Hi!
I recently had to reinstall my domoticz system om my Rpi since the MicroSD-card turned corrupt. Just now I noticed that the month december has changed to january in my dummy-switches. As soon I change it back to december and then return to "timers", the month has changed to january again. I have the 2024.7 version. Anyone with an idea what to do?
December changes to january in my dummies
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: December changes to january in my dummies
Is your OS data and time correct?
- gizmocuz
Is both your OS and your raspberry pi date+time correct?
(For instance, Windows And your raspberry pi date/time)
- Domoticz version: 4.9700
Yes, both show the same time + date.
I just tried to add a timer to one of my other switches in Domoticz, not a dummy. I choosed an annual timer that switches on on december 1. When I check it afterwards it shows january 1 instead of december 1.
I can confirm this is latest beta. When you select an existing yearly timer (eg on 7 June) it shows correctly the month in the timer list but not in the edit form (you have to leave the timer page). There the month is always January, whatever you have set earlier. So if you want the change the date to June 9 you have to change the day AND month.... So it seems a bug somewhere.
Ok, thanks for confirming the bug. Hope they will release a fix soon.waltervl wrote: ↑Sunday 15 December 2024 0:24 I can confirm this is latest beta. When you select an existing yearly timer (eg on 7 June) it shows correctly the month in the timer list but not in the edit form (you have to leave the timer page). There the month is always January, whatever you have set earlier. So if you want the change the date to June 9 you have to change the day AND month.... So it seems a bug somewhere.
