any errors in any of the logs, has anyone any idea where to look?
Domoticz Version: 2025.1 (build 16626)
Zigbee2MQTT Version 2.1.1
Thanks in advance
"backlight_mode": "high",
"child_lock": "UNLOCK",
"current_heating_setpoint": 22.5,
"deadzone_temperature": 0.5,
"factory_reset": "OFF",
"frost_protection": "ON",
"linkquality": 90,
"local_temperature": 22.5,
"local_temperature_calibration": 0.1,
"max_temperature_limit": 29.5,
"preset": "auto",
"running_state": "heat",
"schedule_holiday": "07:00/22.0°C 23:00/18.5°C",
"schedule_weekday": "06:00/21.5°C 08:00/22.5°C 11:30/21.0°C 12:30/22.0°C 17:00/22.0°C 22:00/18.5°C",
"sensor": "internal",
"system_mode": "heat",
"working_day": "7"
}Code: Select all
info 2025-04-15 09:27:45z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/New Lounge Thermostat', payload '{"backlight_mode":"high","child_lock":"UNLOCK","current_heating_setpoint":22.5,"deadzone_temperature":0.5,"factory_reset":"OFF","frost_protection":"ON","linkquality":93,"local_temperature":22.5,"local_temperature_calibration":0.1,"max_temperature_limit":29.5,"preset":"auto","running_state":"heat","schedule_holiday":"07:00/22.0°C 23:00/18.5°C","schedule_weekday":"06:00/21.5°C 08:00/22.5°C 11:30/21.0°C 12:30/22.0°C 17:00/22.0°C 22:00/18.5°C","sensor":"internal","system_mode":"heat","working_day":"7"}'
Thanks in advance
