Proxmox
solarboy
Domoticz version: 2024.6
Proxmox
Post by solarboy »
I am moving from rpi3b to an Intel NUC 6i3SYK i3 6100U as the pi is starting to stress out with all the services I am running. I have read extensively about proxmox and I like the idea of running domoticz and all my home automation services in a VM for the complete setup backup and snapshot capability. Up till now I have only found the "sdcard copier" in raspbian to provide a reliable backup.
I currently have everything running in dockers except domoticz which I intend to move to docker. Am I on the right path for improved reliability or are the layers of virtualisation excessive ?
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
HvdW
Domoticz version: 2023.2
Re: Proxmox
Post by HvdW »
I'm using rpi-clone?
Here is a script to let it run smoothly.
#!/bin/bash
# rpi-clone.sh
# https://github.com/billw2/rpi-clone
# command to find attached drives
# sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
# df -h
# command sh -x rpi-clone.sh
sudo service cron stop
sudo service domoticz stop
sudo service lighttpd stop
#sudo service pihole-FTL stop
#sudo service unifi stop
sudo service unattended-upgrades stop
sudo service unbound stop
#sudo service fail2ban stop
sudo systemctl stop SBFspotUpload
# first setup
# -f is force initialise -U is unattended
#sudo ~/rpi-clone/rpi-clone -f -v -U mmcblk0 for cloning from sd to rpi
sudo ~/rpi-clone/rpi-clone -v -f sda
# all following
#sudo rpi-clone -v -u sdx
# to install as a cronjob: crontab -e
# # m h  dom mon dow   command
#6 6 * * 6 sudo rpi-clone -u sdx
sudo service cron start
sudo service domoticz start
sudo service lighttpd start
#sudo service unifi start
#sudo service pihole-FTL start
sudo service unattended-upgrades start
sudo service unbound start
#sudo service fail2ban start
sudo systemctl start SBFspotUpload
Bugs bug me.
Domoticz version: 2024.7
Re: Proxmox
Did you do a search on proxmox on this forum?
If you like Docker I would install Ubuntu server on your new Nuc and continue using docker, also for Domoticz.
For backup copy a daily backup of your userdata of all your Docker containers to a safe location.
Egregius
Domoticz version: v2024.7
Re: Proxmox
Post by Egregius »
I'm running Domoticz without Docker on Debian in a Proxmox CT. Runs perfectly. No hassle at all to restore a backup if needed.
Because CT uses a LXC container there's practically no overhead at all.
gizmocuz
Re: Proxmox
Post by gizmocuz »
Just use Domoticz (and your other services) with Docker Compose.
Create separate folders for each of your projects, and use folders inside these folders as volumes
./my_folder:/opt/docker-project/folder
Use a rsync job to backup the dockers folders, I install all my dockers in /opt, so I only need to backup the /opt folder and done.
These nucs are fast, I am also an old (5 year?) intel i5 nuc, and these days the price of a m.2 drive is very interesting as well
solarboy
Re: Proxmox
Post by solarboy »
HvdW wrote: Friday 29 November 2024 0:32 I'm using rpi-clone?
#!/bin/bash
# rpi-clone.sh
# df -h
# first setup
# all following
That's a great script. I did try to use rpi-clone a few years back but ran into issues with the system rebooting into the cloned drive instead of the main drive so I went with a monthly sd-card-copier back up, booting into that, and another sd-card-copier backup to another SSD, that way always keeping an SSD ready to go. The 2 SSD's were identical and I think that was why I ran into problems doing direct clones. Thanks for your suggestion.
solarboy
Re: Proxmox
Post by solarboy »
Egregius wrote: Friday 29 November 2024 6:57 I'm running Domoticz without Docker on Debian in a Proxmox CT. Runs perfectly. No hassle at all to restore a backup if needed.
Am I right in thinking that you are running the docker containers in Proxmox without using a VM ? I hadn't considered this. Thanks for the suggestion.
solarboy
Re: Proxmox
Post by solarboy »
gizmocuz wrote: Friday 29 November 2024 9:03 Just use Domoticz (and your other services) with Docker Compose.
Thanks for this suggestion, another option to consider. I currently run everything in dockers (docker-compose) except domoticz as I needed time to study how to make ports available and if I needed a custom start up script to install python modules etc inside the container but I will now be moving Domoticz into a container at least. I do like the idea of a virtual machine though, simply for the ease of just rolling back everything in one swift and easy command as often when I update zigbee/zwave/domoticz and something goes wrong I find myself with hours of work to fix the issue and sometimes I don't have the time to spare. This is where a full system backup is useful, but my method was very hands on and took about half a day to complete.
Obviously a VM will add some overhead but it seems the NUC is powerful enough without using too much extra energy.
Egregius
Re: Proxmox
Post by Egregius »
solarboy wrote: Friday 29 November 2024 18:48
I don't use Docker, don't see the advantage of that and don't understand it.
solarboy
Re: Proxmox
Post by solarboy »
I was under the impression that LXC containers are quite similar to Docker containers, at least in their use of the underlying kernel. Docker originally used LXC apparantly.
