Error: zigbee: There are alreday Widget
Posted: Monday 06 January 2025 19:50
by tulips
Error: zigbee: There are alreday Widget(s) associated for this objet {'Version': '3', 'ZDeviceName': '
Had a ssd crash and try to get my old backup running.
Anyone know how to solve it? :?
Re: Error: zigbee: There are alreday Widget
Posted: Monday 06 January 2025 23:46
by waltervl
What zigbee integration are you running?
Posted: Tuesday 07 January 2025 19:15
by tulips
ZigBeeforDomoticZ plugin Version 7.1.018
Posted: Tuesday 07 January 2025 19:19
by tulips
Allot of error messages in the log
2025-01-07 19:17:56.111 Status: zigbee: [1] NEW OBJECT: 0b20 Model Name: TS0001
2025-01-07 19:17:56.111 Status: zigbee: [1] NEW OBJECT: 0b20 Manufacturer Name: _TZ3210_j4pdtz9v
2025-01-07 19:17:56.111 Error: zigbee: There are alreday Widget(s) associated for this objet {'Version': '3', 'ZDeviceName': '', 'Status': '8043', 'SQN': 'f5', 'Ep': {'01': {'0000': {'0007': 3, 'fffe': 0, '0004': '_TZ3210_j4pdtz9v', '0000': 3, '0001': 83, '0005': 'TS0001', 'ffe2': 54, 'ffe4': 0, 'ffdf': '\x18\x0f/\x11\x0f/\x11'}, '0004': {}, '0005': {}, '0006': {'0000': '00'}, '0019': {}, 'e000': {}, 'Type': 'Switch'}}, 'Heartbeat': '7198', 'RIA': '1', 'LQI': 32, 'Battery': {}, 'Model': 'TS0001', 'ForceAckCommands': [], 'MacCapa': '80', 'IEEE': 'a4c1387463d0405b', 'Type': '', 'ProfileID': '0104', 'ZDeviceID': '0000', 'App Version': 83, 'Attributes List': {}, 'DeviceType': 'RFD', 'HW Version': '', 'Last Cmds': [], 'LogicalType': 'End Device', 'Manufacturer': '1141', 'Manufacturer Name': '_TZ3210_j4pdtz9v', 'NbEp': '1', 'PowerSource': 'Battery', 'ReadAttributes': {'Ep': {'01': {'0000': {'TimeStamp': 1736267866, 'iSQN': {'0004': '00', '0000': '00', '0001': '00', '0005': '00', '0007': '00', 'fffe': '00'}, 'Attributes': {'0004': '00', '0000': '00', '0001': '00', '0005': '00', '0007': '00', 'fffe': '00', 'ffe2': '00', 'ffe4': '00', 'ffdf': '00'}, 'ZigateRequest': {}}, '0006': {'TimeStamp': 1736273860, 'iSQN': {}, 'Attributes': {'0000': '00'}, 'ZigateRequest': {}}}}}, 'ReceiveOnIdle': 'Off', 'Stack Version': '', 'Stamp': {'time': 1736273860.4961917, 'Time': '2025-01-07 19:17:40', 'MsgType': '8102', 'LastSeen': 1736273860}, 'ZCL Version': 3, 'Health': 'Live', 'Capability': ['Reduced-Function Device', 'Standard security', 'NwkAddr should be allocated'], 'ZCLSQN': '00', 'ZDPSQN': '03', 'ErrorManagement': 0, 'PairingInProgress': True, 'ZCL-IN-SQN': {'ef00': 'c0', '0000': 'de', '000a': 'f0'}, 'RollingLQI': [47, 47, 40, 40, 40, 40, 40, 36, 36, 32, 32], 'ConfigSource': 'DeviceConf', 'Param': {'PowerOnAfterOffOn': 2}, 'Epv2': {'01': {'ProfileID': '0104', 'ZDeviceID': '0000', 'ClusterIn': {'0006': {}, 'ef00': {}, '0000': {}}, 'ClusterOut': {'0019': {}, '000a': {}}}}, 'ReqEpv2': {'01': 1736237790.12027}, '_rawNodeDescriptor': '1141004200422a000080424002', 'Max Buffer Size': '42', 'Max Rx': '0042', 'Max Tx': '0042', 'macapa': '80', 'bitfield': '4002', 'server_mask': '2a00', 'descriptor_capability': '00', 'ZDeviceVersion': '0001', 'SQN_000a': 'f0', 'Tuya': {'UnknowDp_0x65_Dt_0x04': '00', 'UnknowDp_0x69_Dt_0x02': '00000010'}} in Domoticz
Posted: Tuesday 07 January 2025 19:47
by waltervl
Are there devices in the device list (Menu Setup - devices) for this node TS0001 _TZ3210_j4pdtz9v, IEEE': 'a4c1387463d0405b'? Search in the device list for the IEEE iD to check. If so, delete them from Domoticz.
It seems the Domoticz database currently has more info than the plugin config.
