dzVents error in Domoticz (beta) in Docker
Posted: Saturday 28 December 2024 13:23
by BarryT
today i'm busy to try to get all my software in to docker (portainer) and want to stop with sd cards and stuff.
So far so good, and the first things works, but i'm struggling with some error messages in dzVents when using the first script:
2024-12-28 13:17:00.520 dzVents: Alarmering: : ------ Start internal script: 7-Alarmering-:, trigger: "every 1 minutes"
2024-12-28 13:17:00.521 dzVents: Debug: Alarmering-: : OpenURL: url = https://alarmeringen.nl/feeds/area/*.rss
2024-12-28 13:17:00.521 dzVents: Debug: Alarmering-: : OpenURL: method = GET
2024-12-28 13:17:00.521 dzVents: Debug: Alarmering-: : OpenURL: post data = nil
2024-12-28 13:17:00.521 dzVents: Debug: Alarmering-: : OpenURL: headers = nil
2024-12-28 13:17:00.521 dzVents: Debug: Alarmering-: : OpenURL: callback = alarmering
2024-12-28 13:17:00.522 dzVents: Alarmering: : ------ Finished 7-Alarmering-
2024-12-28 13:17:00.903 dzVents: Alarmering: : ------ Start internal script: 7-Alarmering-: HTTPResponse: "alarmering"
2024-12-28 13:17:00.945 dzVents: Debug: Alarmering-: : utcTimeDiffSeconds = 3600
2024-12-28 13:17:00.945 dzVents: Debug: Alarmering-: : Existing result_table: type = table
2024-12-28 13:17:00.945 dzVents: Debug: Alarmering-: : html file = /volumies/domoticz/www/templates/Alarmering.html
2024-12-28 13:17:00.946 Error: dzVents: Alarmering-: : An error occurred when calling event handler 7-Alarmering-
2024-12-28 13:17:00.946 Error: dzVents: Alarmering-: : ...ta/scripts/dzVents/generated_scripts/7-Alarmering.lua:83: attempt to index a nil value (local 'file')
All rights of the files are correct but the HTML page is not present nor it created..
Someone has an idea?
Re: dzVents error in Domoticz (beta) in Docker
Posted: Saturday 28 December 2024 15:12
by gizmocuz
I guess you mean you have created a script in the Domoticz Events Editor?
does /volumies/domoticz/www/templayes/Alarmering.html exists?
Did you mount any folders in the docker compose file? And places your html files in here?
Did you override the templates folder in the docker compose file?
For example, underneath your domoticz docker compose folder (I hope you created a folder for each compose project),
you can create a folder templates
then in your docker-compose.yml file you can mount this like
./templates:/opt/domoticz/www/templates
Now you script should be able to use /opt/domoticz/www/templates and see the file
Posted: Saturday 28 December 2024 15:39
by BarryT
gizmocuz wrote: Saturday 28 December 2024 15:12 I guess you mean you have created a script in the Domoticz Events Editor?
Hi Gizmo, thanks for answering!
That's correct.. It worked before with my normal installed domoticz, but in docker it doesnt work anymore.
Ofcourse the file is there (but if it wasnt its being created)
i'm using portainer as my main interface to do docker images and stacks (thas the easiest way to backup things, and its great).
I'm using this:
volumes:
  domoticz:
services:
  domoticz:
    image: domoticz/domoticz:beta
    container_name: domoticz
    restart: unless-stopped
#    network_mode: host
    #Pass devices to container
    #devices:
    # - /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AQ5NB7WR-if00-port0:/dev/ttyUSB0 #P1Monitor
    # - /dev/serial/by-id/usb-0658_0200-if00-port0:/dev/ttyACM0
    ports:
#     - 30:90 #HTTPS
       - 88:88/tcp #HTTP
#     - 6144:tcp #REMOTE DOMOTICZ
    volumes:
      - ./volumies/domoticz/:/opt/domoticz/userdata
#      - /volumies/domoticz/plugins/:/opt/domoticz/plugins
#      - /volumies/domoticz/www/templates:/opt/domoticz/www/templates
#      - /volumies/domoticz/www/styles:/opt/domoticz/www/styles
#      - /volumies/domoticz:/config
    environment:
      - /etc/timezone:/etc/timezone:ro
      - /etc/localtime:/etc/localtime:ro
      - TZ=Europe/Amsterdam
      - PUID=1005
      - PGID=1005
      - WWW_PORT=88
      - SSL_PORT=0
      - loglevel error,status
#      - LOG_PATH=/volumies/domoticz/domoticz.log
Posted: Saturday 28 December 2024 15:42
by BarryT
And this is the directory, also taken all files as user root with rwx rwx rwx, and this has worked before..
on some way it looks like it doesnt see the directory?
(Btw, i copied the file Alarmering from my working backup system, so that could not be the issue i guess)
Also i tried to delete it to see it is making a new one, but it does not..
Posted: Sunday 29 December 2024 12:28
by BarryT
Nobody? Still not working ;)
Re: dzVents error in Domoticz (beta) in Docker  [Solved]
Posted: Sunday 29 December 2024 13:52
by gizmocuz
If you remark the volume line, it is not working
Remove the '#'
and restart your container
And in your script use the path /opt/domoticz/www/templates
Posted: Sunday 29 December 2024 20:32
by BarryT
Ahh, it works!
Thanks Gizmocuz, for this answer!
I tought we had to use the mounted directory, but it is the /opt/ map i had to use in the script.. How stupid!
