Page 1 of 2
Usage data last month and last year not displaying anything
Posted: Wednesday 06 November 2024 11:47
by jacobh
I'm using Domoticz beta 2024.7 (build 16325). My Log-view panels for power do display the usage data "usage last three days" and "usage last week", as well as for the "comparing usage", but I'm getting a "no data to display" on the panels "usage last month" and "usage last year".
What is wrong here and how to fix?
Same panels under my gas utility show proper data in the matching panels
Re: Usage data last month and last year not displaying anything
Posted: Wednesday 06 November 2024 19:33
Do a ctrl-F5 to force a refresh of the browser javascripts or use a browser session in incognito/private mode.
Posted: Wednesday 06 November 2024 21:30
by jacobh
Thanks, tried the CTRL+F5 and incognito browser. No effect, still same two panes showing "no data available".
Also tried other browsers, same picture. I reckon the data would be stored in the domoticz.db. In what table are they stored? Can I check there for more detail?
Posted: Wednesday 06 November 2024 21:46
That data is probably in meter_calendar or multimeter_calendar table.
That data is there as the compare graph shows data of last month.
Do you see proper data in the report page (report button top right)?
Posted: Thursday 07 November 2024 6:49
by jacobh
Ok, just checked if there was any data in the report page. Exported the csv's of the missing panels. They only show a header line, no actual data there.
Did the same thing for Gas, they do show data.
Now went to the database and looked at the tables you mentioned. My Power utility has DeviceId 21, for Gas this is 25.
In the Meter_Calendar I find 2838 entries for id 25 (oldest 2020-09-01, most recent 2024-11-05). I don't find any entries for Id 21.
In the Multimeter_Calendar I find 0 entries for id 25, 1404 entries for id 21 (oldest 2020-09-01, most recent 2024-11-05).
Posted: Thursday 07 November 2024 7:44
So the data is in the database. It is OK to have it in 2 different tables.
Then we have 1 last test to do, get the month data through the API for bothe IDX device 21 and 25 (change IDX, IP and port in link below)
http://YourIP:port/json.htm?type=command&param=graph&sensor=counter&idx=IDX&range=month
It should give a list of values with data per day of last month.
Posted: Thursday 07 November 2024 7:50
Additional: as I see a last week graph in your 2024.7 screenshot it indicates to me it is a browser cache issue as that graph is deleted in 2024.7!!!
Do not switch in the same browser session from your old to new environment!! There should only be a last month graph with a 1 wk filter:
Posted: Thursday 07 November 2024 8:07
by jacobh
"CostEnergy" : 2149,
"CostEnergyR1" : 800,
"CostEnergyR2" : 800,
"CostEnergyT2" : 2149,
"CostGas" : 6218,
"CostWater" : 16473,
"Divider" : 1000.0,
"DividerEnergy" : 1000.0,
"DividerWater" : 100.0,
"P1_Tariff" : "High",
"ValueQuantity" : "",
"ValueUnits" : "",
"counter" : "5247.769",
"result" :
"c" : "5179.35",
"d" : "2024-10-07",
"p" : "0.0000",
"v" : "1.57"
"c" : "5180.92",
"d" : "2024-10-08",
"p" : "0.0000",
"v" : "0.48"
"c" : "5181.40",
"d" : "2024-10-09",
"p" : "0.0000",
"v" : "0.60"
"c" : "5182.00",
"d" : "2024-10-10",
"p" : "0.0000",
"v" : "1.34"
"c" : "5183.34",
"d" : "2024-10-11",
"p" : "0.0000",
"v" : "2.18"
"c" : "5185.52",
"d" : "2024-10-12",
"p" : "0.0000",
"v" : "4.42"
"c" : "5189.93",
"d" : "2024-10-13",
"p" : "0.0000",
"v" : "1.73"
"c" : "5191.66",
"d" : "2024-10-14",
"p" : "0.0000",
"v" : "2.93"
"c" : "5194.59",
"d" : "2024-10-15",
"p" : "0.0000",
"v" : "3.04"
