Sent CPU temperature from Proxmox to Domoticz
Posted: Friday 10 January 2025 22:31
With help of google I made a Python scrip for sending my server CPU temperature running PROXMOX VM to a virtual sensor
The temperature is updated in the file : /sys/class/thermal/thermal_zone0/temp
Only reading the first 2 digits on the first line.
Send this value to a virtual sensor in Domoticz every 5 minutes.
Note: This script has to run on the Proxmox server itself !! Not on the OS Domoticz runs on !!!!!
import os
import re
import requests
import time
import sys
while True:
file = open('/sys/class/thermal/thermal_zone0/temp', 'r')
first_line = file.readline(2).strip()
# Close the file
file.close()
domoticzserver = "192.168.178.37:8080"
idx_temp = "373" # Put youre own IDX here of the virtual sensor
val_temp = first_line
res = requests.get(
"http://"
+ domoticzserver
+ "/json.htm?type=command¶m=udevice&idx="
+ idx_temp
+ "&nvalue=0&svalue="
+ val_temp
time.sleep(300) # send every 5 minutes
