Domoticz 2024.7 Build 16325
Debian latest updated and upgraded
RPi5 8 Gig
Since build 16325, I have a problem with the Currently One smartmeter over MQTT. 3 autodiscovered devices (L1, L2, and L3) showing power on each phase is correct. There is one more autodiscovered device (Type: Usage, electric, "Currently Using") which correctly shows the sum of L1, L2 and L3. Then there is another autodiscovered device (Type: General, kWh, "Currently Used") which, before updating to 16325 from 16219, showed also sum of L1, L2 and L3 and calculated energy today based on the total consumption. After update to 16325, this device, "Currently Used" now only shows power from L1 and the today consumtion is calculated only from L1 power instead of the sum of L1, L2 and L3. Worked like a charm since more than a year but from 16325 shows the wrong values both power and energy.
Tested on another Rpi with Domoticz 2024.7 stable and works correct!
Anybody else seeing this behaviour?
/fjuppe
Build 16325 Smartmeter problem/Bug
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 16341
Re: Build 16325 Smartmeter problem/Bug
Bumping...
Anybody??
Anybody??
Hi fjuppe, have you tried rolling back to Build 16219 on your RPi5 to see if the issue persists, or does it only happen on Build 16325?
- Domoticz version: 2024.7
Check if the device ID in MQTT is still the same. Perhaps due to an update of the application controlling the device (Zwave-JS-UI? Zigbee2MQTT?) it changed ID and then Domoticz will get confused.
Delete all related and retained config topics from your MQTT server/broker and restart domoticz and the- controlling application to force rediscovering the devices by Domoticz.
