Is there a select statement?
manjh
- Domoticz version: 2025.2
Hopefully there is a simple answer to this...
In other programming languages I can use the select statement to execute parts of code depending on content of a variable.
For instance:
Assume variable x has a numeric value.
Select (x)
when (1) do
when (2) do
otherwise
I know I could do this using if-then-elseif etcetera, but the select would be much cleaner....
Is there something like this?
For instance:
Select (x)
when (1) do
when (2) do
otherwise
Hans
Kedi
- Domoticz version: latest
Re: Is there a select statement?
In https://www.lua.org/manual/5.1/manual.html you can see that the select statement is used for somewhat different.
What would be the benefit over "if then elseif end" method?
lost
The C-like switch/case is not present in Lua (was same for very long with Python as well), usual advice to avoid heavy if/elseif usage is to rework the logic using what is the basis of this language: Tables...
http://lua-users.org/wiki/SwitchStatement
That's one among C oldies I often miss using Lua or Python, others being static variables and ternary operator: There is always some tricks, but not being a language feature I always have to remember/search when needed.
manjh
Maybe I should explain the purpose I wanted this for.
I use a UserVariable to store a value, coming out of a number of NFC sources.
Each value represents a specific command: like "turn on lights", "turn off ventilation", "toggle driveway spotlight", etcetera.
My routine picks up that uservariable, and then executes a specific subroutine.
One way to do it would be to name the subroutine with the value and then call it using the variable.
For example: name the subroutine "1", and then find a way to call that directly using the uservariable.
Unfortunately I see no way to do this in LUA.
The article pointed at by "lost" in this thread, shows many interesting workarounds to do it.
But I guess for now I'll stick to the if-then-elseif list.
Hans
- jvdz
- Domoticz version: 4.107
Can't you simply store them in an array using the number as key? That way you should be able to get the command with array[key].
manjh
Not sure what you mean. Store what in an array? Get what command?jvdz wrote: Thursday 06 February 2025 9:13 Can't you simply store them in an array using the number as key? That way you should be able to get the command with array[key].
Could you give a small example?
Hans
FlyingDomotic
- Domoticz version: 2020.2
Idea, for a switch number between 3 and 6, to use something like:
array[3] = "AAAA"
array[4] = "BBBB"
array[5] = "CCCC"
array[6] = "DDDD"
if number >= 3 and number <=6 then
print(array[number])
print("Number out of 3-6 range")
Tukker
- Domoticz version: 2023.2
If - elseif:
or:
like:
local x = 2 -- Example value
if x == 1 then
-- Code to execute when x is 1
print("x is 1")
elseif x == 2 then
-- Code to execute when x is 2
print("x is 2")
-- Code to execute for all other cases
print("x is something else")
endCode: Select all
local actions = {
[1] = function()
print("x is 1")
end,
[2] = function()
print("x is 2")
local action = actions[x] or function()
action() -- Execute the corresponding functionCode: Select all
devices = { 'MyDevice' }
local x = device.state -- Assuming the device state is a numeric value
local actions = {
[1] = function()
domoticz.log("x is 1", domoticz.LOG_INFO)
-- Additional actions for x == 1
end,
[2] = function()
domoticz.log("x is 2", domoticz.LOG_INFO)
-- Additional actions for x == 2
domoticz.log("x is something else", domoticz.LOG_INFO)
-- Additional actions for other cases
}Bugs bug me.
manjh
Thank you! This is EXACTLY what I was looking for!HvdW wrote: Thursday 06 February 2025 18:05 If - elseif:or:Code: Select all
local x = 2 -- Example value if x == 1 then -- Code to execute when x is 1 print("x is 1") elseif x == 2 then -- Code to execute when x is 2 print("x is 2") else -- Code to execute for all other cases print("x is something else") endlike:Code: Select all
local x = 2 -- Example value local actions = { [1] = function() -- Code to execute when x is 1 print("x is 1") end, [2] = function() -- Code to execute when x is 2 print("x is 2") end } local action = actions[x] or function() -- Code to execute for all other cases print("x is something else") end action() -- Execute the corresponding functionCode: Select all
return { on = { devices = { 'MyDevice' } }, execute = function(domoticz, device) local x = device.state -- Assuming the device state is a numeric value local actions = { [1] = function() domoticz.log("x is 1", domoticz.LOG_INFO) -- Additional actions for x == 1 end, [2] = function() domoticz.log("x is 2", domoticz.LOG_INFO) -- Additional actions for x == 2 end } local action = actions[x] or function() domoticz.log("x is something else", domoticz.LOG_INFO) -- Additional actions for other cases end action() -- Execute the corresponding function end }
Hans
manjh
For everyone that is interested, I found an elegant way to solve my coding problem.
It starts with a UserVariable that contains an integer value. For each unique value of that UserVariable, I create a function, called NFCn.
This is the code to call the right function, based on the uservariable:
This shows a very compact and elegant way to do it, much smaller than the if-then-elseif-etcetera construct!
(The functions are not shown in this code snippet, but are not difficult)
-- run through all changed variables
local myVariable = "NFC"
for variableName,variableValue in pairs(uservariablechanged) do
-- check if NFC value was changed
if (variableName == myVariable) then
-- found it. Now compose function name
local FunctionName = variableName..variableValue
-- if function exists, call it. Else report.
if (_G[FunctionName] ~= nil) then
_G[FunctionName]()
print(FunctionName.." does not exist")
Hans
Kedi
Why run through all changed variables, instead of
variables = { 'NFC' }
execute = function(dz, item)
... do stuff
}Logic will get you from A to B. Imagination will take you everywhere.
manjh
This is dzvents, I wanted to stick to pure LUA...Kedi wrote: Thursday 13 February 2025 13:38 Why run through all changed variables, instead ofCode: Select all
return { on = { variables = { 'NFC' } }, execute = function(dz, item) ... do stuff end }
But you're right. Instead of looping through the whole list of uservariables, I could just check for uservariablechanged[myVariable].
Hans
