Remote Server Settings
solarboy
Domoticz version: 2024.6
Post by solarboy »
In the wiki page for the domoticz remote server there is this line :
Configuration
Remote1 and Remote2
1. Specify the shared port (6144 by default) where the Main will connect to.
But it is not specified where this is to be entered.
In the log of the main I get this repeated ;
Can not connect to: 192.168.2.34:6144 (Connection refused)
I did create a new user ("remote") on the "slave" and used this log in data on the "main" domoticz instance.
jvdz
Domoticz version: 4.107
Re: Remote Server Settings
Post by jvdz »
Port for "Remote Shared Port (For Remote Domoticz clients):" can be found on the Setup/Security page.
solarboy
Post by solarboy »
Brilliant, thank you jvdz !
solarboy
Post by solarboy »
I am still getting
in the "Main" domoticz log. I set the trusted network to "192.168.2.*" and enabled "Allow Basic Auth" and still no luck.
Otherwise I followed the wiki. The new server is a brand new docker version of domoticz on a raspberry pi3b, both are latest stable.
jvdz
Post by jvdz »
solarboy wrote: Thursday 10 April 2025 20:08 The new server is a brand new docker version of domoticz on a raspberry pi3b, both are latest stable.
Did you define the 6144 port in the docker config?
solarboy
Post by solarboy »
Ah , no, I used the standard docker-compose.yml from hub.docker.com/r/domoticz/domoticz.
Good catch !
solarboy
Post by solarboy »
Bingo, all up and running, thanks a lot jvdz.
