Dutch dynamic energy prices bar chart in Custom menu
Posted: Tuesday 31 December 2024 13:16
The Enever plugin made me think about making a bar chart to show dynamic electricity prices for today and tomorrow.
Preparation
- In Setup->Users->your name or admin activate the Custom menu and save
- get yourself a token from enever to be able to access the API
- prepare your RPI (example lightttpd) because you need to be able to update files on /var/www/html
- go /var/www/html
- copy these 2 dzVents scripts
- go /var/www/html and write the html that collects data and displays the data in a graph. Name of the file energyprices.html (omit the underscore from the other html to not mix up both files)
- test in your browser http://your_LAN_IP/energyprices.html
- write a file in /home/pi/domoticz/www/templates named energy_prices.html
restart domoticz
- back in domoticz in your browser refresh with Ctrl-F5 to clear the buffer
PS In my situation it works as expected in Firefox and in Edge it doesn't. (help and advice appreciated)
Preparation
- go /var/www/html
touch Energy_Prices_Today.csv
touch Energy_Prices_Tomorrow.csv
sudo chmod 664 /var/www/html/Energy_Prices_Today.csv
sudo chmod 664 /var/www/html/Energy_Prices_Tomorrow.csv
sudo chown www-data:www-data /var/www/html/Energy_Prices_Today.csv
sudo chown www-data:www-data /var/www/html/Energy_Prices_Tomorrow.csv
timer = { 'at 00:05' }, -- a new day yesterday, is an old day now
httpResponses = { 'EnergyPricesTodayReceived' }
logging = {
level = domoticz.LOG_INFO,
marker = 'EnergyPricesToday'
local energyProviders = {
--prijs = "Beurs",
AA = "Atoom Alliantie",
AIP = "All in power",
ANWB = "ANWB Energie",
BE = "Budget Energie",
EE = "EasyEnergy",
EN = "Eneco",
EVO = "Energie van Ons",
EZ = "Energy Zero",
FR = "Frank Energie",
GSL = "Groenestroom Lokaal",
MDE = "Mijndomein Energie",
NE = "NextEnergy",
TI = "Tibber",
VDB = "Vandebron",
VON = "Vrij op naam",
WE = "Wout Energie",
ZG = "ZonderGas",
ZP = "Zonneplan"
if (item.isTimer) then
domoticz.log('Starting energy prices update', domoticz.LOG_INFO)
-- Doe het API verzoek
domoticz.openURL({
url = 'https://enever.nl/api/stroomprijs_vandaag.php?token='<your_enever_token>',
method = 'GET',
callback = 'EnergyPricesTodayReceived'
elseif (item.isHTTPResponse) then
domoticz.log('Processing HTTP response', domoticz.LOG_INFO)
if (item.ok) then
local data = item.json
if data.status == "true" then
-- Open het CSV-bestand om te schrijven
local file = io.open("/var/www/html/Energy_Prices_Today.csv", "w")
if file then
-- Schrijf de header naar het bestand
file:write("Afkorting,Provider,00:00,01:00,02:00,03:00,04:00,05:00,06:00,07:00,08:00,09:00,10:00,11:00,12:00,13:00,14:00,15:00,16:00,17:00,18:00,19:00,20:00,21:00,22:00,23:00\n")
-- Schrijf de data voor elke provider
for provider, name in pairs(energyProviders) do
file:write(provider .. "," .. name)
for _, hour in ipairs(data.data) do
file:write(string.format(",%s", hour["prijs" .. provider]))
file:write("\n")
file:close()
domoticz.log('Energy prices saved to Energy_Prices_Today.csv', domoticz.LOG_INFO)
domoticz.log('ERROR: Could not open Energy_Prices_Today.csv for writing', domoticz.LOG_ERROR)
domoticz.log('ERROR: Invalid response from API', domoticz.LOG_ERROR)
domoticz.log('ERROR: HTTP request failed', domoticz.LOG_ERROR)
timer = { 'every hour between 14:00 and 17:00', 'at 00:04' }, -- new prices arrive in the afternoon of the preceding day
-- after midnight the tomorrow day needs to change
httpResponses = { 'EnergyPricesTomorrowReceived' }
logging = {
marker = 'EnergyPricesTomorrow'
--prijs = "Beurs",
EE = "EasyEnergy",
EN = "Eneco",
EZ = "Energy Zero",
NE = "NextEnergy",
TI = "Tibber",
VDB = "Vandebron",
ZG = "ZonderGas",
ZP = "Zonneplan"
-- Huidige tijd in seconden sinds epoch (1 januari 1970)
local currentTime = os.time()
-- Tijd in seconden voor één dag (24 uur * 60 minuten * 60 seconden)
local oneDay = 24 * 60 * 60
-- Tijd in seconden voor morgen
local tomorrowTime = currentTime + oneDay
-- Datum van morgen in het gewenste formaat
local tomorrowDate = os.date("%d-%m-%Y %H:%M", tomorrowTime)
print("Datum van morgen: " .. tomorrowDate)
domoticz.log('Starting energy prices tomorrow update', domoticz.LOG_INFO)
domoticz.openURL({
url = 'https://enever.nl/api/stroomprijs_morgen.php?token=<your_enever_token',
