solar power prediction
JanJaap
Domoticz version: Dev
Post by JanJaap »
Hey,
Has anyone already built some integration to fetch predicted solar power? Would be interested in light of controlling home batteries. First step would be to compare prediction vs actuals..... Solarpanel.forecast for example seems like a potential target to pull form.
psubiaco
Re: solar power prediction
Post by psubiaco »
I don't remeber where I found this dzVents script, but it works. Try it!
    timer = {
        'at *:50'
    httpResponses = {
      'solarforecastEAST' -- must match with the callback passed to the openURL command
  logging = {
    level = domoticz.LOG_INFO,
    marker = 'get solar forecast',
      local idxSolarForecastCounter=2481  	-- device with 24h forecast: type 'Managed counter', Energy generated
      local idxSolarForecast=2477  			-- device holding the forecast for the next hour: type 'Custom sensor', axis: 'Wh'
    if (item.isTimer) then
		print("EAST")
      domoticz.openURL({
        url = 'https://api.forecast.solar/estimate/watthours/period/45.8812/12.1833/15/-90/2.7',
        method = 'GET',
        callback = 'solarforecastEAST', -- see httpResponses above.
    if (item.isHTTPResponse) then
      if (item.ok) then
        --domoticz.log('item.data ' .. item.data .. '***************************', domoticz.LOG_INFO)
        if (item.isJSON) then
            domoticz.utils.dumpTable(item)
            local messagetype=item.json.message["type"]
            domoticz.log("message type" .. messagetype, domoticz.LOG_INFO)
            if messagetype=="success" then
                local currentHR=os.date("%Y-%m-%d %H:00:00")
                local oneHRahead=os.date("%Y-%m-%d %H:00:00",os.time()+1*60*60)
                local twoHRahead=os.date("%Y-%m-%d %H:00:00",os.time()+2*60*60)
                local forecastCurrentHR=tonumber(item.json.result[currentHR])
                if forecastCurrentHR==nil then
                    forecastCurrentHR=0
                local forecastOneHR=tonumber(item.json.result[oneHRahead])
                if forecastOneHR==nil then
                    forecastOneHR=0
                local forecastTwoHR=tonumber(item.json.result[twoHRahead])
                if forecastTwoHR==nil then
                    forecastTwoHR=0
                domoticz.log("solar forecast for next three hours :" .. forecastCurrentHR .. "+" .. forecastOneHR .. " + " .. forecastTwoHR .. " WattHR", domoticz.LOG_INFO)
                domoticz.devices(idxSolarForecast).updateCustomSensor(forecastOneHR)
                local updateHour=0
                for id = 1, 24 do
                    if id<10 then
                        updateHour="0"..tostring(id)
                        updateHour=tostring(id)
                    domoticz.devices(idxSolarForecastCounter).updateHistory(os.date("%Y-%m-%d ")..updateHour..":00:00","0;0")
                    domoticz.devices(idxSolarForecastCounter).updateHistory(os.date("%Y-%m-%d ",os.time()+24*60*60)..updateHour..":00:00","0;0")
                local response=item.json.result
                for datehour,value in pairs(response) do
                    domoticz.log("solar forecast date "..domoticz.utils.stringSplit(datehour)[1].." hour "..domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1].." value "..value,domoticz.LOG_INFO)
                    local previousHour=domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1]-1
                    if previousHour<10 then
                        previousHour="0"..tostring(previousHour)
                        previousHour=tostring(previousHour)
                    domoticz.log("previousHour "..previousHour)
                    if value>0 then
                        sensorDateHour=domoticz.utils.stringSplit(datehour)[1].." "..domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1]..":00:00"
                        sValueStr="0;"..value
                        domoticz.log("sensorDateHour "..sensorDateHour.." sValueStr "..sValueStr,domoticz.LOG_INFO)
                        domoticz.devices(idxSolarForecastCounter).updateHistory(sensorDateHour,sValueStr)
                        if sensorDateHour==currentHR then
                            domoticz.devices(idxSolarForecastCounter).updateCounter(value)
                domoticz.log("no successfull message", domoticz.LOG_INFO)
            domoticz.log('is not json', domoticz.LOG_INFO)
        domoticz.log('There was a problem handling the request', domoticz.LOG_INFO)
        domoticz.log(item, domoticz.LOG_INFO)
Paolo
JanJaap
Post by JanJaap »
Tnx! Looks simple enough, might convert it to plugin.
psubiaco
Post by psubiaco »
JanJaap wrote: Saturday 01 February 2025 20:02 Tnx! Looks simple enough, might convert it to plugin.
