[SOLVED] public DZ through ssh tunnel and reverse https apache: widget not updated
Posted: Friday 07 March 2025 23:06
by jpaul
I have a local Domoticz server, with a ssh tunnel to a public server. This public server has an apache https proxy enabled.
DZ is well displayed through the remote url, and I can switch my devices on and off.
When I click on a widget to switch a light on, the light is well toggle on, but the widget icon is not refreshed.
When I try to open https://<public_url>/service-worker.js I've a "401 Unauthorized error"
Here is my config:
  • domoticz stable version 2024.7 in my LAN, IP 192.168.1.1, listening on port 8080
  • on this 192.168.1.1 dz server, autossh is configured to connect to my public server (a.b.c.d) and to establish an ssh tunnel from local port 8080 to remote port 8888:
    /usr/bin/autossh -M 0
     -o "ServerAliveInterval=30" -o "ServerAliveCountMax=3" -o "ExitOnForwardFailure=yes" -N
     -R 8888:127.0.0.1:8080
     [email protected]
  • on the public server, an https apache proxy is enabled with a basic auth
            SSLProxyEngine on
            ProxyVia on
            ProxyPreserveHost On
            ProxyRequests off
            ProxyPass / http://127.0.0.1:8888/
            ProxyPassReverse / http://127.0.0.1:8888/
            ProxyTimeout 5400
            Timeout 5400
            RequestHeader set Authorization "Basic XXXXX"
            <Proxy *>
               Order deny,allow
               Allow from all
               Authtype Basic
               Authname "Password Required"
               AuthUserFile /etc/apache2/dohtpasswd
               Require valid-user
            </Proxy>
  • in dz setup, I set "Trusted proxy" to: a.b.c.d;127.0.0.1;127.*;192.168.1.1
What I'm missing ? Can you help me ?
Re: public DZ through ssh tunnel and reverse https apache: widget not updated
Posted: Friday 07 March 2025 23:50
Is security setting Allow Basic-Auth authentication over plain HTTP (API only) switch on?
You also should have a login needed here when accessing from outside
What IP is mentioned in the log in the denied access session?
Check also this page for the websockets entries in Apache config: https://wiki.domoticz.com/WebServer_Proxy
Posted: Saturday 08 March 2025 8:13
by jpaul
"Allow Basic-Auth authentication over plain HTTP " is on.
I can't debug the web requests: DZ server crashes with the options "-loglevel all -debuglevel webserver".
I had to add these "upgrade" option in apache:
ProxyPass / http://127.0.0.1:8888/ upgrade=websocket
ProxyPassReverse / http://127.0.0.1:8888/ upgrade=websocket
But he issue is definitely with the apache basic-auth:
When I set in apache: RequestHeader set Authorization "Basic XXX"
then the requests on wss://public_address/json return a 401Unauthorized error.
and I think this generates this log in DZ:
Basic Authorization ignored as this is not a call to the API![
domoticz: [web:8080] isPage 0 isAction 0 isUpgrade 1 needsAuthentication 1 isAuthenticated 0 ()
Now if I change apache to RequestHeader unset Authorization, everything works as expected, but I loose the basic auth behavior and I must use the DZ login page to set a login/password :(
Posted: Saturday 08 March 2025 8:35
by jpaul
Got it ! It's solved, I added this in apache:
RequestHeader set X-Forwarded-For  "127.0.0.1"
to sum up, my apache config is
SSLEngine on
SSLCertificateFile      /etc/letsencrypt/live/vvvv/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/vvvv/privkey.pem
SSLProxyEngine on
ProxyTimeout 5400
Timeout 5400
RequestHeader set Authorization "Basic XXXXXXXXXX"
<Proxy *>
  Order deny,allow
  Allow from all
  Authtype Basic
  Require valid-user
</Proxy>
