Hue API V2
Maxx
Hue API V2
Post by Maxx »
Hello All,
Currently I am using direct API call to hue using the v1 API version. I am trying to upgrade to API V2 and I am partly successfull. I use the following test program:
		timer = {
			'every minute'
		httpResponses = {
			'trigger'
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
 		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://192.168.1.8/clip/v2/resource/device',
				headers = { ['hue-application-key'] = 'LqUg-Ho81HxhcjOqX4YnRbrQELiSXHjkh3' },
				method = 'GET',
				callback = 'trigger', .
				domoticz.log('HTTPS call has been done')
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local json = item.data
					domoticz.log(json)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Sometimes I get usable data back but most of the time I get a SSL error:
2024-11-25 15:22:01.917 Error: dzVents: template: HTTP/1.1 response: 35 ==>> SSL connect error
I know that V2 uses https calls only and according the Hue development site you should use the given certificate, this is probably what is going wrong at the moment.
Now the question: Does anybody know how to use a certificate in the openURL call? Is that even possible or is there another way? There are CURL examples where the certificate is sent with the CURL call.