Wow... keep us informed if you'll write a plugin doing that! Thanks a lot
Paolo
willemd
Domoticz version: 2024.1
Post by willemd »
here is my dzVents script to load solar forecast for my location (I replaced my location with XXXX an YYYY) and my panel specs (angles and capacity)
Please check the API specification for the other parameters in the call.
		timer = {
		    'every hour'
		httpResponses = {
			'solarforecast' -- must match with the callback passed to the openURL command
	logging = {
	    local idxSolarForecast=106  -- device holding the forecast for the next hour
	    local idxSolarForecastCounter=186
			domoticz.openURL({
				url = 'https://api.forecast.solar/estimate/watthours/period/XXXX/YYYY/55/58/2.75',
				method = 'GET',
				callback = 'solarforecast', -- see httpResponses above.
			if (item.ok) then
    				        forecastCurrentHR=0
    				        forecastOneHR=0
    				        forecastTwoHR=0
    				    -- set previous forecast to zero on managed counter
    				    local updateHour=0
    				    for id = 1, 24 do
    				        if id<10 then
    				    -- load new forecast onto managed counter
				            if value>0 then
JanJaap
Post by JanJaap »
ok I can fetch data, so far so good. As I never use the dzEvents I'm a bit puzzled to how the sensor update works. Is the 24 hr forecast counter updated per hour? So only one hour form now? Or is it always giving 24 hrs ahead but all hours being updated as time passes?
See first part: JanJaapKo/SolarForecast
erwindob
Post by erwindob »
@JanJaap
Looks promising,
I see the values in my log, but not yet in the devices. Keeping an eye on updates.
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
Try this weblink as introduction & explanation for the scripts earlier in this thread.
eatme1972
Post by eatme1972 »
I installed the Solar Forecast plugin from Jan-Jaap Kostelijk in my Domoticz, but I can not fill in my location anywhere. The counter also stays on 0 KWH.
What am i missing?
JanJaap
Post by JanJaap »
The location is taken from your Domoticz settings. Then fill out all mandatory settings in the plugin hardware page. And then I think you need to wait for the evening as i remember only polling then to avoid rate limits.
If it then still doesnt do anything i need screenshot of HW config and debug logging.
Oh and the values only appear in the logging of the device, as there is never an actual value.
HvdW
Domoticz version: 2023.2
Post by HvdW »
Here is another Solar Power forecast which takes the cloud overcast into account.
        timer = {
            'every 2 hours at daytime'  -- Metingen alleen overdag
        httpResponses = {
            'solar_data'
    data = {
        measurementCycle = { initial = {
            startHour = nil,
            startWh = nil,
            measurements = {}
    execute = function(domoticz, trigger)
        -- ##### CONFIGURATIE #####
        local powerThreshold = 50      -- Minimale weergave drempel (W/m²)
        local dataLogging = true      -- CSV logging aan/uit
        local logFilePath = "/home/pi/csvData/radiation_impact.csv"
        local daysToShow = 2          -- Number of days to display (including today)
        -- ##### HELPER FUNCTIES #####
        local function spaces(count)
            return ("&nbsp;"):rep(count)
        local function calculateAdjustedIrradiance(hourData)
            local gr_w = tonumber(hourData.gr_w) or 0
            local lc = tonumber(hourData.lc) or 0
            local mc = tonumber(hourData.mc) or 0
            local hc = tonumber(hourData.hc) or 0
            local lowCloudFactor = 0.85
            local midCloudFactor = 0.60
            local highCloudFactor = 0.30
            local cloudAttenuation = (lc*lowCloudFactor + mc*midCloudFactor + hc*highCloudFactor) / 100
            cloudAttenuation = math.min(cloudAttenuation, 0.9)
            return math.floor(gr_w * (1 - cloudAttenuation) + 0.5)
        local function generateBar(value)
            local adjustedValue = value or 0
            if adjustedValue < 50 then return "" end
            local symbol = adjustedValue >= 100 and "■" or "|"
            local count = adjustedValue >= 100 and math.floor(adjustedValue/100) or 1
            return string.rep("<span style='color:#FFA500'>"..symbol.."</span>", count)
        local function appendToCSV(timestamp, data)
            local file = io.open(logFilePath, "a")
            if file then
                file:write(timestamp .. ";" .. table.concat(data, ";") .. "\n")
                file:close()
                domoticz.log("Kan logbestand niet openen: " .. logFilePath, domoticz.LOG_ERROR)
        -- ##### HOOFDLOGICA #####
        if trigger.isTimer then
            -- Haal zoninstralingsdata op
            domoticz.openURL({
                url = 'https://data.meteoserver.nl/api/solar.php?locatie=YourHomeTown&key=abcdef123456',
                method = 'GET',
                callback = 'solar_data'
        elseif trigger.isHTTPResponse then
            local data = trigger.json
            if not data then return end
            local now = os.date("*t")
            local currentHour = now.hour
            local solarDevice = domoticz.devices('Zonnepanelen')
            local whToday = solarDevice.WhToday
            -- Verwerk huidige meting
            local currentInstraling = 0
            local currentAdjusted = 0
            local currentClouds = 0
            for _, hour in ipairs(data.forecast) do
                if string.sub(hour.cet, 12, 13) == string.format("%02d", currentHour) then
