Help with Z-Wave Device Inclusion Failing Intermittently
Posted: Thursday 28 November 2024 10:43
Hi everyone,
I’m new to Domoticz and have been trying to set up a Z-Wave network at home. I’ve got the system running on a Raspberry Pi 4 using the Aeotec Z-Stick Gen5+ as the Z-Wave controller. Everything seemed fine during the initial setup, but I’m having trouble adding new devices to the network.
Sometimes, the inclusion process works perfectly, and the device appears in Domoticz as expected. However, more often than not, the inclusion process either times out or the device shows up without any meaningful data (e.g., no manufacturer info, no node ID). It’s inconsistent and quite frustrating.
I’ve tried the following so far:
Restarting the Domoticz service and Z-Stick.
Ensuring the devices are within range (most are within 2-3 meters during inclusion).
Testing with both secure and non-secure inclusion options.
Updating Domoticz to the latest stable version.
Despite all this, I can’t seem to figure out the root cause. Has anyone experienced something similar or have suggestions for troubleshooting? Could it be interference, or am I missing a key step in the configuration?
Thanks in advance for your help!
jira
jira
