Domoticz in Docker
Posted: Wednesday 01 January 2025 17:13
first of all Happy New Year!
after a lot of trail and error our Domoticz in Docker is working, but now i'm struggling with some scripts:
Our tuya script is not working, it cant find its files:
this tuyaha is installed on the system and is working in normal installation of domoticz, but in docker it does not...
After installing the "pip install tuyaha" inside the domoticz docker console it is working, but does not survive an reboot/restart.
the same for our heos script, it is also not working anymore:
the heos_player is installed in the usr/local/bin directory, but docker (domoticz) does not seems to see it.
After installing the "pip install heospy" inside the domoticz docker console it is working,
but after restart/update the container its gone and does not work anymore and need to install pip heospy again.
Console:
Can someone help me with this?
Thanks,
Barry
2025-01-01 17:14:57.850 Status: Tuya: Started.
2025-01-01 17:14:58.003 Error: Tuya: (tuya) failed to load 'plugin.py', Python Path used was '/opt/domoticz/userdata/plugins/Domoticz-TUYA-Plugin/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2025-01-01 17:14:58.021 Error: Tuya: Traceback (most recent call last):
2025-01-01 17:14:58.021 Error: Tuya: File "/opt/domoticz/userdata/plugins/Domoticz-TUYA-Plugin/plugin.py", line 65, in <module>
2025-01-01 17:14:58.021 Error: Tuya: import tuyaha
2025-01-01 17:14:58.021 Error: Tuya: ModuleNotFoundError: No module named 'tuyaha'
/opt/domoticz/userdata/scripts/barry/bparadise.sh: 1: /usr/local/bin/heos_player: not found
/opt/domoticz/userdata/scripts/barry/bparadise.sh: 2: /usr/local/bin/heos_player: not found
/opt/domoticz/userdata/scripts/barry/bparadise.sh: 3: /usr/local/bin/heos_player: not found
Console:
root@mainserver:/opt/domoticz# pip3 install tuyaha
Collecting tuyaha
Downloading tuyaha-0.0.11-py3-none-any.whl (13 kB)
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (from tuyaha) (2.32.3)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests->tuyaha) (3.10)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests->tuyaha) (2.3.0)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests->tuyaha) (2024.12.14)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests->tuyaha) (3.4.1)
Installing collected packages: tuyaha
Successfully installed tuyaha-0.0.11
root@mainserver:/opt/domoticz# pip3 install heospy
Collecting heospy
Downloading heospy-0.2.7-py3-none-any.whl (16 kB)
Collecting six
Downloading six-1.17.0-py2.py3-none-any.whl (11 kB)
Collecting future
Downloading future-1.0.0-py3-none-any.whl (491 kB)
|████████████████████████████████| 491 kB 7.8 MB/s
Installing collected packages: six, future, heospy
Successfully installed future-1.0.0 heospy-0.2.7 six-1.17.0
Thanks,
Barry
