Controlling the heater from photovoltaic production
Posted: Sunday 19 January 2025 16:12
Hello
I would like to use the overproduction from photovoltaics that goes into the power grid, and in Poland it is not very profitable to send energy from photovoltaic panels to the power grid.
I installed 3x PZEM 004T from Tasmota on the main wires supplying the house, so I can see the energy that devices in the house are drawing.
I installed 3x PZEM 004T from Tasmota on the main wires from the inverter / converter, thanks to which I have readings and the W gives the inverter / Inverter.
I installed a heater in the tank, which is switched on by the EARU 63A module - currently switched on using blockly if the value on the PZEM 004T mounted on the inverter exceeds 2000.
It is known that on the circuits in the house there are different energy consumptions, sometimes higher, sometimes lower, charging from the sun, I would also like some script that would see the difference between the readings and in the case of free W turn on the heater.
Unfortunately, I have no indication from the inverter of the energy that is fed into the power grid.
@psubiaco please watch it in your free time.