"c" : "5197.64",
"d" : "2024-10-16",
"p" : "0.0000",
"v" : "3.15"
"c" : "5200.78",
"d" : "2024-10-17",
"p" : "0.0000",
"v" : "1.69"
"c" : "5202.48",
"d" : "2024-10-18",
"p" : "0.0000",
"v" : "0.76"
"c" : "5203.24",
"d" : "2024-10-19",
"p" : "0.0000",
"v" : "0.98"
"c" : "5204.22",
"d" : "2024-10-20",
"p" : "0.0000",
"v" : "1.39"
"c" : "5205.60",
"d" : "2024-10-21",
"p" : "0.0000",
"v" : "1.74"
"c" : "5207.35",
"d" : "2024-10-22",
"p" : "0.0000",
"v" : "1.07"
"c" : "5208.42",
"d" : "2024-10-23",
"p" : "0.0000",
"v" : "1.67"
"c" : "5210.08",
"d" : "2024-10-24",
"p" : "0.0000",
"v" : "1.66"
"c" : "5211.75",
"d" : "2024-10-25",
"p" : "0.0000",
"v" : "2.08"
"c" : "5213.83",
"d" : "2024-10-26",
"p" : "0.0000",
"v" : "1.31"
"c" : "5215.14",
"d" : "2024-10-27",
"p" : "0.0000",
"v" : "0.60"
"c" : "5215.74",
"d" : "2024-10-28",
"p" : "0.0000",
"v" : "3.16"
"c" : "5218.90",
"d" : "2024-10-29",
"p" : "0.0000",
"v" : "1.45"
"c" : "5220.35",
"d" : "2024-10-30",
"p" : "0.0000",
"v" : "2.00"
"c" : "5222.35",
"d" : "2024-10-31",
"p" : "0.0000",
"v" : "1.42"
"c" : "5223.77",
"d" : "2024-11-01",
"p" : "0.0000",
"v" : "2.42"
"c" : "5226.19",
"d" : "2024-11-02",
"p" : "0.0000",
"v" : "2.72"
"c" : "5228.92",
"d" : "2024-11-03",
"p" : "0.0000",
"v" : "4.03"
"c" : "5232.95",
"d" : "2024-11-04",
"p" : "0.0000",
"v" : "4.71"
"c" : "5237.66",
"d" : "2024-11-05",
"p" : "0.0000",
"v" : "3.44"
"c" : "5241.10",
"d" : "2024-11-06",
"p" : "0.0000",
"v" : "4.81"
"c" : "5245.90",
"d" : "2024-11-07",
"p" : "0.0000",
"v" : "1.87"
"resultprev" :
"d" : "2023-10-07",
"p" : "0.0000",
"v" : "0.21"
"d" : "2023-10-08",
"p" : "0.0000",
"v" : "0.64"
"d" : "2023-10-09",
"p" : "0.0000",
"v" : "1.61"
"d" : "2023-10-10",
"p" : "0.0000",
"v" : "1.26"
"d" : "2023-10-11",
"p" : "0.0000",
"v" : "0.14"
"d" : "2023-10-12",
"p" : "0.0000",
"v" : "1.18"
"d" : "2023-10-13",
"p" : "0.0000",
"v" : "2.37"
"d" : "2023-10-14",
"p" : "0.0000",
"v" : "1.74"
"d" : "2023-10-15",
"p" : "0.0000",
"v" : "3.02"
"d" : "2023-10-16",
"p" : "0.0000",
"v" : "2.76"
"d" : "2023-10-17",
"p" : "0.0000",
"v" : "2.41"
"d" : "2023-10-18",
"p" : "0.0000",
"v" : "4.89"
"d" : "2023-10-19",
"p" : "0.0000",
"v" : "4.62"
"d" : "2023-10-20",
"p" : "0.0000",
"v" : "4.57"
"d" : "2023-10-21",
"p" : "0.0000",
"v" : "3.71"
"d" : "2023-10-22",
"p" : "0.0000",
"v" : "1.66"
"d" : "2023-10-23",
"p" : "0.0000",
"v" : "4.02"
"d" : "2023-10-24",
"p" : "0.0000",
"v" : "3.53"
"d" : "2023-10-25",
"p" : "0.0000",
"v" : "4.28"
"d" : "2023-10-26",
"p" : "0.0000",
"v" : "3.02"
"d" : "2023-10-27",
"p" : "0.0000",
"v" : "4.00"
"d" : "2023-10-28",
"p" : "0.0000",
"v" : "2.78"
"d" : "2023-10-29",
"p" : "0.0000",
"v" : "2.23"
"d" : "2023-10-30",
"p" : "0.0000",
"v" : "3.23"
"d" : "2023-10-31",
"p" : "0.0000",
"v" : "3.25"
"d" : "2023-11-01",
"p" : "0.0000",
"v" : "2.73"
"d" : "2023-11-02",
"p" : "0.0000",
"v" : "3.85"
"d" : "2023-11-03",
"p" : "0.0000",
"v" : "3.17"
"d" : "2023-11-04",
"p" : "0.0000",
"v" : "3.63"
"d" : "2023-11-05",
"p" : "0.0000",
"v" : "5.04"
"d" : "2023-11-06",
"p" : "0.0000",
"v" : "3.93"
"d" : "2023-11-07",
"p" : "0.0000",
"v" : "2.69"
"status" : "OK",
"title" : "Graph counter month"
"CostGas" : 6218,
"CounterR1" : "0.000",
"CounterR2" : "0.000",
"CounterT1" : "6869.547",
"CounterT2" : "8513.295",
"Divider" : 1000.0,
"P1DisplayType" : 0,
"ValueUnits" : "",
"result" :
"c1" : "6755.156",
"c2" : "0",
"c3" : "8366.837",
"c4" : "0",
"d" : "2024-10-07",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.913",
"v2" : "5.856"
"c1" : "6757.069",
"c2" : "0",
"c3" : "8372.693",
"c4" : "0",