                    currentInstraling = tonumber(hour.gr_w) or 0
                    currentAdjusted = calculateAdjustedIrradiance(hour)
                    currentClouds = tonumber(hour.lc) + tonumber(hour.mc) + tonumber(hour.hc)
                    break
            -- ##### DATA LOGGING #####
            if dataLogging then
                -- Initieer CSV met header indien niet bestaat
                if not io.open(logFilePath) then
                    appendToCSV("Timestamp", {
                        "StartUur", "EindUur",
                        "Instraling_Origineel", "Instraling_Gecorrigeerd",
                        "CloudCover", "WhToday_Verschil"
                -- Controleer of we een nieuwe cyclus starten (elke even uur)
                if currentHour % 2 == 0 then
                    -- Nieuwe cyclus begint
                    domoticz.data.measurementCycle = {
                        startHour = currentHour,
                        startWh = whToday,
                        measurements = {
                                hour = currentHour,
                                instraling = currentInstraling,
                                adjusted = currentAdjusted,
                                clouds = currentClouds
                    -- Voeg meting toe aan bestaande cyclus
                    table.insert(domoticz.data.measurementCycle.measurements, {
                        hour = currentHour,
                    -- Als we 3 metingen hebben (uur 0, 1 en 2 van de cyclus)
                    if #domoticz.data.measurementCycle.measurements == 3 then
                        local m = domoticz.data.measurementCycle.measurements
                        -- Controleer of alle metingen gelijk zijn
                        local allEqual = true
                        for i = 2, #m do
                            if m[i].adjusted ~= m[1].adjusted or m[i].clouds ~= m[1].clouds then
                                allEqual = false
                                break
                        -- Log alleen als alle metingen gelijk zijn
                        if allEqual then
                            local whDiff = whToday - domoticz.data.measurementCycle.startWh
                            appendToCSV(os.date("%Y-%m-%d %H:%M"), {
                                domoticz.data.measurementCycle.startHour,
                                currentHour,
                                m[1].instraling,
                                m[1].adjusted,
                                m[1].clouds,
                                whDiff
            -- ##### VISUELE WEERGAVE #####
            local datesToDisplay = {}
            for i = 0, daysToShow-1 do
                table.insert(datesToDisplay, os.date('%d-%m-%Y', os.time() + 86400 * i))
            local outputLines = {}
            local totalDataLineCount = 0
            for dayIndex, currentDate in ipairs(datesToDisplay) do
                -- Voeg datumheader toe
                local dateHeader = "Verwachte zoninstraling ("..currentDate.."):"
                if dayIndex > 1 then dateHeader = spaces(15)..dateHeader end
                table.insert(outputLines, dateHeader)
                -- Voeg kolomheaders toe
                local columnHeader = "Uur   Origineel    Gecorrigeerd"
                if dayIndex > 1 then columnHeader = spaces(15)..columnHeader end
                table.insert(outputLines, columnHeader)
                -- Voeg scheidingslijn toe
                local separator = "-----------------------------"
                if dayIndex > 1 then separator = spaces(15)..separator end
                table.insert(outputLines, separator)
                local dateDataLineCount = 0
                    if string.sub(hour.cet, 1, 10) == currentDate then
                        local time = string.sub(hour.cet, 12, 16)
                        local original = tonumber(hour.gr_w) or 0
                        local adjusted = calculateAdjustedIrradiance(hour)
                        if adjusted >= powerThreshold then
                            dateDataLineCount = dateDataLineCount + 1
                            totalDataLineCount = totalDataLineCount + 1
                            local lineContent = string.format(
                                "%s  %03d W/m²   %03d W/m² %s",
                                time,
                                original,
                                adjusted,
                                generateBar(adjusted)
                            -- Inspringing voor dagen na de eerste
                            if dayIndex > 1 then lineContent = spaces(15)..lineContent end
                            -- Speciale inspringing voor eerste dag
                            if dayIndex == 1 and dateDataLineCount > 2 then
                            table.insert(outputLines, lineContent)
                -- Geen data melding
                if dateDataLineCount == 0 then
                    local noDataMsg = "Geen significante zoninstraling verwacht"
                    if dayIndex > 1 then noDataMsg = spaces(15)..noDataMsg end
                    table.insert(outputLines, noDataMsg)
                -- Lege regel tussen datums
                if currentDate ~= datesToDisplay[#datesToDisplay] then
                    table.insert(outputLines, "")
            -- Update device
            domoticz.devices('Zonnestraling').updateText(table.concat(outputLines, "\n"))
Just creatae a TextSensor named Zonnestraling.
