Page 1 of 2
Why is dzvents device lookup using name instead of idx
Posted: Friday 14 February 2025 17:31
by Ragdag
If I do a script like this, it fails
local TEST_SWITCH = 565
local myTestIDX = 3081
devices = {
TEST_SWITCH
logging = {
level = domoticz.LOG_DEBUG,
marker = 'TEST SCRIPT',
domoticz.devices(myTestIDX).switchOff()
with
2025-02-14 17:22:24.045 Error: ZwaveJS2MQTT: sending switch commands for switch type 'sensor' is not supported (yet...) (zwavejs2mqtt_0xc15d8aa6_73-50-0-value-66049/Slaapkamer Luuk - Nachtlampje)
the reason for this is that dzvents is using name as the lookup and not the idx
I can work around that by renaming device, but for some devices I like them having the same name without the need to overextend teh name to something like Slaapkamer Luuk - Nachtlampje - kWh and Slaapkamer Luuk - Nachtlampje - Switch
Why does Domoticz/dzVents prioritize name-based lookup instead of the more reliable IDX? Wouldn't IDX be a better unique identifier for device action
Re: Why is dzvents device lookup using name instead of idx
Posted: Friday 14 February 2025 18:38
by Tukker
Be carefull when using identical names.
Anyway 'Slaapkamer Luuk - Nachtlampje'for two devices, one usage and the other switch is deadly, that's for shure.
Name it Luuk central, Luuk lampje, Luuk whatever, keep the name short.
I had some trouble updating a textSensor which had the same name as somthing else, maybe even the name of the script.
It updated 9 lines. After renaming it it updated all 12 lines.
So domoticz.devices(3080).switchOff() does not react?
and domoticz.devices('Slaapkamer Luuk - Nachtlampje').switchOff() does not react either?
Posted: Friday 14 February 2025 18:42
by Ragdag
That is not the actual switch but one of the other switches that the wallplug creates, the actual switching device is 3081
The reason seems to be that idx 3080 has the same name and is picked up in dzvents and passed to the command which triggers the sensor error
Posted: Friday 14 February 2025 18:46
by Tukker
Same name for 2 different entities will alway render problems, in any programming language.
You could use Slaapkamer Luuk - Nachtlampje en Slaapkamer Luuk _ Nachtlampje
Posted: Friday 14 February 2025 19:00
by Ragdag
I know, but generally speaking any application that has ID and Name labels uses the ID as primary look ups not the names
Posted: Friday 14 February 2025 19:21
I believe it is due to the original Lua integration (dzvents is an addon on the Lua integration). Lua is looking at names, not IDX.
Posted: Sunday 16 February 2025 12:52
by Ragdag
Okay, I understand.
In the end created a script that processed the nodes.json output from Zwave JS and did a rename based on the naming scheme there (%loc - %n - %l) so that all are unique.
if anybody is interested, here is the script I build
https://github.com/Rouzax/Rename-Domoti ... -ZwaveJSON
Use at own risk and MAKE A BACKUP BEFORE!!
Posted: Tuesday 18 February 2025 15:02
by Kedi
Ragdag wrote: Friday 14 February 2025 19:00
I do not agree. Numbers are for computers and Names are for humans. The numbers are unique, so should the names be.
If you use Google (dzga) You can call your lights, switches or whatever by Name and it works.
Try memorizing all those numbers for Google to switch lights etc. on/off
Posted: Tuesday 18 February 2025 16:16
If you look at other applications with objects in a database (I am an application manager with some database applications in management) they do work with Unique ID's (UID), the name is then irrelevant. Problem in Domoticz database is also that it is not a Unique ID. There are multiple objects with IDX:1 (a hardware gateway, a device, a camera, a scene/group, a timer a floorplan etc). But hey, this is what we have to live with here in Domoticz.
It would be an improvement for now if Domoticz would not allow double names for objects in the database to prevent issues.
Posted: Tuesday 18 February 2025 16:31
by manjh
waltervl wrote: Tuesday 18 February 2025 16:16
I fully agree. Once you get to work with Domoticz in a bit lower and technical detail, you will find peculiarities.
It shows that Domoticz was developed in an organic way, as a hobby project; not as a professionally designed software development project.
But to be honest: that is also the charm of Domoticz!
A while back I had a look at HA, and decided to stick with Domoticz...
Posted: Tuesday 18 February 2025 16:43
by Ragdag
manjh wrote: Tuesday 18 February 2025 16:31
Agree with this, have looked at HA a few times, but I have so much scripting and customization in Domoticz that it will be hard to replace
Posted: Tuesday 18 February 2025 17:45
by gizmocuz
That's not correct. Each table have a unique ID.
A device table is something different then a scene table
This is normal database development (SQL)
Posted: Tuesday 18 February 2025 17:47
by gizmocuz
Gee thanks!
So, as you have probably looked at the code, what's not professional about this? Do you think that an application that can work with 50+ different type of hardware, can control various devices with schedules/scripts and API is not professional?
This is not an application that does one trick (like pushing one type of hardware to MQTT)
And you are more than welcome to help with development as this is an open source project
Posted: Tuesday 18 February 2025 18:27
gizmocuz wrote: Tuesday 18 February 2025 17:45
In the 2 big applications I use professionally each object has an unique ID even if they are separated by tables or object sort. So when I query for an ID over the complete database (with millions of objects) I only get one result. So your conclusion that the way Domoticz is setup is normal database development is not true, but my conclusion one can do it differently is also true.
Posted: Wednesday 19 February 2025 8:57
by Ragdag
@gizmocuz It was not my intention to disrespect your work. I truly love Domoticz and hope that it has a long life ahead of it, and value all the hard work that people put into it.
Unfortunately, I'm no developer, otherwise I would have contributed.
Posted: Monday 24 February 2025 14:53
by lost
Domoticz was developed in an organic way...
Organic: This reminds me another "little hobby project"...
https://wptavern.com/linus-torvalds-sha ... ation-hype
“If you want to do something new, something that is really pushing the envelope, nobody can really say ‘This is the way to do it,’” Torvalds said. “What you need to do is a lot of trial and error. I often compare software development to biological processes where really it is evolution. It is not intelligent design.
Posted: Monday 29 June 2026 16:41
by Ragdag
Wanted to bump this to the surface again, as there is something to say about generating a cross-hardware stable ID for all devices.
Posted: Monday 29 June 2026 18:58
by solarboy
I always use device Id's for the reasons mentioned above.
Posted: Monday 29 June 2026 19:14
solarboy wrote: Monday 29 June 2026 18:58
IDX is unique, the name could not be. If the name is not unique then dzvents gets confused as it does not know what unique IDX to map to the name....
I use IDX in my dzvents scripts but you have to be aware you have to have unique device names too.
Posted: Monday 29 June 2026 19:23
by Ragdag
waltervl wrote: Monday 29 June 2026 19:14
IDX is not unique, it is only unique for all devices under a single hardware item.
Also (the reason I started this thread to begin with), dzvents only uses the IDX to look up the device name, which is then used in the script. I learned that the hard way with device having the same name and dzvents not triggering the device I expected.
