dummy device type "electricity usage" does not seem to calculate costs
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
renerene
Post by renerene »
dummy device type "electricity usage" does not seem to calculate costs, see legenda in screenhot below of fresh made device
Domoticz version: 2024.7
Re: dummy device type "electricity usage" does not seem to calculate costs
That is correct as it does not measure kWh but only Watt.
It is by the way not advised to use this type of device as it also has no history. Better use the Electricity (instant and counter) sensor as indicated in the wiki
https://wiki.domoticz.com/Dummy_for_vir ... lectricity
renerene
Post by renerene »
thanks for the explanation Walter.
(my excuse: the advice to not use this device was not on on the dzVents wiki)
For this incidently user it is a bit overwelming and confusing.I was using you "Electricity (instant and counter) sensor" before, to monitor my airco that only reports current [amps]
A bit of topic is here my script to fill the "Electricity (instant and counter) sensor" Maybe you could be so kind to have a look?
the problem: it resulted in some negative values in the log for energy bars
	active = true,
	logging = {
		--level = domoticz.LOG_DEBUG, -- comment to use the dzVents global logging setting
		marker = 'dzOpenEvseKwh'
	   devices = {
	       'OpenEVSE - Amps'
	      --,'triggerhulp'
	data = {
        vorigSec = { initial = 0 },
    execute = function(dz, item, timer)
        if dz.data.vorigSec > 0 then -- niet de eerste keer / data leeg?
            secNu = os.time()
            secVerstreken = secNu - dz.data.vorigSec
	        stroom= dz.devices('OpenEVSE - Amps').current
            voltage = dz.devices('tuyaPlug2AircoOverloopVolt').voltage
            vermogen= stroom * voltage --power [Watt]
            energie=vermogen * secVerstreken/3600 -- energy [Wh]
            dz.devices ('openEvseKwh').updateElectricity (vermogen, energie) --updateElectricity(power, energy): Function. Supports command options.
            dz.log ('sec: '..secVerstreken, dz.LOG_INFO)
            dz.log ('stroom: '..stroom, dz.LOG_INFO)
            dz.log ('voltage: '..voltage, dz.LOG_INFO)
            dz.log ('vermogen [Watt]: '..vermogen, dz.LOG_INFO)
            dz.log ('energie [kWh]: '..energie, dz.LOG_INFO)
            dz.log ('geen realistische tijdwaarde / eerste keer? ', dz.LOG_INFO)
        dz.data.vorigSec = secNu
renerene
Post by renerene »
to answer my own post: problem solved, you need to pass TOTAL Wh, not delta Wh
correct script to convert Amps to power:
	active = true,
	logging = {
		marker = 'dzMitsubishiAircoKwh'
	   devices = {
	       'MitsubishiAircoControl current power'
	      --,'triggerhulp'
	data = {
            secNu = os.time()
	        stroom= dz.devices('MitsubishiAircoControl current power').current
            voltage = dz.devices('tuyaPlug2AircoOverloopVolt').voltage --better than 230 solid value
            vermogen= stroom * voltage --power [W]
            oudeEnergie = dz.devices('mitsubishiAircoKwh').WhTotal
            energie=vermogen * secVerstreken/3600 --[Wh]
            dz.devices ('mitsubishiAircoKwh').updateElectricity (vermogen, energie + oudeEnergie) --updateElectricity(power, energy): Function. Supports command options.
            --dz.devices ('mitsubishiAircoKwh').updateEnergy(vermogen) --updateEnergy(energy): Function. In Watt.
            dz.log ('oudeEnergie [Wh]: '..oudeEnergie, dz.LOG_INFO)
            dz.log ('energie [Wh]: '..energie, dz.LOG_INFO)