method = 'GET',
callback = 'EnergyPricesTomorrowReceived'
if (item.ok) then
local file = io.open("/var/www/html/Energy_Prices_Tomorrow.csv", "w")
if file then
file:write("\n")
file:close()
domoticz.log('Energy prices saved to Energy_Prices_Tomorrow.csv', domoticz.LOG_INFO)
domoticz.log('ERROR: Could not open Energy_Prices_Tomorrow.csv for writing', domoticz.LOG_INFO)
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Energy Prices Staafdiagram</title>
<style>
body {
font-family: Arial, sans-serif;
.container {
width: 80%;
margin: auto;
text-align: center;
.dropdown {
margin-bottom: 20px;
</style>
<!-- Verwijzing naar de Chart.js bibliotheek via een CDN -->
<script src="https://cdn.jsdelivr.net/npm/chart.js"></script>
</head>
<body>
<div class="container">
<h1>Energy Prices Staafdiagram</h1>
<div class="dropdown">
<label for="providerSelect">Kies een provider:</label>
<select id="providerSelect">
<option value="EN">Eneco</option>
<option value="FR">Frank Energie</option>
<option value="EVO">Energie van Ons</option>
<option value="TI">Tibber</option>
<option value="GSL">Groenestroom Lokaal</option>
<option value="ANWB">ANWB Energie</option>
<option value="ZG">ZonderGas</option>
<option value="ZP">Zonneplan</option>
<option value="EZ">Energy Zero</option>
<option value="VON">Vrij op naam</option>
<option value="EE">EasyEnergy</option>
<option value="MDE">Mijndomein Energie</option>
<option value="BE">Budget Energie</option>
<option value="AA">Atoom Alliantie</option>
<option value="WE">Wout Energie</option>
<option value="VDB">Vandebron</option>
<option value="NE">NextEnergy</option>
<option value="AIP">All in power</option>
</select>
</div>
<canvas id="energyPricesChart" width="800" height="400"></canvas>
<p id="dates"></p>
</div>
<script>
document.addEventListener('DOMContentLoaded', function() {
const providerSelect = document.getElementById('providerSelect');
const chartCanvas = document.getElementById('energyPricesChart');
const datesElement = document.getElementById('dates');
let chart;
function fetchData(provider) {
fetch('/Energy_Prices_Today.csv')
.then(response => response.text())
.then(todayData => {
console.log('Today Data:', todayData); // Controleer de opgehaalde data
fetch('/Energy_Prices_Tomorrow.csv')
.then(tomorrowData => {
console.log('Tomorrow Data:', tomorrowData); // Controleer de opgehaalde data
const todayPrices = parseCSV(todayData, provider);
const tomorrowPrices = parseCSV(tomorrowData, provider);
console.log('Today Prices:', todayPrices); // Controleer de verwerkte data
console.log('Tomorrow Prices:', tomorrowPrices); // Controleer de verwerkte data
const labels = generateLabels();
const combinedPrices = todayPrices.concat(tomorrowPrices);
const todayDate = new Date().toLocaleDateString();
const tomorrowDate = new Date(Date.now() + 86400000).toLocaleDateString();
datesElement.textContent = `Vandaag: ${todayDate}, Morgen: ${tomorrowDate}`;
if (chart) {
chart.destroy();
chart = new Chart(chartCanvas, {
type: 'bar',
data: {
labels: labels,
datasets: [{
label: provider,
data: combinedPrices,
backgroundColor: 'rgba(75, 192, 192, 0.2)',
borderColor: 'rgba(75, 192, 192, 1)',
borderWidth: 1
options: {
scales: {
x: {
title: {
display: true,
text: 'Tijd'
ticks: {
color: 'black' // Kleur van de labels op de x-as
y: {
beginAtZero: true,
title: {
display: true,
text: 'Prijs'
ticks: {
color: 'black' // Kleur van de labels op de y-as
function parseCSV(data, provider) {
const lines = data.split('\n');
const result = [];
const providerIndex = lines[0].split(',').indexOf(provider);
for (let i = 1; i < lines.length; i++) {
const columns = lines[i].split(',');
if (columns[0] === provider) {
for (let j = 2; j < columns.length; j++) {
result.push(parseFloat(columns[j]));
break;
return result;
function generateLabels() {
const labels = [];
for (let i = 0; i < 24; i++) {
labels.push(i.toString().padStart(2, '0') + ':00');
return labels.concat(labels);
providerSelect.addEventListener('change', function() {
fetchData(providerSelect.value);
</script>
</body>
</html>
<IFRAME SRC="http://192.168.2.104/energyprices.html" height="800" width="100%"></IFRAME>Code: Select all
sudo service domoticz restartPS In my situation it works as expected in Firefox and in Edge it doesn't. (help and advice appreciated)
