Version : 2024.7
Platform : Raspberry Pi 5 8 Go - Bookworm 64b
Plugin : pp-manager / Shellyteacher4domo /
HS110 : ajay10000_domoticz_hs110_plugin-master
Mosquitto
Hello
I was using a Rasbperry Pi 3B - Bulleyes - Domoticz 2024.7.
Work well
I buy a Raspberry Pi 5 and do a clear install under Rapberry Pi OS - same plugins
I copy the database and scripts as usual.
Configuration is Ok, all devices are seen, scripts work well
So, now, OS crash (freeze) after some hours.
When I test memory (command free), I see that free memory decrease continously.
Temporaly, I use a script (crontab) that test free memory and stop Domoticz before reboot system. Then a crontab restart Domoticz if not running. A very bad solution.....
Is about the same as : https://github.com/raspberrypi/bookworm ... issues/275
A idea ?
Philippe
Memory leak and crash
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- gizmocuz
Re: Memory leak and crash
This is with the normal Raspbian image (without the desktop) ?
Could you try with the docker compose Domoticz?
- Domoticz version: 2024.7
This is with with Raspian image and Desktop (like my old config on Raspberry Pi 3 and Bulleyes)
So I can try with a image without desptop....
But I just test to stop Mosquitto : memory return to 550 Mo and is stable. When Mosquitto restart, memory free decrease again ....
To install Mosquitto, I had use :
sudo apt install mosquitto
Is the right way ?
Is the right way ?
Finally I found the error related to a bad installation of Mosquitto. According to the source: www.tutos.eu/4910
I had simply done:
etc...
I redid the installation considering:
mosquitto.org/blog/2013/01/mosquitto-debian-repository/ and repo.mosquitto.org/debian/README.txt
and therefore the following commands:
- sudo wget -q https://repo.mosquitto.org/debian/mosquitto-repo.gpg -O /etc/apt/keyrings/mosquitto-repo.gpg
- sudo wget -O /etc/apt/sources.list.d/mosquitto-bookworm.list https://repo.mosquitto.org/debian/mosqu ... kworm.list
and finally
- sudo apt-get update && apt-get install mosquitto
So, now, all work well.
As a beginner, I use this procedure which seems simpler than setting up Docker and which I do not understand well how to use.
The original troubles were related to a installation of Samba and a faulty reinstallation of Mosquitto
I had simply done:
etc...
and finally
