Integrate Shelly Dimmer Gen3
marmachine
Domoticz version: 3.4834
Post by marmachine »
Suddenly it was released so i ordered a couple to replace my older (Gen1 and 2) ones that are sort of dying (dropping connection or not responding at all).
Not knowing what i was getting into, i found out that the device isn't as easy as it was before.... so i thought, the functionality "one-button-dimming" for example is kinda hidden, but still there... easily overlooked. I hate that! :lol: :oops:
Anyway, as much as it sounds like a developed new thing, freedom and all what we've ever wanted, my intention is to simply replace the old dimmers. Shelly claims compatibility, but it seems everything but compatible with Domoticz right now.
Maybe someone can point me to some helpfull information since Shelly helpdesk is kinda sad to be honest. I need to integrate the device into domoticz, using MQTT like it worked out of the box in the old days. How do i get it into Domoticz?
I just hope there is some script available to make it work like before, set and go... ?
Last edited by marmachine on Saturday 01 February 2025 15:57, edited 1 time in total.
Re: Integrate Shelly Dimmer Gen3
Use the Shelly teacher script. viewtopic.php?p=322662#p322662
It is not completely gen 3 compatible yet but the can be easily added.
marmachine
Just installed shellyteacher4domo and ran it... this first resulted in an error for this new device.
So i've created a new entry for the tag [shellydimmerg3] in mqtt_templates_gen2.txt so that it's recognized.
This specific file (mqtt_templates_gen2.txt) inside shellyteacher, takes care of MQTT mapping to allow applications to recognize the unknown hardware.
I am quite stuck with the syntax because i understand *shit* of what i see there... as it is a Gen3 device, things might be different and i don't know how to translate the device payload to a working template. Anyone with some knowlegde on that?
Raised an issue on Github : https://github.com/enesbcs/shellyteacher4domo/issues/65
P.s.: I did manage to get my Shelly 1 Gen 3 to work... the dimmer is just a different thing :|
Fdmekinabo
Post by Fdmekinabo »
I disabled MQTT on Shellies and I am using this script to control them and read the state. Here is an example for two devices, Shelly Dimmer Gen3 and Shelly Plus RGBW PM. The script needs to be updated with a fixed IP of the device, the actual Domoticz name or IDX and if necessary channel number. You can also paste it into an AI and add in the same way other devices.
        devices = { 'MYDIMMER3', 'MYRGBWDIMMER3' },
        timer = { 'every minute' },
        httpResponses = { 'shellyDimStatus', 'shellyRGBWStatus' }
    execute = function(domoticz, triggeredItem)
        local shellies = {
                idx = 2210,
                ip = '192.168.1.126',
                lightId = 0,
                statusCallback = 'shellyDimStatus'
                idx = 2211,
                ip = '192.168.1.150',
                lightId = 3,
                statusCallback = 'shellyRGBWStatus'
        if triggeredItem.isDevice then
            for _, shelly in ipairs(shellies) do
                if triggeredItem.idx == shelly.idx then
                    local state = triggeredItem.state
                    local level = triggeredItem.level or 0
                    local url
                    if state == 'Off' then
                        url = string.format('http://%s/rpc/Light.Set?id=%d&on=false', shelly.ip, shelly.lightId)
                        url = string.format('http://%s/rpc/Light.Set?id=%d&on=true&brightness=%d', shelly.ip, shelly.lightId, level)
                    os.execute('curl -s "' .. url .. '"')
                    break
        elseif triggeredItem.isTimer then
                domoticz.openURL({
                    url = string.format('http://%s/rpc/Light.GetStatus?id=%d', shelly.ip, shelly.lightId),
                    method = 'GET',
                    callback = shelly.statusCallback
        elseif triggeredItem.isHTTPResponse and triggeredItem.ok then
                if triggeredItem.callback == shelly.statusCallback then
                    local data = triggeredItem.json
                    local dev = domoticz.devices(shelly.idx)
                    if data.output == true then
                        if dev.level ~= data.brightness then
                            dev.dimTo(data.brightness)
                        if dev.active then
                            dev.switchOff()
                    break
Edit waltervl: make code a code block