The local function calculateAdjustedIrradiance(hourData) calculates the impact of low clouds (lc), medium clouds (mc) and high clouds (hc)
Visit https://data.meteoserver.nl/ to obtain a key.
Bugs bug me.
JanJaap
Post by JanJaap »
Hey, how reliable are these forecasts? As the ones from Solar Forecast tend to be off by more than 40% regularly....
HvdW
Post by HvdW »
JanJaap wrote: Saturday 31 January 2026 9:47 Hey, how reliable are these forecasts? As the ones from Solar Forecast tend to be off by more than 40% regularly....
I have tried to rely on it and have come to the conclusion that it is not reliable. (a bit yes)
It has to do with planning EV charging.
My conclusion: better do this manually.
The other side of the medal:
It's nice to develop something and I have nice displays now.
I made things like predicting the weather visually to be able to check what day is best for a bicycle tour, tomorrow or the day after tomorrow.
Working on airplanes flying over the house using python and dzVents instead of just dzVents.
You know, it's just a hobby keeping me off of the street.
Bugs bug me.
eatme1972
Post by eatme1972 »
JanJaap wrote: Friday 30 January 2026 17:19 The location is taken from your Domoticz settings. Then fill out all mandatory settings in the plugin hardware page. And then I think you need to wait for the evening as i remember only polling then to avoid rate limits.
Thanks JanJaap,
It makes sense to use Domoticz location, I didn't think of that.
I still see "0.00 KwH" in my dashboard. When I open it, I see values.
My goal is to switch on a boiler for x hrs when the solar prediction > 15 KwH.
I have solar panels on east and west, so I make 2 solar forecast hardware/devices and add them up.
Can I do this with the plugin?
Last edited by eatme1972 on Saturday 31 January 2026 13:52, edited 1 time in total.
JanJaap
Post by JanJaap »
HvdW wrote: Saturday 31 January 2026 11:14
Yeah I want to use it for home battery charging strategy vs solar production. For EV charging im simply using the "slimmer laden" app that just picks the cheapest time.
Definition og a hobby: maximum effort, minimum result 🤪
eatme1972
Post by eatme1972 »
Update :
Using the dzvents script from psubiaco and claude.ai, I created a script that adds up the 24-hour yield for today and tomorrow from my east and west panels and displays this.
