Domoticz stable version 2022.2 - who has the file?
pmmisiek
- Domoticz version: 2022.2
Hi All,
Does anyone have a compiled version of 2022.2 for Raspberry PI?
I pressed "update" by accident and lost whole day to make to get my Danfoss Zwave thermostats working again - unfortunately no results, I have to go back to working version domoticz.
BR
BR
lost
Re: Domoticz stable version 2022.1 - who has the file?
What is the updated version? Zwave integration was legacy OZW? If so, this was removed for some time but restored so latest stable should be OK (I'm ~80% zwave, still on OZW as this ran smoothly for years & I have devices others reported not working with ZwaveJS, like my buggy Qubino Smart-Meter...).
Weird to have issues with devices used for heating in winter.
- Domoticz version: 2026.3
Current stable with Openzwave does not support the new thermostat/setpoint device.
You can also update to Zwave-JS-UI as that is the most future proof.
pmmisiek
I tried to use Zwave-JS-UI but it doesn't work. Zstick was detected but thermostats not, even don't started integration in domoticz.
The last Domoticz wokred fine over few years without touching it so I would like to go back to version 2022.1
pmmisiek
Re: Domoticz stable version 2022.2 - who has the file?
I've just changed title - I have database ver.156 so I need a version 2022.2
You could perhaps setup a (temporary) docker system and load the 2022.2 image. You could use the docker version or copy the domoticz folder from it and paste it into your old domoticz environment.
https://hub.docker.com/r/domoticz/domot ... ame=2022.2
Edit: Probably not usable as the image seems to be overwritten by 2023.1: https://hub.docker.com/layers/domoticz/ ... xt=explore
lost
Hello,pmmisiek wrote: Monday 25 November 2024 22:03 I've just changed title - I have database ver.156 so I need a version 2022.2
looked on my PC drive and... I still have both aarch64 and armv7l install archives (those before 2022.2 were already erased).
Here are the sha1sum for check vs filebin storage:
$ sha1sum *.tgz
e9e32134b94471778dfda46adb08f163afb3a741 domoticz_linux_aarch64.tgz
224f42e6a663e933fbd00002f2b3402e89f9979a domoticz_linux_armv7l_2022_2_32b.tgzhttps://filebin.net/5fi60y38y1gjn25o
Edit: I see I also have 2023.2 that was latest stable with OZW... and also latest 2023.2 beta before OZW removal (build 15462).
Let me know if they may make sense for you, to have maybe most up-to-date binaries still compatible with your system.
pmmisiek
Many Many Many Thanks!
You save my home automation system whose most important task now is to manage heating (Danfoss Zwave thermostats - and AEON Stick ZW090)
System is working 8 years without any problems
I tried to compile 2022.2 but with below error but thanks to you it doesn't matter.
Now domoticz is working again. I will never again put my cursor near the update button.
pi@domoticz:~/dev-2022-domoticz2 $ make
[ 1%] Built target minizip
[ 2%] Built target jsoncpp_static
[ 16%] Built target libmosquitto_static
[ 16%] Building CXX object CMakeFiles/domoticztester.dir/main/domoticz_tester.cpp.o
In file included from /home/pi/dev-2022-domoticz2/main/domoticz_tester.cpp:8:
/home/pi/dev-2022-domoticz2/main/appversion.h:2:10: fatal error: ../appversion.h: No such file or directory
#include "../appversion.h"
compilation terminated.
make[2]: *** [CMakeFiles/domoticztester.dir/build.make:124: CMakeFiles/domoticztester.dir/main/domoticz_tester.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:427: CMakeFiles/domoticztester.dir/all] Error 2
make: *** [Makefile:152: all] Error 2
