I am running DZ in docker for some time now and no problems.
I was looking at the FW of my receiver and wanted to update to the latest one.
Am I going crazy or is there no option to update the FW of the RFXCOM device in DZ Docker ?
Update FW of RFX433E in Docker
wvries
- Domoticz version: latest B
- Screenshot 2024-12-29 at 16.35.30.png (183.93 KiB) Viewed 4657 times
- Screenshot 2024-12-29 at 16.35.21.png (163.41 KiB) Viewed 4657 times
- gizmocuz
Re: Update FW of RFX433E in Docker
Firmware update option has been removed on request as this was not working 100% and could cause some dangerous issues.
Therefor you just need to update via the RFXFlash application
wvries
Thanks for the quick answer...
will dig up an old rpi and just install a copy of DZ to do the upgrade there..
- Domoticz version: 2026.3
Seems you are drawing the wrong conclusion here.... Updating firmware by Domoticz can cause dangerous issues (brick?)!!wvries wrote: Sunday 29 December 2024 17:31 Thanks for the quick answer...
PieterS
- Domoticz version: 2024.7
As far as I know:
After downloading the manager to a computer, upgrading the firmware and configuring is possible if you connect the device to a laptop.
Saves time I guess
Saves time I guess
Synology with Domoticz build (V2024.7) in Docker
wvries
Would be, but I have either Linux or MacOS, so no windows....PieterS wrote: Sunday 29 December 2024 19:48 As far as I know:
Saves time I guess![]()
And windows emulator on Mac is not working for this (tried and failed)
So just install a quick DZ on an older RPI...
- gizmocuz
You should be able to use wine to run the RFXFlash utility.
You can also install a fresh windows copy and use it for free the first month(s)
For mac, you can use parallels
BartSr
- Domoticz version: V2024.7
interesting to know why to update.
can you inform?
can you inform?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
