Hi.
I am having a Zigbee Tuya movement sensor with reacts as expected. But once for a longer time there has been no movement the 'x,y and z' sensor in 'utilities' tab shows up in domoticz red colored. Same sensor has 'vibration and tilt'measureing which shows and stays normal in 'switches' tab.
Movement of sensor makes them sow correct value in correct color.
Is there a solution for this to keep them 'normal colored'?
TIA
Bart
zigbee2mqtt problem appearance 'XYZ movement sensor'
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- gizmocuz
Re: zigbee2mqtt problem appearance 'XYZ movement sensor'
That's just a sensor timeout and you don't have to worry about it
Thanks, also happens with a zwave device. But can I prevent this in a way?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2024.7
Change the timeout setting in menu setup - settings
thanks.
with knowledge as is now I understand meaning of that setting.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
investigating more setting options:
I tried timer plans but clicking on the pulldown has no effect.
Not longer in use?
Not longer in use?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- gizmocuz
Please don't mix topics, and sure timer plans are still working