Now to see over the coming year if it's reasonably accurate :)
        timer = {
            'at *:50'
        httpResponses = {
            'solarforecast_oost',
            'solarforecast_west'
    logging = {
    data = {
        forecastOostToday = { initial = 0 },
        forecastWestToday = { initial = 0 },
        forecastOostTomorrow = { initial = 0 },
        forecastWestTomorrow = { initial = 0 },
        oostReceived = { initial = false },
        westReceived = { initial = false }
        local idxSolarForecastToday = 552 -- device voor VANDAAG totaal: type 'Custom sensor', axis: 'Wh'
        local idxSolarForecastTomorrow = 553 -- device voor MORGEN totaal: type 'Custom sensor', axis: 'Wh'
            print("Ophalen voorspelling OOST en WEST voor vandaag en morgen")
            -- Reset alle waarden
            domoticz.data.forecastOostToday = 0
            domoticz.data.forecastWestToday = 0
            domoticz.data.forecastOostTomorrow = 0
            domoticz.data.forecastWestTomorrow = 0
            domoticz.data.oostReceived = false
            domoticz.data.westReceived = false
            -- Call 1: Oost (3 kWp, -90 graden)
            domoticz.openURL({
                url = 'https://api.forecast.solar/estimate/watthours/period/50.0000000/4.0000000/45/-90/3',
                method = 'GET',
                callback = 'solarforecast_oost',
            -- Call 2: West (1.4 kWp, 90 graden)
            domoticz.openURL({
                url = 'https://api.forecast.solar/estimate/watthours/period/50.0000000/4.0000000/45/90/1.4',
                method = 'GET',
                callback = 'solarforecast_west',
            if (item.ok) then
                    local messagetype = item.json.message["type"]
                    if messagetype == "success" then
                        local totalToday = 0
                        local totalTomorrow = 0
                        local today = os.date("%Y-%m-%d")
                        local tomorrow = os.date("%Y-%m-%d", os.time() + (24 * 60 * 60))
                        -- Tel alle waarden op per dag
                        for datehour, value in pairs(item.json.result) do
                            local forecastDate = string.sub(datehour, 1, 10)
                            if forecastDate == today then
                                totalToday = totalToday + tonumber(value)
                            elseif forecastDate == tomorrow then
                                totalTomorrow = totalTomorrow + tonumber(value)
                        -- Sla het resultaat op afhankelijk van welke callback
                        if item.callback == 'solarforecast_oost' then
                            domoticz.data.forecastOostToday = totalToday
                            domoticz.data.forecastOostTomorrow = totalTomorrow
                            domoticz.data.oostReceived = true
                            domoticz.log("OOST - Vandaag: " .. totalToday .. " Wh, Morgen: " .. totalTomorrow .. " Wh", domoticz.LOG_INFO)
                        elseif item.callback == 'solarforecast_west' then
                            domoticz.data.forecastWestToday = totalToday
                            domoticz.data.forecastWestTomorrow = totalTomorrow
                            domoticz.data.westReceived = true
                            domoticz.log("WEST - Vandaag: " .. totalToday .. " Wh, Morgen: " .. totalTomorrow .. " Wh", domoticz.LOG_INFO)
                        -- Als beide calls binnen zijn, update de devices met de totalen
                        if domoticz.data.oostReceived and domoticz.data.westReceived then
                            local grandTotalToday = domoticz.data.forecastOostToday + domoticz.data.forecastWestToday
                            local grandTotalTomorrow = domoticz.data.forecastOostTomorrow + domoticz.data.forecastWestTomorrow
                            domoticz.log("TOTAAL VANDAAG: " .. grandTotalToday .. " Wh (" .. domoticz.data.forecastOostToday .. " + " .. domoticz.data.forecastWestToday .. ")", domoticz.LOG_INFO)
                            domoticz.log("TOTAAL MORGEN: " .. grandTotalTomorrow .. " Wh (" .. domoticz.data.forecastOostTomorrow .. " + " .. domoticz.data.forecastWestTomorrow .. ")", domoticz.LOG_INFO)
                            domoticz.devices(idxSolarForecastToday).updateCustomSensor(grandTotalToday)
                            domoticz.devices(idxSolarForecastTomorrow).updateCustomSensor(grandTotalTomorrow)
                        domoticz.log("Geen succesvolle respons ontvangen", domoticz.LOG_INFO)
                    domoticz.log('Respons is geen JSON', domoticz.LOG_INFO)
                domoticz.log('Probleem bij verwerken van het verzoek', domoticz.LOG_INFO)
Last edited by eatme1972 on Saturday 31 January 2026 17:53, edited 2 times in total.
Artenverho
Post by Artenverho »
I am using NED.nl as data source (free). It also provides prediction for solar production in (provinces of) the Netherlands. I extrapolate the capacity used value (%) for each hour to my own setup and apply correction for angle and orientation. It results are reasonably accurate, at least as accurate as their own web tool they provide as well: https://ned.nl/index.php/nl/zonne-energievoorspeller (which is not accessible through the API).
I have been running it for a month and it is pretty good aside from the occasion misfire when it comes predicting effects of sudden weather changes and it cannot predict the impact of snow on the panels at all :P.
dzvents script below. be sure to make the necessary sensors, user variables and counters
EDIT: forgot to add that the counter for the daily forecast should have a divider of 10000 in order to get kwh..
