401 basics
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
bartemannekes
401 basics
Post by bartemannekes »
Hi forum,
I am pretty new to domoticz, after quite a few searches on the forum, I remain stuck...
I have an ssh connection to the pi, and i type
"curl http://192.168.0.212:8080/json.htm?type=command&param=udevice&idx=19&nvalue=0&svalue=33;0"
which keeps on giving "401 Unauthorized"
(when going to
from safari from another machine, this works, at least when there is a session to domoticz where i am logged in)
in settings, trusted networks, I have "127.0.0.*, 192.168.0.212" and API protection is set to allow basic auth
I have raspberry pi 5, domoticz 2024.7, ip of the pi is 192.168.0.212
Am I doing something very basic wrong in the curl command?
What can I actually do in terms of debugging to understand why I get 401, as far as I understand, it should be allowed as I have the ip in trusted networks?
Thanks a lot for the help
Bart
Domoticz version: 2025.1
Re: 401 basics
Change the trusted network IP to "127.0.0.*,192.168.0.*"
Also no spaces in this setting, there is now a space afte the comma (could be typing error).
skippy711
Domoticz version: 2024.2
Re: 401 basics
Post by skippy711 »
Just checked and on the settings page it says that the trusted networks should be separated by a semicolon (and not a comma). Perhaps it's worth a try.
