Problemen nieuwe installatie
Posted: Friday 22 November 2024 21:48
by testerke
Draai al jaren domoticz voor men P1 uit te lezen en had nog een oude versie met wat lopende werkende fouten...
Dus dacht ik tijd voor Pi4 eens opnieuw te installeren ...
Maar vandaag tegen zoveel problemen aangelopen,
alle 32bit versie geprobeerd via raspberry imager....
Draaien zo traag, duurt een ewig eer die nu opstarten.
Dan werkte de link niet om Domoticz te installeren, vond de oplossing via forum om eerst libssl1.1 te installeren...
Dan terug Domoticz link geprobeerd en liep het weer vast...
Hoe krijg ik mijn raspberry met Domoticz terug werkend en snel zoals mijn oude versie ??
Bedankt alvast
Re: Problemen nieuwe installatie
Posted: Friday 22 November 2024 23:06
by waltervl
Please use English language here on this forum. There is also a Dutch forum if you are not able to.
Posted: Friday 22 November 2024 23:07
by jvdz
This is an English forum, so please post your questions in English. :-)
As to your question: It is way to generic, but there is already a lot of information available on the forum and Wiki pages on how to install domoticz.
Posted: Saturday 23 November 2024 0:10
by Tukker
My experience.
Just burn a new SD card with raspberry 64 bits Bookworm
Then copy your old domoticz directory to the new SD card under a different name like domoticz.old
Then do the simple install procedure, the curl one.
The install script will find your old domoticz install and after finishing everything is back in place.
Posted: Monday 25 November 2024 11:18
by testerke
After everything is installed it freezes...
Posted: Monday 25 November 2024 12:31
by Tukker
Try again, start from scratch and maybe use a new sd card.
Posted: Saturday 14 December 2024 17:16
by gritman
I've been running Domoticz for some time on an RP0W2.RPi3b and RPi4.
When I tried to install on a new RPI0W2, I get stuck at the first screen.
When I enter Return, nothing happens.
I tried reformtting the SD card, same result.
A new SD card gives the same result.
I then tried a RPI3A, withe the same effect.
I tried various versions of Raspbian, both Bullseye and Bookworm, both 32 and 64 bit, but the result stays the same.
I'm puzzled.
