lambda probe (o2 sensor)
Posted: Friday 27 December 2024 16:25
i have a gasification wood boiler and i will like to attach an O2 sensor to it to measure the flue gases and to use the raspberry pi to control the primary and secondary air so that the burning of the wood to be the most efficient i can make it.
now the primary and secondary air are set (by feeling or by using a O2 sensor temporarily attached to the flue) and it will be the same no matter the changing conditions of the burning.
is there a known way of reading the O2 sensor with raspberry pi? (by known i meant documented - someone did it, knows and shares the parts used, software needed, scripts or anything else ...). i'm a noob around raspberry and electronics and i will not know where to start and where to poke to do this by myself.
is it worth bothering to continue digging on how to use the O2 sensor with the raspberry or take an arduino and see how to make it integrate with raspberry and domoticz?
does someone did or know about a project of this kind?
