Error: Z4D: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req 00:17:88:01:08:3c:63:e3/0x3402 0x104 0x8
Posted: Sunday 22 December 2024 11:37
by JBN
I get these type of errors from z4d "Error: Z4D: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req 00:17:88:01:08:3c:63:e3/0x3402 0x104 0x8 payload: b'\x10\x08\x00\x00\x00' AckIsDisable: True RETRY: 1/1 (NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT)"
and now the controller is unable to turn on or off switches:
- Spoiler: show
- 2024-12-22 11:34:12.047 Z4D: UpdateDevice - ( Julgran) 2:99
2024-12-22 11:34:12.082 Error: Z4D: _send_and_retry - Unexpected Exception - raw_zcl_zcl_onoff bc:33:ac:ff:fe:7a:70:6d/0xf17d 0x104 0x6 payload: b'\x11\x14\x01' AckIsDisable: False RETRY: 1/1 (NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT)
Edit: A restart fixed the issue (at least for now).
Re: Error: Z4D: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req 00:17:88:01:08:3c:63:e3/0x3402 0x104
Posted: Monday 23 December 2024 16:30
by pipiche
can you check what this device is : 3402 , f17d
the message simply indicates that we try to read an attribute on that device, and it failed - mostlekly because the device is not reachable or not responding
Posted: Monday 23 December 2024 21:51
by JBN
3402 is a Phillips Hue LWG004
f17d is an IKEA TRADFRI control outlet
Posted: Friday 10 January 2025 8:57
by lost
I'm getting similar issue since a few hours, from 3 devices:
0xa2d7 0x3d46 0x1d9c : All 3 being same "TS011F-plug" devices (so all 3 in use!) working correctly since months...
Versions:
Plugin: 7.1.018 [5.353]
Firmware: Ezsp - 6.10.3.0 build 297
Last logs grep'ed since this morning at 8h00:
2025-01-10 08:00:04.117 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10\x1e\x00\x05\x05\
x08\x05\x0b\x05' AckIsDisable: True RETRY: 1/1 (NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT)
2025-01-10 08:00:09.179 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10g\x00\x05\x05\x08
2025-01-10 08:01:09.193 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x101\x00\x05\x05\x08
2025-01-10 08:05:04.211 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10\x1f\x00\x05\x05\
2025-01-10 08:05:09.170 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10h\x00\x05\x05\x08
2025-01-10 08:06:09.183 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x102\x00\x05\x05\x08
2025-01-10 08:10:04.169 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10 \x00\x05\x05\x08
2025-01-10 08:10:09.165 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10i\x00\x05\x05\x08
2025-01-10 08:11:09.195 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x103\x00\x05\x05\x08
2025-01-10 08:15:04.139 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10!\x00\x05\x05\x08
2025-01-10 08:15:09.190 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10j\x00\x05\x05\x08
2025-01-10 08:16:09.085 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x104\x00\x05\x05\x08
2025-01-10 08:20:04.159 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10"\x00\x05\x05\x08
2025-01-10 08:20:09.435 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10k\x00\x05\x05\x08
2025-01-10 08:21:09.170 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x105\x00\x05\x05\x08
2025-01-10 08:24:44.134 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0x0 payload: b'\x10#\x00\x00\x00' AckI
2025-01-10 08:24:49.188 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0x0 payload: b'\x106\x00\x00\x00' AckI
2025-01-10 08:24:54.150 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0x0 payload: b'\x10l\x00\x00\x00' AckI
2025-01-10 08:25:04.128 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10$\x00\x05\x05\x08
2025-01-10 08:25:09.179 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10m\x00\x05\x05\x08
2025-01-10 08:26:09.205 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x107\x00\x05\x05\x08
2025-01-10 08:30:04.113 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10%\x00\x05\x05\x08
2025-01-10 08:30:09.197 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10n\x00\x05\x05\x08
2025-01-10 08:31:09.150 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x108\x00\x05\x05\x08
2025-01-10 08:35:04.187 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10&\x00\x05\x05\x08
2025-01-10 08:35:09.140 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10o\x00\x05\x05\x08
2025-01-10 08:36:09.112 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x109\x00\x05\x05\x08
2025-01-10 08:40:04.181 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b"\x10'\x00\x05\x05\x08
\x05\x0b\x05" AckIsDisable: True RETRY: 1/1 (NcpResetCode.ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT)
2025-01-10 08:40:09.175 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10p\x00\x05\x05\x08
2025-01-10 08:41:09.125 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x10:\x00\x05\x05\x08
2025-01-10 08:45:04.114 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:6a:e7:b3:58:da/0x1d9c 0x104 0xB04 payload: b'\x10(\x00\x05\x05\x08
2025-01-10 08:45:09.164 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:57:6d:40:24:ff/0x3d46 0x104 0xB04 payload: b'\x10q\x00\x05\x05\x08
2025-01-10 08:46:09.148 Error: Zi-Stick: _send_and_retry - Unexpected Exception - rawaps_read_attribute_req a4:c1:38:64:2d:43:90:a1/0xa2d7 0x104 0xB04 payload: b'\x10;\x00\x05\x05\x08
Let me know if more data/logs needed...
EDIT: A few hours after a plugin restart (no devices side action), no more errors & plugs OK as usual: can be controlled again & sends measurements...
Posted: Sunday 19 January 2025 17:27
by pipiche
Check the serial line between the host and the zigbee controller. Strongly recommand to use a good quality USB cable.
you can also do a Power Off/On of the Coordinator
Posted: Sunday 26 January 2025 10:36
by pipiche
lost wrote: Friday 10 January 2025 8:57
Versions:
Do you still have this issue time to time ?
Do you have Domoticz automatic backup enabled ?
Posted: Monday 27 January 2025 8:45
by lost
Sorry, did not noticed your previous answer/question: IMO, cable is not the culprit there & IMO quite good in ext diameter (so, I believe, internal cables) with ferrite.
For 2nd question: No more issue since the single I had reported hereupper & Yes, Domoticz backup is enabled (not sure this can be completely disabled, saw messages about hacks in the forums but I do not use them) on my system.
Still on same 7.1.018 version for now.
Posted: Monday 27 January 2025 9:54
by pipiche
Ok, keep me posted if it comes back, working on a solution. It looks like we have an issue when Domoticz backup is triggered, this get the python threads stuck and the SiliconLabs zigbee chipset doesn't like that.
Posted: Monday 27 January 2025 11:03
by lost
Makes sense, this log was at 08:00:04.117, so when hourly backup was done... If this only happens with this exact coordinator, this may not be plugin issue: If that's a coordinator side timeout that happens when there is, unfortunately, some serial-usb exchanges on-going at hourly boundaries, must be quite rare issue.
FYI, already experienced such issues (other side stuck after some delay during data exchange, especially running Linux RT patched kernels where kernel can be preempted by applicative SW so much more often than vanilla ones) on usb linked hardware & less intrusive WA I found was using linux kernel usb reset ioctl before HW reinit. Original tip is from this LKML post I believe (C code, here):
https://marc.info/?l=linux-usb&m=121459435621262&w=2
Using this from python is quite straightforward, for instance (only 'device path' retrieval is not so common):
https://gist.github.com/PaulFurtado/fce ... 0469f34d51
I'll let you know if I experience this again. If needing some specific logs, let me know, I'll ensure they'll not be erased over time.
Posted: Monday 27 January 2025 14:39
by pipiche
@lost let me know if you get this error again, I have created a special branch so the plugin restart when getting such error, and do not stay in this faulty situation
