Error: state is nil for item.level: nil
Posted: Wednesday 20 November 2024 18:38
by Tukker
I am not able to find an example on Google to retrieve the cause of this error message.
2024-11-20 18:35:00.651 Error: dzVents: Car charging on PV Power: Error: state is nil for item.level: nil
The script runs smooth but I want to get rid of this error message.
Checked and logged everything state and level, all OK
Re: Error: state is nil for item.level: nil
Posted: Wednesday 20 November 2024 19:11
I never have seen this error but it could be a misformed table of item.
Is item an domoticz object or a json from external?
Posted: Wednesday 20 November 2024 22:09
by Tukker
The only item word in the script is triggeredItem that's why I am wondering.
I have put a lot of debug statements inside, all flawless.
As mentioned, a Google search didn't give me a clue where to search either.
Posted: Thursday 21 November 2024 6:03
by Kedi
Beter post the complete script.
Posted: Thursday 21 November 2024 10:17
by Tukker
Well...
timer = {'every 1 minutes', }, -- at daytime
logging = {
level = domoticz.LOG_DEBUG,
marker = 'Car charging on PV Power'
data = {
desiredLevel = { initial = 'Off' },
lastChangeTime = { initial = 0 },
execute = function(domoticz, triggeredItem)
if triggeredItem then
domoticz.log('#11111 triggeeredItem ', domoticz.LOG_DEBUG)
-- domoticz.devices('Charging Level').dump()
local ChargingSwitchState = domoticz.devices('Charging Level').levelName
local EVSwitch_16A = domoticz.devices('EVSE Switch 16A')
local chargeLevelSet = domoticz.devices('XC40 battery charge set').level
local chargeLevelActual = domoticz.devices('XC40-ChargeLevel').nValue -- is een int en niet iets met een komma XC40-ChargeLevel
local EVSE_Connected = domoticz.globalData.EVSE_Connected
local newLevel = 'Off'
-- Define power levels
local powerLevels = {
Off = 0,
['6A'] = 1400,
['8A'] = 1850,
['10A'] = 2300,
['13A'] = 3000,
['16A'] = 3700
-- Get power level based on charging switch state
local PowerLaadpaal = powerLevels[ChargingSwitchState] or 0
-- Get power data
local PowerReturn = tonumber(domoticz.devices('Power').rawData[6]) -- Solar power generation
local PowerConsumption = tonumber(domoticz.devices('Power').rawData[5]) -- Home power consumption
local availableEnergy = PowerLaadpaal + PowerReturn - PowerConsumption
-- Logging
--domoticz.log('#0 EVSE connected: ' .. domoticz.globalData.EVSE_Connected, domoticz.LOG_DEBUG)
domoticz.log('#1 Energy usage from the network: ' .. PowerConsumption, domoticz.LOG_DEBUG)
domoticz.log('#2 Energy return to the network: ' .. PowerReturn, domoticz.LOG_DEBUG)
domoticz.log('#3 Actual power on laadpaal: ' .. PowerLaadpaal, domoticz.LOG_DEBUG)
domoticz.log('#4 Available energy: ' .. availableEnergy, domoticz.LOG_DEBUG)
-- Check if SmartEVSE is OK
if domoticz.globalData.EVSE_CommunicationError ~= 'None' then
domoticz.notify('@1 There is an EVSE Communication Error', domoticz.PRIORITY_NORMAL)
domoticz.devices('Auto laden').switchOff().forSec(30)
-- Determine the desired charging level
local currentLevel = domoticz.devices('Charging Level').state
domoticz.log('###### currentLevel : ' .. currentLevel, domoticz.LOG_DEBUG)
for level, power in pairs(powerLevels) do
if availableEnergy >= power then
newLevel = level
domoticz.log('###### newLevel : ' .. newLevel, domoticz.LOG_DEBUG)
-- Check if chargeLevelActual >= chargeLevelSet
if chargeLevelActual >= chargeLevelSet and EVSE_Connected == 'Connected' then
domoticz.devices('Charging Level').switchSelector('Off')
domoticz.log('#5 Set to: ' .. newLevel, domoticz.LOG_DEBUG)
-- Check if chargeLevelActual < chargeLevelSet
elseif chargeLevelActual < chargeLevelSet and EVSE_Connected == 'Connected' and EVSwitch_16A.state == 'Off' then
local currentTime = os.time()
if availableEnergy < 900 then -- 1400 - 500 = 900
newLevel = 'Off'
domoticz.devices('Charging Level').switchSelector(newLevel)
-- Notify charging state
-- It sends the notification one time when the level has changed
local current_time = os.date('%d-%m-%Y %H:%M')
local subject, message
if newLevel == 'Off' and (currentLevel ~= newLevel) then
subject = '@2 Charging on PV power has ended.'
