Moving average usage
Posted: Sunday 09 March 2025 18:58
by Patricen
I would like to calculate moving average of a value, but can't succeed.
The goal is to detect water leak depending on water consumption. I do have the following available values from water counter : number of liters used since midnight and instantaneous water flow. I think the last one is the clue, if the water flow is stable for a certain amount of time (tbd) and not equal to zéro, there is a leak.
This means that if the moving average equals the actual flow, the leak is suspected.
Can anybody give me some help about moving average calculation to solve m'y issue ?
Re: Moving average usage
Posted: Sunday 09 March 2025 19:24
by Tukker
Tbh, there's nothing from me here, it's just CoPilot.
I inserted your question, preceded with dzVents coding and changed your last sentence to: Can you give me some help about moving average calculation to solve my issue ?
CoPilot answered:
I'd be happy to help you with calculating the moving average for your water consumption data!
The moving average is a commonly used technique for smoothing out data over a specific period. To detect a water leak based on stable water flow over time, you can calculate the moving average of the instantaneous water flow and compare it to the actual flow. If they are equal and not zero, it indicates a potential leak.
Here's an example of how to calculate the moving average in Lua, a language often used with Dzvents:
-- Define the period for the moving average (e.g., 10 minutes)
local period = 10
-- Store the last 'period' values of water flow in an array
local flow_values = {}
-- Function to calculate the moving average
function calculate_moving_average(new_flow)
    table.insert(flow_values, new_flow)
    if #flow_values > period then
        table.remove(flow_values, 1)
    local sum = 0
    for _, flow in ipairs(flow_values) do
        sum = sum + flow
    local moving_average = sum / #flow_values
    return moving_average
-- Example of using the function
local current_flow = 5 -- Replace this with the actual instantaneous water flow value
local moving_average = calculate_moving_average(current_flow)
print("Current flow: " .. current_flow)
print("Moving average: " .. moving_average)
-- Check for leak
if moving_average == current_flow and current_flow ~= 0 then
    print("Leak suspected!")
    print("No leak.")
In this example:
period is the number of values over which you want to calculate the moving average (e.g., 10 minutes).
flow_values is an array storing the last period values of the instantaneous water flow.
calculate_moving_average(new_flow) is a function that adds the new flow value to the array, calculates the moving average, and returns it.
Replace current_flow with your actual instantaneous water flow value, and the script will print whether a leak is suspected based on the moving average.
Feel free to adjust the period value to suit your needs, and let me know if you need further assistance!
Posted: Sunday 09 March 2025 19:35
by waltervl
Posted: Sunday 09 March 2025 20:37
by Patricen
Thanks all,
I'll try this and keep you informed
Posted: Monday 10 March 2025 8:13
by lost
Take care examples are just averaging values not taking into account the time they last.
As well i'm not into dzVent as i stayed lua but i presume historical data used comes from DB
If so you just get 5mn period samples that do not reflect true consumptions for devices with figures that may vary a lot in these 5mn slices.
To sum up, you cannot handle such device as a T or Hum that is quite stable. But that's what domoticz core does.
Had same issue with wattmeters and had to script discrete integration over 10mn slices using last_update.
Posted: Thursday 13 March 2025 21:18
by Patricen
Hello all,
Thank you very much for your inputs, I managed using your examples, the final version that looks working fine is below and can be reused and improved of course. I had to add a virtual device "Water_Leak" as I didn't succeed to send a telegram notification using DzVents (if any clue?)
		timer = {'every 1 minutes'},
		devices = {'Waterflow'}
	logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Leak detection',
	data =
        Waterflow_History = { history = true, maxMinutes = 5},
	execute = function(domoticz)
        local Waterflow = domoticz.devices('Waterflow').flow
                -- add new data waterflow
        domoticz.data.Waterflow_History.add(Waterflow)
       		-- average for waterflow
        local Moving_avg_Flow = domoticz.data.Waterflow_History.avg()
        domoticz.log('Water flow avg  ' .. Moving_avg_Flow, domoticz.LOG_INFO)
        if Moving_avg_Flow == Waterflow and Waterflow > 0 then
            domoticz.devices('Water_Leak').switchOn().checkFirst()
        if Moving_avg_Flow ~= Waterflow or Waterflow == 0 then
            domoticz.devices('Water_Leak').switchOff().checkFirst()
Posted: Monday 31 March 2025 8:00
by Patricen
Hello all,
As written above, it is working fine, except for low flows as the flowmeter device looks to be at detection limit, thus unstable.
As @lost was saying, is it possible to read the meter value (instantaneous cubic meter reading) and associated sample times to compute consumption over time instead of using flowmeter device ?
