Custom pages problem
Tukker
Domoticz version: 2023.2
Post by Tukker »
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Energy Prices Staafdiagram</title>
    <style>
        table {
            width: 100%;
            border-collapse: collapse;
        table, th, td {
            border: 1px solid black;
        th, td {
            padding: 8px;
            text-align: left;
        th {
            background-color: #4CAF50; /* Groene achtergrondkleur */
            color: white; /* Witte tekstkleur */
    </style>
    <!-- Verwijzing naar de Chart.js bibliotheek via een CDN -->
    <script src="https://cdn.jsdelivr.net/npm/chart.js"></script>
</head>
<body>
    <h1>Energy Prices Staafdiagram</h1>
    <canvas id="energyPricesChart" width="400" height="200"></canvas>
    <script>
        document.addEventListener('DOMContentLoaded', function() {
            const labels = ["00:00", "01:00", "02:00", "03:00", "04:00", "05:00", "06:00", "07:00", "08:00", "09:00", "10:00", "11:00", "12:00", "13:00", "14:00", "15:00", "16:00", "17:00", "18:00", "19:00", "20:00", "21:00", "22:00", "23:00"];
            const data = {
                labels: labels,
                datasets: [{
                    label: 'Eneco',
                    data: [0.278666, 0.270063, 0.269518, 0.263504, 0.264993, 0.270111, 0.27483, 0.29131, 0.299248, 0.298098, 0.292073, 0.283312, 0.285369, 0.280759, 0.287704, 0.301148, 0.310719, 0.321899, 0.322081, 0.319249, 0.311287, 0.301269, 0.304475, 0.296586],
                    backgroundColor: 'rgba(75, 192, 192, 0.2)',
                    borderColor: 'rgba(75, 192, 192, 1)',
                    borderWidth: 1
            const config = {
                type: 'bar',
                data: data,
                options: {
                    scales: {
                        x: {
                            title: {
                                display: true,
                                text: 'Tijd'
                        y: {
                            beginAtZero: true,
                            title: {
                                display: true,
                                text: 'Prijs'
            const ctx = document.getElementById('energyPricesChart').getContext('2d');
            new Chart(ctx, config);
    </script>
</body>
</html>
The above script works when placed in /var/www/html/energy_prices.html
However when placed in ~/domoticz/www/templates it shows the header and nothing else.
How come?
How to resolve it.
Is there something domoticz which stops the script?
Bugs bug me.
gizmocuz
Re: Custom pages problem
Post by gizmocuz »
Did you try the two provided template examples? And are they working?
If they are (I suspect so), try to find the difference between yours and the supplied examples
gizmocuz
Post by gizmocuz »
Open your browsers development console and check for any errors will also help you
lost
Post by lost »
HvdW wrote: Friday 27 December 2024 23:07 The above script works when placed in /var/www/html/energy_prices.html
Take care Domoticz cannot use files out of it's own www root. So if you use files out of ~/domoticz/www/templates (to keep your custom things separate from the web server root: ~/domoticz/www) in your script, you may symlink them there and modify your custom page paths using those files to the simlinked ones.
I do this for my cams last captures jpegs that stays for some time in /tmp (so a tmpfs in ram, to avoid SD card wear) and are made available from a Domoticz custom page, for instance. Using directly /tmp/something.jpg in the page was KO. Using ~/domoticz/www/templates/something.jpg after a "ln -s /tmp/something.jpg ~/domoticz/www/templates" command this was OK.
