Fresh install Domoticz
Posted: Wednesday 22 January 2025 23:40
Hello again, it has been some time since i posted on the forum. Domoticz has been running smootly and not much changed in my home automation system so not much need for me to change/update Domoticz. As a result my Domoticz knowledge has become a bit “rusty”
Time to brush up my knowledge again as i plan to upgrade my Raspberry pi 3 to a 4Mb pi 4.
Now i am looking for advise for the type of install that would best fit my needs (and others?) primarily as the Wiki page seems somewhat outdated.
I am using Domoticz with RFC, Zwave and Zigbee (Zigbee for Domoticz). I am upgrading many RFX devices to Zigbee but i will probably still keep using some RFX devices on my new pi.
My question is what is currently the “best” type of install to use? (Since starting with Domoticz many years ago i always used the “easy” install from the Wiki)
Is the easy still the recommended one or should i go for a docker installation or something else.
(I read somewhere the docker install makes the system less flexible)
Also which zigbee implementation to use? Currently i use ZigbeeforDomoticz (Silicon Labs EZSP coordinator) but Zigbee2MQTT seems to be compatible with more devices.
For Zwave i understand i should move from OpenZwave to ZWaveJS2MQTT.
Also if there will be a Matter implementation in Domoticz, which type of install is most likely to be compatible with such an implementation.
Who can and wants to share their thoughts and advise.
Thanks a bunch
Thanks a bunch
