dummy device type "electricity usage" does not seem to calculate costs
Posted: Wednesday 08 January 2025 20:35
dummy device type "electricity usage" does not seem to calculate costs, see legenda in screenhot below of fresh made device
Open source Home Automation System
https://forum.domoticz.com/
active = true,
logging = {
--level = domoticz.LOG_DEBUG, -- comment to use the dzVents global logging setting
marker = 'dzOpenEvseKwh'
devices = {
'OpenEVSE - Amps'
--,'triggerhulp'
data = {
vorigSec = { initial = 0 },
execute = function(dz, item, timer)
if dz.data.vorigSec > 0 then -- niet de eerste keer / data leeg?
secNu = os.time()
secVerstreken = secNu - dz.data.vorigSec
stroom= dz.devices('OpenEVSE - Amps').current
voltage = dz.devices('tuyaPlug2AircoOverloopVolt').voltage
vermogen= stroom * voltage --power [Watt]
energie=vermogen * secVerstreken/3600 -- energy [Wh]
dz.devices ('openEvseKwh').updateElectricity (vermogen, energie) --updateElectricity(power, energy): Function. Supports command options.
dz.log ('sec: '..secVerstreken, dz.LOG_INFO)
dz.log ('stroom: '..stroom, dz.LOG_INFO)
dz.log ('voltage: '..voltage, dz.LOG_INFO)
dz.log ('vermogen [Watt]: '..vermogen, dz.LOG_INFO)
dz.log ('energie [kWh]: '..energie, dz.LOG_INFO)
dz.log ('geen realistische tijdwaarde / eerste keer? ', dz.LOG_INFO)
dz.data.vorigSec = secNu
active = true,
logging = {
marker = 'dzMitsubishiAircoKwh'
devices = {
'MitsubishiAircoControl current power'
--,'triggerhulp'
data = {
secNu = os.time()
stroom= dz.devices('MitsubishiAircoControl current power').current
voltage = dz.devices('tuyaPlug2AircoOverloopVolt').voltage --better than 230 solid value
vermogen= stroom * voltage --power [W]
oudeEnergie = dz.devices('mitsubishiAircoKwh').WhTotal
energie=vermogen * secVerstreken/3600 --[Wh]
dz.devices ('mitsubishiAircoKwh').updateElectricity (vermogen, energie + oudeEnergie) --updateElectricity(power, energy): Function. Supports command options.
--dz.devices ('mitsubishiAircoKwh').updateEnergy(vermogen) --updateEnergy(energy): Function. In Watt.
dz.log ('oudeEnergie [Wh]: '..oudeEnergie, dz.LOG_INFO)
dz.log ('energie [Wh]: '..energie, dz.LOG_INFO)
