Version: 2024.7
Platform: Raspbian
I made a virtual alert sensor which shows when my doorbell is pressed using rfxcom - nodered - mqtt.
The sensor shows when de doorbell is pressed, but there is no history in the log.
Is there a way to solve this, or is there anonther way to display the history of alerts?
Log/ history of virtual alert sensor
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2022.1
Re: Log/ history of virtual alert sensor
I also have a doorbell via rfxcom, mine keeps a log in domoticz.
Why you using node red and mqtt for this?
You could link an action or send a notification from within the domoticz doorbell switch.
Stephan
Stephan
- Domoticz version: 2023.1+
You wrote in the title you use an alert sensor. (Ignore this message if this a false observation)
Alert sensor can be a bit tricky as you need to set the triangle color to ánd its a text sensor...
see : https://wiki.domoticz.com/Domoticz_API/ ... ert_sensor
the best way in lua is by setting : commandArray[#commandArray + 1]={['UpdateDevice']='IDX'..'|'..Alevel..'|'..textvalue
(Note on this that ON/OFF is a binary state and not a text value)
If your set an alert sensor by an on/off doorbell device it probably wont work as it is it cannot handle this.
In lua you can receive the signal from the on/off doorbell and set (with lua) the alert sensor as you wish with the above statement.
Hope this helps.....
As for notifications : test if it works on another sensor as expected and try to find the differences, maybe its not about the doorbel but about the general notification settings ?