--Dzvents script to fetch solar production predictions from NED.nl and adjusts/corrects for PV angle and orientation. Made by Artneverho.
    active = true,
    logging = {
        marker = 'NED-hourly-solar'
    -- Persistent forecast storage
    data = {
        solar = { initial = {} },
        solarAll = { initial = {} }  -- store all hours for user variable
        timer = { 'every hour' },
        httpResponses = { 'NEDHourlySolar' }
        local idxNEDsolarforecast = 528 --provide IDX for counter that shows the forecast (updates hourly)
        local idxNEDtoken         = 29 --IDX for uservariable that contain NED token.
        local idxSolarYesterdayForecast = 529  --idx for custom sensor that shows the final prediction for yesterday (at 23h), in total kWh
        local idxSolarTomorrowForecast = 530 --idx for custom sensor that shows prediction for tomorrow at 13h in total kwh
        local nameUserVariable = 'NEDsolarForecast' --name of uservariable that stors the kwh data in json.
        local token = domoticz.variables(idxNEDtoken).value
        local baseURL = "https://api.ned.nl/v1/utilizations?"
        local pvPeakKW = 4.5 -- set peak power output of solar PV array
        local panelTilt = 27 -- angle of panels
        local pvAzimuth  = 245 -- orientation of the panels.
        local tomorrow = os.time() + 48 * 3600
        local today = os.time()
        local from = os.date("%Y-%m-%d", today)
        local to   = os.date("%Y-%m-%d", tomorrow)
        local currentHour = tonumber(os.date("%H"))
        -- ---- REQUEST ----
        if item.isTimer then
            domoticz.data.solar = {}
            domoticz.data.solarAll = {}  -- clear previous export
            --NOTE: adjust the region to your own location by setting "point=0" to any of the values below:
                -- 0 Nederland
                -- 1 Groningen
                -- 2 Friesland
                -- 3 Drenthe
                -- 4 Overijssel
                -- 5 Flevoland
                -- 6 Gelderland
                -- 7 Utrecht
                -- 8 Noord-Holland
                -- 9 Zuid-Holland
                -- 10 Zeeland
                -- 11 Noord-Brabant
                -- 12 Limburg
            local url =
                baseURL ..
                "point=0" ..
                "&type=2" ..
                "&granularity=5" ..
                "&granularitytimezone=1" ..
                "&classification=1" ..
                "&activity=1" ..
                "&validfrom%5Bafter%5D=" .. from ..
                "&validfrom%5Bstrictly_before%5D=" .. to
            domoticz.openURL({
                url = url,
                method = 'GET',
                callback = 'NEDHourlySolar',
                headers = {
                    ['X-AUTH-TOKEN'] = token,
                    ['accept'] = 'application/xml'
        -- ---- RESPONSE ----
        if item.isHTTPResponse then
            if not item.ok or not item.isXML then
                domoticz.log('NED request failed', domoticz.LOG_ERROR)
                return
            domoticz.devices(idxNEDsolarforecast).updateCounter(0)
            local daycounter = 0
            for _, entry in ipairs(item.xml.response.item or {}) do
                local ts = entry.validfrom
                local hour = tonumber(string.sub(ts, 12, 13))
                local perc = tonumber(entry.percentage)
                if hour then
                    -- ---- SOLAR POSITION / CORRECTIONS ----
                    local numOfDay = os.date('%j')
                    local angularSpeed = 360/365.25
                    local declination = math.deg(math.asin(0.3978 * math.sin(math.rad(angularSpeed) *(numOfDay - (81 - 2 * math.sin((math.rad(angularSpeed) * (numOfDay - 2))))))))
                    local latitude    = domoticz.settings.location.latitude
                    local longitude   = domoticz.settings.location.longitude
                    local function rad(deg) return deg * math.pi / 180 end
                    local function deg(rad) return rad * 180 / math.pi end
                    local timeUTC = hour
                    local solarHour = timeUTC + (4 * longitude / 60)
                    local hourlyAngle = 15 * (12 - solarHour)
                    local sunAltitude = math.deg(math.asin(math.sin(math.rad(latitude))* math.sin(math.rad(declination)) + math.cos(math.rad(latitude)) * math.cos(math.rad(declination)) * math.cos(math.rad(hourlyAngle))))
