Identify a switching sequence
Posted: Friday 14 February 2025 14:31
by paul402
I would like to know if 3 movement sensors are triggered in a sequence with max 5 minutes gap between each of the triggers for the data to be valid.
I not sure how to go about this so would appreciate some hints on how to do it.
I'm not asking someone to do it for me, just give me a clue. For instance do I need to use persistent data or not. Thanks.
Re: Identify a switching sequence
Posted: Friday 14 February 2025 14:44
by Ragdag
Asked my trusted ChatGPT
local scriptVar = 'Motion_Sequence_Detection'
-- Sensor configuration
local SENSOR_IDX = {
MOTION_1 = 1001, -- Replace with actual Domoticz device IDs
MOTION_2 = 1002,
MOTION_3 = 1003
-- Constants
local MAX_TIME_GAP = 300 -- 5 minutes (300 seconds)
devices = {SENSOR_IDX.MOTION_1, SENSOR_IDX.MOTION_2, SENSOR_IDX.MOTION_3} -- Trigger on motion sensor activation
logging = {
level = domoticz.LOG_DEBUG,
marker = scriptVar,
data = {
Motion1Time = { initial = 0 },
Motion2Time = { initial = 0 },
Motion3Time = { initial = 0 }
local function logDebug(message)
domoticz.log(message, domoticz.LOG_DEBUG)
local function logInfo(message)
domoticz.log(message, domoticz.LOG_INFO)
local function triggerAction()
logInfo("Motion sequence detected! Triggering action.")
-- Add your action here, e.g., send a notification
domoticz.notify("Motion Sequence", "All 3 motion sensors triggered in sequence!", domoticz.PRIORITY_NORMAL)
-- Reset timestamps after detection
domoticz.data.Motion1Time = 0
domoticz.data.Motion2Time = 0
domoticz.data.Motion3Time = 0
local currentTime = os.time()
if item.idx == SENSOR_IDX.MOTION_1 then
logDebug("Motion sensor 1 triggered")
domoticz.data.Motion1Time = currentTime
elseif item.idx == SENSOR_IDX.MOTION_2 then
if domoticz.data.Motion1Time > 0 and (currentTime - domoticz.data.Motion1Time) <= MAX_TIME_GAP then
logDebug("Motion sensor 2 triggered within valid time window")
domoticz.data.Motion2Time = currentTime
logDebug("Motion sensor 2 triggered but sequence invalid (resetting)")
elseif item.idx == SENSOR_IDX.MOTION_3 then
if domoticz.data.Motion1Time > 0 and domoticz.data.Motion2Time > 0 and
(currentTime - domoticz.data.Motion2Time) <= MAX_TIME_GAP then
logDebug("Motion sensor 3 triggered within valid time window")
triggerAction() -- All 3 sensors triggered in sequence
logDebug("Motion sensor 3 triggered but sequence invalid (resetting)")
or
-- Trigger on all three motion sensor devices
devices = { "Motion Sensor 1", "Motion Sensor 2", "Motion Sensor 3" }
-- Persistent data to store the timestamps of triggers
data = {
sequence = { initial = {} }
local now = os.time() -- Current timestamp in seconds
local seq = domoticz.data.sequence -- Get the current sequence
-- If there is already a recorded trigger, check the gap between the last trigger and now
if #seq > 0 then
local lastTrigger = seq[#seq]
if (now - lastTrigger > 300) then -- 300 seconds = 5 minutes
domoticz.log("Time gap exceeded 5 minutes. Resetting sequence.", domoticz.LOG_INFO)
seq = {} -- Reset the sequence if the gap is too long
-- Add the current trigger's timestamp to the sequence
table.insert(seq, now)
domoticz.data.sequence = seq -- Save the updated sequence
domoticz.log("Sensor triggered: " .. device.name .. ". Sequence count: " .. #seq, domoticz.LOG_DEBUG)
-- Check if we have reached three triggers in valid succession
if #seq >= 3 then
domoticz.log("Valid sequence of 3 movement sensor triggers detected!", domoticz.LOG_INFO)
-- Perform your desired action here. For example, send a notification:
domoticz.notify(
"Movement Sequence",
"Three movement sensors were triggered in sequence with less than 5 minutes between each.",
-- Reset the sequence after handling the valid event
domoticz.data.sequence = {}
Posted: Friday 14 February 2025 14:47
You can ask for the last updated value of those 3 sensors if the last update value is equal to switching. It depends on the integration if last update is the same as last switched.
