I did purchased ZTRV-801 https://www.moestech.com/blogs/news/ztrv-801 thermostats that are working fine but...
The refresh rate is really poor, it can take several hours to send data to the coordinator.
The only way to refresh data is to send a command to the valve, the valve will then make-up and respond.
Is there a smarter way getting regular updates ? Firmware update, reporting interval rate?
Thanks !
MOES ZTRV-801 thermostat
- Domoticz version: 2026.3
Re: MOES ZTRV-801 thermostat
Check the zigbee2mqtt GitHub for tips...
Patricen
- Domoticz version: Beta rel
Thanks !