                    local sunAzimuth = math.acos((math.sin(math.rad(declination)) - math.sin(math.rad(latitude)) * math.sin(math.rad(sunAltitude))) / (math.cos(math.rad(latitude)) * math.cos(math.rad(sunAltitude) ))) * 180 / math.pi
                    local sinAzimuth = (math.cos(math.rad(declination)) * math.sin(math.rad(hourlyAngle))) / math.cos(math.rad(sunAltitude))
                    if(sinAzimuth<0) then sunAzimuth=360-sunAzimuth end
                    local sunAlt = sunAltitude
                    local sunAz = sunAzimuth
                    local diffuseMin = 0.12
                    local lowSunAltCutoff = 3
                    local correction = 0
                    if perc > 0 and sunAlt > -2 then
                        local azDiff = sunAz - pvAzimuth
                        if azDiff > 180 then azDiff = azDiff - 360 end
                        if azDiff < -180 then azDiff = azDiff + 360 end
                        local directFactor
                        if azDiff >= -55 then
                            directFactor = 1.0
                        elseif azDiff >= -100 then
                            directFactor = math.max(0.15, (azDiff + 100) / 45)
                            directFactor = 0.1
                        local altFactor = (sunAlt <= -2) and 0 or (sunAlt < 5 and 0.15 + 0.85*(sunAlt+2)/7 or 1)
                        directFactor = directFactor * altFactor
                        local diffuseFactor = 0.18 * altFactor
                        correction = math.min(1, directFactor + diffuseFactor)
                    -- ---- FINAL ENERGY ----
                    local kWh = pvPeakKW * perc * correction * 10000
                    -- --- STORE FOR PLOTTING / HISTORY (existing logic) ---
                    domoticz.data.solar[hour] = kWh
                    local function nedToDomoticzTime(ts)
                        local y,m,d,H,M,S = ts:match("(%d+)-(%d+)-(%d+)T(%d+):(%d+):(%d+)")
                        local t = os.time({year=y, month=m, day=d, hour=H, min=M, sec=S, isdst=nil}) + 3600
                        return os.date("%Y-%m-%d %H:%M:%S", t)
                    local dt = nedToDomoticzTime(ts)
                    domoticz.devices(idxNEDsolarforecast).updateHistory(dt, "0;" .. kWh)
                    -- --- NEW: store for user variable export
                    table.insert(domoticz.data.solarAll, { ts = ts, kWh = kWh })
                    -- --- DAILY TOTALS (existing logic) ---
                    if daycounter <= 24 then
                        totalToday = totalToday + kWh
                        totalTomorrow = totalTomorrow + kWh
                    daycounter = daycounter + 1
                    -- Debug log
                    domoticz.log(string.format("Hour %d: perc=%.4f sunAz=%.1f, sunAlt=%.1f, correction=%.3f kWh=%.3f", hour, perc, sunAz, sunAlt, correction, kWh), domoticz.LOG_INFO)
            -- ---- EXPORT TO USERVARIABLE ----
            local out = {}
            for _, e in ipairs(domoticz.data.solarAll) do
                table.insert(out, { ts = e.ts, kWh = tonumber(string.format('%.3f', e.kWh)) })
            table.sort(out, function(a,b) return a.ts < b.ts end)
            domoticz.variables(nameUserVariable).set(domoticz.utils.toJSON(out))
            domoticz.log('Stored NEDsolarForecast ('..#out..' hourly entries, including tomorrow if available)', domoticz.LOG_INFO)
            -- ---- DAILY CUSTOM SENSOR UPDATES (existing logic) ----
            if currentHour == 23 then
                local totalKWh = totalToday / 10000
                domoticz.devices(idxNEDsolarforecast).updateHistory(from, '0;' .. totalToday)
                domoticz.devices(idxSolarYesterdayForecast).updateCustomSensor(domoticz.utils.round(totalKWh,2))
                domoticz.devices(idxSolarYesterdayForecast).updateCustomSensor(domoticz.devices(idxSolarYesterdayForecast).rawData[1])
            if currentHour == 13 then
                local totalKWhTomorrow = totalTomorrow / 10000
                domoticz.devices(idxSolarTomorrowForecast).updateCustomSensor(domoticz.utils.round(totalKWhTomorrow,2))
                domoticz.devices(idxSolarTomorrowForecast).updateCustomSensor(domoticz.devices(idxSolarTomorrowForecast).rawData[1])
            domoticz.devices(idxNEDsolarforecast).updateCounter(domoticz.utils.round(totalToday,2))
            domoticz.log("Total predicted solar production today: "..string.format("%.3f kWh", totalToday), domoticz.LOG_INFO)
JanJaap
Post by JanJaap »
eatme1972 wrote: Saturday 31 January 2026 13:04
Seeing you already fixed that. No you can't, the plugin you need to set up twice and then use some other script to add them.
