Popp TRV 010101 resets itself to 20°C after a few seconds
breversa
Post by breversa »
Version: Domoticz 2024.7
Platform: Raspberry Pi
Plugin/Hardware: Popp (formerly Danfoss) Z-Wave Thermostat Radiator Valves model 010101
Description:
Hello!
This is my first post here, and I’m not even sure if that’s the best place, as my issue looks hardware-related, not Domoticz-related.
I have 3 Popp/Danfoss Z-Wave Thermostat Radiator Valves (TRV) model 010101 (see https://popp.eu/products/wireless-thermostatic-valve/) that I’ve been using for a few years :
- paired with an AEON Labs Z‐Stick Gen5 USB Controller
- plugged into a Raspberry Pi 3 Model B Rev 1.2
- running Raspbian GNU/Linux 11 (bullseye)
- running zwave-js-ui: 9.6.2.6e369a1 + zwave-js: 12.4.1
- running Domoticz 2024.7
Since September 2024, one of these TRV has stopped working properly: whatever setpoint I set, and whatever the means (through Domoticz or physically on the device itself), it resets itself back to 20°C after a few seconds.
I’ve tried :
- changing the batteries
- factory resetting the devices
- re-pairing it with the Z-Stick
Nothing had any effect.
I’m thinking of replacing the device, but not before throwing a message in a bottle here. :-)
Re: Popp TRV 010101 resets itself to 20°C after a few seconds
I moved the topic to the Zwave sub forum.
The only other possibility I could think of is some script that is (re)setting the setpoint.
Is there any difference in setting the setpoint from Domoticz or Zwave-JS-UI? You could check with Mqtt explorer if the temperature is set from Domoticz or from Zwave-JS-UI. And then you have to find out what the real source is of the setpoint resetting is.
breversa
Post by breversa »
Hello and thanks for your suggestions.
As I said, what troubles me the most is that changing the setpoint on the device itself (= by using its physical buttons) yields the same result, so I’d imagine that Zwave-JS-UI/Domoticz are downhill from the issue source.
I’ve contacted Popp about it ; I will let you know if I get a useful reply. :-)
If some script from Domoticz is setting the temperature at 20 degree it will also do that when set manually on the device itself.
But if you are unaware of such a script it probably is an hardware issue.
breversa
Post by breversa »
I’ve contacted Popp support who advised me to exclude the problematic TRV node from its Z-Wave network controller.
After I did, the TRV stopped resetting to 20°C.
I included it back, and everything seems to be fine again. :-)