if (domoticz.devices('My PIR 1').lastUpdate.minutesAgo < 5 and
domoticz.devices('My PIR 2').lastUpdate.minutesAgo < 5 and
domoticz.devices('My PIR 3').lastUpdate.minutesAgo < 5)
Posted: Friday 14 February 2025 15:28
by paul402
Wow! Thank you. I never expected so much help!
Can I be cheeky and ask how I would change this if the motion sequence went sensor1, sensor2 and back to sensor1 as the alternative possible exit.
Posted: Friday 14 February 2025 19:26
I think you have to ask chatgpt.....
My solution was only to check if 3 motion sensors were triggered within 5 minutes. Not checking the order. But that could probably done with some simple if-then statements based on last updates (but then with swcondsago instead of minutes ago.
Posted: Sunday 16 February 2025 6:28
by paul402
Thanks. I've never used AI/ChatGPT before how do you phrase a request for code? Do you have an example of what you entered to reply to my initial post?
Posted: Thursday 20 February 2025 8:59
by Ragdag
paul402 wrote: Sunday 16 February 2025 6:28
I did something like this
Can you help me with this Domoticz dzvents script?
I do have the premium ChatGPT this month, so I created a Domoticz dzvents project so that I can attach the dzvents wiki page as a resource, but even without it will likely work
Posted: Thursday 20 February 2025 9:06
by Ragdag
Here is an alternative, with both sequences
Description:
This script monitors a sequence of three motion sensors. It validates that the triggers occur within a maximum of 5 minutes between each activation.
Additionally, it detects an alternative exit sequence where motion returns to Sensor 1 after Sensor 2.
-- Constants and Configuration
local scriptName = 'MotionSequenceDetection'
local maxTimeGap = 300 -- 5 minutes (in seconds)
-- Sensor names as configured in Domoticz
local SENSORS = {
SENSOR1 = 'Motion Sensor 1',
SENSOR2 = 'Motion Sensor 2',
SENSOR3 = 'Motion Sensor 3'
-- Persistent Data Storage
devices = { SENSORS.SENSOR1, SENSORS.SENSOR2, SENSORS.SENSOR3 }
data = {
motionSequence = { initial = {} }
local now = domoticz.time.raw
local sequence = domoticz.data.motionSequence
-- Remove expired entries
local newSequence = {}
for _, entry in ipairs(sequence) do
if now - entry.time <= maxTimeGap then
table.insert(newSequence, entry)
sequence = newSequence
-- Add the new motion event
table.insert(sequence, { sensor = device.name, time = now })
domoticz.data.motionSequence = sequence
-- Check if sequence matches predefined patterns
if #sequence >= 3 then
if sequence[1].sensor == SENSORS.SENSOR1 and
sequence[2].sensor == SENSORS.SENSOR2 and
sequence[3].sensor == SENSORS.SENSOR3 then
domoticz.log('Valid motion sequence detected: SENSOR1 -> SENSOR2 -> SENSOR3', domoticz.LOG_INFO)
elseif sequence[1].sensor == SENSORS.SENSOR1 and
sequence[3].sensor == SENSORS.SENSOR1 then
domoticz.log('Alternative exit detected: SENSOR1 -> SENSOR2 -> SENSOR1', domoticz.LOG_INFO)
Posted: Friday 21 February 2025 12:56
by paul402
Thank you. I've learned something new!
Much appreciated. Can't wait to try this on another project I have in mind to create a touch screen Raspi with rotating info/photo screens.