message = 'Charging Off, Energy : ' .. availableEnergy .. '\nTime : ' .. current_time
if domoticz.LOG_DEBUG then
domoticz.notify(subject, message, domoticz.PRIORITY_NORMAL)
domoticz.log('#6 Notification sent: ' .. subject, domoticz.LOG_DEBUG)
elseif newLevel ~= 'Off'and (currentLevel ~= newLevel) then
subject = '@3 We are charging on PV power.'
message = 'Charging ' .. newLevel .. ', Energy : ' .. availableEnergy .. '\nTime : ' .. current_time
domoticz.log('#7 Notification sent: ' .. subject, domoticz.LOG_DEBUG)
domoticz.log('#7 Car charging on PV Power END of test loop', domoticz.LOG_DEBUG)
Posted: Thursday 21 November 2024 11:59
by jvdz
Guess it has to be this line?:
Check the devicename and type whether it really has field level.
To make sure that is the one, you could change the line to:
local chargeLevelSet = domoticz.devices('XC40 battery charge set').level or '??'
Posted: Thursday 21 November 2024 13:04
by Tukker
gives the same result
Here's the full log
2024-11-21 13:03:00.161 dzVents: Car charging on PV Power: ------ Start internal script: Car charging on PV Power:, trigger: "every 1 minutes"
2024-11-21 13:03:00.162 dzVents: Debug: Car charging on PV Power: #11111 triggeeredItem
2024-11-21 13:03:00.164 dzVents: Debug: Car charging on PV Power: Processing device-adapter for Charging Level: Switch device adapter
2024-11-21 13:03:00.164 dzVents: Debug: Car charging on PV Power: Processing device-adapter for EVSE Switch 16A: Switch device adapter
2024-11-21 13:03:00.164 dzVents: Debug: Car charging on PV Power: #1 Energy usage from the network: 0
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: #2 Energy return to the network: 760
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: #3 Actual power on laadpaal: 0
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: #4 Available energy: 760
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: ###### currentLevel : Off
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: ###### newLevel : Off
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: Constructed timed-command: Set Level 0
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: #5 Set to: Off
2024-11-21 13:03:00.165 dzVents: Debug: Car charging on PV Power: #7 Car charging on PV Power END of test loop
2024-11-21 13:03:00.167 dzVents: Car charging on PV Power: ------ Finished Car charging on PV Power
2024-11-21 13:03:00.175 Error: dzVents: Car charging on PV Power: Error: state is nil for item.level: nil
2024-11-21 13:03:00.245 Status: EventSystem: Script event triggered: /home/hein/domoticz/dzVents/runtime/dzVents.lua
2024-11-21 13:03:00.284 Status: EventSystem: reset all device statuses...
2024-11-21 13:03:00.372 Dummy: Light/Switch (Charging Level)
2024-11-21 13:03:00.446 dzVents: Handling events for: "Charging Level", value: "Off"
2024-11-21 13:03:00.452 Error: dzVents: Car charging on PV Power: Error: state is nil for item.level: nil
The nil message is at 13:03:00.175 and at 13:03:00.452 in the same run.
