GPIO over USB (FT232h or ?)
Posted: Tuesday 04 March 2025 19:26
by c64club
Hi everyone. It's my first post after heavy reading.
I'd like to install Domoticz on Linux server, directly or as Podman container. But I need a few GPIO ports to turn on/off few devices (plus temp sensors, preferrably Dallas 18b20), no radio. Is there a simple, proven expander USB->GPIO that works with Domoticz? Plug and play or (acceptable) flash, plug and play.
Tried to search the forum for FT232H but seems nobody used it. Seems obvious for such use.
Or maybe some USB->GPIO module based on Arduino, Rpi Pico or other small board? (should be available as a project ready to flash)
Re: GPIO over USB (FT232h or ?)
Posted: Tuesday 04 March 2025 20:32
by psubiaco
This is not exactly what you're looking for, but
some DomBus modules have many configurable GPIOs (analog, digital, buttons, up/down button, counters, ...) and are plug and play:
1. install the dombus plugin for Domoticz
2. connect a module to the bus (you need a cheap USB/RS485 adapter)
3. set a unique address for that module, then all module ports are ready to use.
As this is a wired bus, it's 100% reliable and secure solution.
Also, DomBus modules are designed for
very low power consumption and can communicate each other so
it is possible, for example, to configure a port connected to a pushbutton/switch to activate a relay port in another (or same) DomBus module, so these simple automations can work independently from Domoticz.
https://wiki.domoticz.com/Creasol_Dombus
Posted: Tuesday 04 March 2025 21:04
by c64club
A bit overkill for my needs but looks very interesting, especially in situation when far and reliable connection is needed. Though the project site and shop look (and work) like abandoned around 2001, the prices are at least up to date
(for west European). So i keep it in mind.
Does Domoticz have some "standard" GPIO method for computers other than Rpi?
Posted: Tuesday 04 March 2025 21:14
by psubiaco
c64club wrote: Tuesday 04 March 2025 21:04
There is a misunderstanding: 2001 is the year when Creasol, the italian company producing DomBus modules, born!
The prices you see at
https://store.creasol.it/domotics are correct, even if modules are produced in "West Europe" as you mind.
Posted: Wednesday 05 March 2025 1:04
by c64club
Yes I figured out that they started in 2001. But visiting their site feels like time-travel to 2001.
For the prices - they seem actual - maybe Western European can afford their devices. Me not. Or, to be precise, my server and its yearly run costs are less than cheapest Dombus module. If I wouldn't find anything more affordable, will go for one or two Dombus 12 modules.
For now - I still search for something closer to FT232H. If it exists for Domoticz.
Posted: Wednesday 05 March 2025 10:07
Perhaps you can use something like this:
https://github.com/bbqkees/Domoticz-Pi- ... me-ov-file
Or search in the plugin list for the term relay for supported relay devices:
https://wiki.domoticz.com/Plugins
There are also the Denkovi IO modules
https://denkovi.com/domoticz-with-denkovi-modules
Posted: Friday 07 March 2025 0:05
by c64club
Muchos gracias.
That's what I need for output.
Nowe the same or similar solution for output plus some two-way pin (for 1wire) is needed.
Posted: Friday 07 March 2025 8:07
You can also use esphome
https://esphome.io/ on esp devices. It connects over MQTT Auto Discover with Domoticz.
Posted: Friday 07 March 2025 9:27
by Dave21w
There is also quite a lot of Ethernet based relays boards you could choose from too. My take on this would be that in the even something fails to work you could at least connect to the board directly to see if it's responding.
Posted: Saturday 08 March 2025 20:28
by c64club
Thanks guys. I really appreciate your wide and detailed help for new user.
After second deeper reading, for this particular location, dedicated Raspberry seems the only reasonable option, just for its GPIO.
In case I would need physical on/off outputs and some (not yet isntalled) sensors, I will choose one of options you proposed. With network connected sensors and Domoticz in container on existing x86 server. I have all your info saved in my notebook for future use.
