Doubt with sensor update (the egg or the chicken)
jpradoar
Domoticz version: stable
Post by jpradoar »
Hi all, Jtan here.
Im working with esp8266 and Im creating my own firmware for my home devices. Working on it I found a "problem" (the egg or the chicken).
Case: If you create a sensor (like light/switch) you can create it manually on domoticz and after that the sensor can be updated sending a mqtt message but you need to know the idx
... {"idx" : 7,  "nvalue" : 0,  "svalue" : "0"}  -t 'domoticz/in'
From here all its ok, but the problem comes when you deplpy a new instance of domocitz, you dont have any idx created and you have old "sensor" with old idx. Obiously you can not create a "custom idx", for this reson I have been migrating to "auto-discovery"
Why? because in real life the first time that I connect a device (phisical device) I dont know what idx correspond.
of course... I created manually the device and after that, put that idx on my new physical device, but Im trying to create a little more "professional" procedure.
To test the "AD" I send MQTT messages "auto-discovery-message" and create virtual thing with my unique ID (not idx, this idx will be created automatically by domoticz).
mosquitto_pub  -u admin -P admin -h 127.0.0.1 -p 1883 \
-m '{"name": "ligth99", "command_topic": "999/set", "state_topic": "999/state", "unique_id": "999", "payload_on": "ON", "payload_off": "OFF", "retain": true }' -t 'homeassistant/binary_sensor/999/config'
from here all ok again, but the problem is when I try to update "light" from domoticz UI the UI dont "send" appropriate message and then to turn-on or turn-off the light I need to send
 mosquitto_pub  -u admin -P admin -h 127.0.0.1 -p 1883 -m 'ON' -t  999/set
This is a problem because the uniq "trigger" is "ON or "OFF" and if a need send more information like battery or something similar I cant.
Im trying to avoid using idx, because the objetive is manage sensors with an CustomID that i know.
Using this mechanism Im sure that my device is <xxxxx> is uniq and no need to "pre-configure" domoticz and then can send messaje like sensor/<xxxx>/state.
I saw some interesting information in this topic viewtopic.php?t=38403&sid=80dd06c4f7196 ... 7ce3cfc4dc but I don't understand if i'm doing something wrong or my concept of auto-discovery is not ok.
Then I made a "hack" changing custom command_topic and state_topic to domoticz/in but I have the same problem, can't update another information.
-m '{"unique_id": "001589", "name": "modulo_001589", "command_topic": "domoticz/in", "state_topic": "domoticz/in", "payload_on": "001589_on", "payload_off": "001589_off", "retain": true}' \
-t 'homeassistant/switch/8/config'
My idea is created switches/Lights (for example) automatically and after that send status update directly to ID (no idx). But the senros must be upadted (status) via Domoticz UI or MQTT message
...I'm trying to avoid create manually sensors or any manual human action.
Manual creation
This is an example, the topic domoticz/in has a "format" that can be send a lot of information like
{"command": "setcolbrightnessvalue", "idx": 2450, "hue": 274, "brightness": 40, "iswhite": false, "Batery" : 100 }
With AD Creation (self creation)
but when a send message to 999/set I dont have this "format"
I hope that can understand the idea and problem
another doc that I saw: https://wiki.domoticz.com/MQTT#Sending_a_Switch_Command
Thanks in advance!!!
Re: Doubt with sensor update (the egg or the chicken)
I do not understand your question completely.
So does the MQTT AD config topic create a device ion Domoticz?
Can you switch the device in Domoticz from MQTT with ON/OFF payload?
You can also look at the ESPHome library as that integrates MQTT AD and test how it configures the MQTT AD config, set and state topics for a specific device type (eg binary sensor). https://esphome.io/components/mqtt.html ... -assistant
FlyingDomotic
Post by FlyingDomotic »
You may have a look at MqttMapper (https://github.com/FlyingDomotic/domoti ... per-plugin).
Giving a definition in a json file, it'll create a Domoticz device, and will update it each time you'll change data in MQTT. You may also change device in Domoticz, and forward the change in MQTT, either in the same topic, or another one. You don't have to specify IDX somewhere.
Should you have multiple Domoticz instances, just duplicate (part of) json configuration file.
