I have a relatively simple problem, but I don't know if it's a bug or something I don't understand.
I've created an “alert'” widget .
Via mqtt, I can receive “INCONNU” or “BLEU” or "BLANC” or “ROUGE” messages.
I'd just like to receive a notification on my e-mail when the status changes from "INCONNU" to "BLANC" or from "INCONNU" to "ROUGE".
I've activated the 'Alert' widget's notification function, but it doesn't work.
so I tried to write a simple “blocky” script and it didn't work.
I created a variable dedicated to this function in order to have a log.
Bug Widget Alert and notification
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Bug Widget Alert and notification
For an Alert sensor the value to trigger on is the Alert level, not the text. See also for example
https://wiki.domoticz.com/Dummy_for_vir ... ert_sensor
Level =
0=gray icon,
1=green icon,
2=yellow icon,
3=orange icon,
4=red icon
So in the notification you use value (Valeur) 0, 1, 2, 3 or 4
or something like for example bigger than 1 to send a notification when level is 2, 3 or 4
Level =
0=gray icon,
1=green icon,
2=yellow icon,
3=orange icon,
4=red icon
- seby901
Is it the same for “blocky” scripts? Can't you make a comparison on the text?
- Capture3.JPG (86.06 KiB) Viewed 1136 times
Perhaps possible with dzvents but the main value for an Alert device is the alert level (0-5) and not the text. So to use an alert device you have to set Alert Level AND text and use the level to trigger actions.