JanJaap
Post by JanJaap »
Artenverho wrote: Saturday 31 January 2026 20:51 I am using NED.nl as data source (free). It also provides prediction for solar production in (provinces of) the Netherlands. I extrapolate the capacity used value (%) for each hour to my own setup and apply correction for angle and orientation. It results are reasonably accurate, at least as accurate as their own web tool they provide as well: https://ned.nl/index.php/nl/zonne-energievoorspeller (which is not accessible through the API).
Any insights on the accuracy of this API? Ive compared the results of last months of my plugin and saw some massive outliers where predictions were a factor 5 or more too high. And then read your comment about the snow ;). For the normal days I see accurcy vary around 30% in both directions.
I plan to put this into a plugin as well (will fire up copolit tonight) as this is usually a bit more user friendly way to fetch the data (although many users combine the data collection with the actual business logic, I like to separate those).
Artenverho
JanJaap wrote: Saturday 07 February 2026 10:49 Any insights on the accuracy of this API? Ive compared the results of last months of my plugin and saw some massive outliers where predictions were a factor 5 or more too high. And then read your comment about the snow ;). For the normal days I see accurcy vary around 30% in both directions.
It seems the most accurate on the day itself rather predicting tomorrow. But this is probably just the Dutch in general I guess. on a sunny day like today my solar system generated 8.7kwh, the script I made predicted 8.5kwh this morning. Yesterday it predicted 6.8kwh for today.. so yeah it is not perfect but for my purpose in scheduling my home battery it works (see my other post: viewtopic.php?t=44342). The API allows quite some refreshing so I am updating the predictions every hour.
FYI, you can also read out wind production predictions from the same API. I use this to relax the economics of my home battery scheduling every time the wind energy production goes above 90% in The Netherlands. The aim here is to increase my renewable energy usage. script is very similar to the solar one:
--Dzvents script to fetch wind production predictions from NED.nl and adjusts/corrects for PV angle and orientation. Made by Artneverho.
        httpResponses = { 'NEDHourlyWind' }
    logging = {
        marker = 'NED-hourly-wind'
    data = {
        windAll = { initial = {} } -- NEW: store all hours for user variable export
        local idxWindForecast = 525      -- Managed counter (%)
        local nameUserVariable = 'NEDwindForecast'  --name of uservariable that stors the kwh data in json.
        local now = os.time()
        local from = os.date("%Y-%m-%d", now)
        local to   = os.date("%Y-%m-%d", now + 48 * 3600)
        local function nedLocalDateHour(ts)
            local t = os.time({
                year = tonumber(y),
                month = tonumber(m),
                day = tonumber(d),
                hour = tonumber(H),
                min = tonumber(M),
                sec = tonumber(S),
                isdst = nil
            }) + 3600
            return os.date("%Y-%m-%d", t), tonumber(os.date("%H", t))
            domoticz.data.windAll = {} -- clear previous export
            local url =
                baseURL ..
                "point=0" ..
                "&type=1" ..
                "&granularity=5" ..
                "&activity=1" ..
            domoticz.openURL({
                url = url,
                method = 'GET',
                callback = 'NEDHourlyWind',
                headers = {
        local todayDate  = os.date("%Y-%m-%d")
                domoticz.log('NED wind request failed', domoticz.LOG_ERROR)
                return
            -- reset visible counter
            domoticz.devices(idxWindForecast).updateCounter(0)
                if ts and perc then
                    -- --- Store for user variable export
                    table.insert(domoticz.data.windAll, { ts = ts, perc = perc })
                    -- Domoticz-safe timestamp
                        local t = os.time({
                            isdst=nil
                        }) + 3600
                    local date, hour = nedLocalDateHour(ts)
                    -- Existing device history update
                    local value = perc * 10000
                    domoticz.devices(idxWindForecast).updateHistory(dt, "0;" .. value)
                    if date == todayDate and hour == currentHour then
                        domoticz.devices(idxWindForecast).update(0, string.format("%.1f", value))
                    domoticz.log(string.format("Hour %s wind perc=%.2f%%", dt:sub(12,13), perc * 100), domoticz.LOG_INFO)
            local out = {}
            for _, e in ipairs(domoticz.data.windAll) do
                table.insert(out, { ts = e.ts, perc = tonumber(string.format('%.4f', e.perc)) })
            domoticz.log('Stored NEDwindForecast ('..#out..' hourly entries, including tomorrow if available)', domoticz.LOG_INFO)
