Use switch second pi
Posted: Sunday 08 December 2024 7:43
by Bospieper
I have two pi's active in the same network. Is it possible to use, through a script for example, a switch on the other pi?
Grz.Piet
Re: Use switch second pi
Posted: Sunday 08 December 2024 8:17
by BazemanKM
YES
if WP.active and Pomp.state == 'Off' and SensorDT.temperature > 0 then
domoticz.openURL('http://IP_OTHER:8080/json.htm?type=command¶m=switchlight&idx=49&switchcmd=On')
Posted: Sunday 08 December 2024 9:01
by Bospieper
Thanx I will try
Posted: Sunday 08 December 2024 9:37
by Bospieper
It works!
Next question: is it possible to use the command .afterMin() to build in a delay?
Grz Piet
Posted: Sunday 08 December 2024 9:41
by Tukker
Domoticz remote is a great way of sharing.
You can choose which devices are shown in the other domoticz instance.
https://wiki.domoticz.com/Setting_up_Device_sharing
Posted: Monday 09 December 2024 18:52
by BazemanKM
Bospieper wrote: Sunday 08 December 2024 9:37
It works!
Grz Piet
Try and you will know. Let us know.
Posted: Monday 09 December 2024 18:54
by BazemanKM
Also possible, but that was not the original question.
If the delay doesn't work, then slave/remote is an option with the delay.
Posted: Tuesday 10 December 2024 0:04
by waltervl
BazemanKM wrote: Monday 09 December 2024 18:54
I also think that device sharing between 2 Domoticz servers is exactly what the topic starter should use to switch a device on another Domoticz server.
