Temp log header not changing
Posted: Sunday 02 February 2025 18:16
by FredZ
Hello all
I have just noticed that when I view a temp it defaults to 7 days, but when I click 1d the log shows correctly but the log header stays at 7Days.
Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-14 02:59:31
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Sep 14 2024, 03:00:30) [GCC 12.2.0]
Installed on Raspberry pi4
Debian GNU/Linux 12 (bookworm)
Fred
Re: Temp log header not changing
Posted: Sunday 02 February 2025 20:48
The header is not related to the 3d, 1d, 3hr, 1hr filter in the graph but related to the setting of days in menu Setup - Settings, tab logs.
You can also select a custom range with your mouse or your fingers. Also then the header will not change.
So probably this is not a bug. If you feel you need to change this behavior you are free to propose your code change with a Pull Request on the GitHub repository.