"d" : "2024-10-08",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.589",
"v2" : "6.033"
"c1" : "6758.658",
"c2" : "0",
"c3" : "8378.726",
"c4" : "0",
"d" : "2024-10-09",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.850",
"v2" : "7.862"
"c1" : "6760.508",
"c2" : "0",
"c3" : "8386.588",
"c4" : "0",
"d" : "2024-10-10",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.756",
"v2" : "4.237"
"c1" : "6762.264",
"c2" : "0",
"c3" : "8390.825",
"c4" : "0",
"d" : "2024-10-11",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.188",
"v2" : "6.550"
"c1" : "6764.452",
"c2" : "0",
"c3" : "8397.375",
"c4" : "0",
"d" : "2024-10-12",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.622",
"v2" : "0.000"
"c1" : "6771.074",
"c2" : "0",
"c3" : "8397.375",
"c4" : "0",
"d" : "2024-10-13",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "7.839",
"v2" : "0.000"
"c1" : "6778.913",
"c2" : "0",
"c3" : "8397.375",
"c4" : "0",
"d" : "2024-10-14",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.113",
"v2" : "6.283"
"c1" : "6781.026",
"c2" : "0",
"c3" : "8403.658",
"c4" : "0",
"d" : "2024-10-15",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.387",
"v2" : "9.144"
"c1" : "6783.413",
"c2" : "0",
"c3" : "8412.802",
"c4" : "0",
"d" : "2024-10-16",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.114",
"v2" : "7.700"
"c1" : "6785.527",
"c2" : "0",
"c3" : "8420.502",
"c4" : "0",
"d" : "2024-10-17",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.988",
"v2" : "6.539"
"c1" : "6787.515",
"c2" : "0",
"c3" : "8427.041",
"c4" : "0",
"d" : "2024-10-18",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.829",
"v2" : "5.497"
"c1" : "6790.344",
"c2" : "0",
"c3" : "8432.538",
"c4" : "0",
"d" : "2024-10-19",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "7.502",
"v2" : "0.000"
"c1" : "6797.846",
"c2" : "0",
"c3" : "8432.538",
"c4" : "0",
"d" : "2024-10-20",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.701",
"v2" : "0.000"
"c1" : "6804.547",
"c2" : "0",
"c3" : "8432.538",
"c4" : "0",
"d" : "2024-10-21",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.833",
"v2" : "6.419"
"c1" : "6806.380",
"c2" : "0",
"c3" : "8438.957",
"c4" : "0",
"d" : "2024-10-22",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.091",
"v2" : "4.988"
"c1" : "6808.471",
"c2" : "0",
"c3" : "8443.945",
"c4" : "0",
"d" : "2024-10-23",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.099",
"v2" : "6.098"
"c1" : "6810.570",
"c2" : "0",
"c3" : "8450.043",
"c4" : "0",
"d" : "2024-10-24",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.878",
"v2" : "6.887"
"c1" : "6812.448",
"c2" : "0",
"c3" : "8456.930",
"c4" : "0",
"d" : "2024-10-25",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.598",
"v2" : "6.237"
"c1" : "6815.046",
"c2" : "0",
"c3" : "8463.167",
"c4" : "0",
"d" : "2024-10-26",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "9.913",
"v2" : "0.000"
"c1" : "6824.959",
"c2" : "0",
"c3" : "8463.167",
"c4" : "0",
"d" : "2024-10-27",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "9.228",
"v2" : "0.000"
"c1" : "6834.187",
"c2" : "0",
"c3" : "8463.167",
"c4" : "0",
"d" : "2024-10-28",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.158",
"v2" : "5.556"
"c1" : "6836.345",
"c2" : "0",
"c3" : "8468.723",
"c4" : "0",
"d" : "2024-10-29",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.186",
"v2" : "6.633"
"c1" : "6838.531",
"c2" : "0",
"c3" : "8475.356",
"c4" : "0",
"d" : "2024-10-30",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.087",
"v2" : "6.668"
"c1" : "6840.618",
"c2" : "0",
"c3" : "8482.024",
"c4" : "0",
"d" : "2024-10-31",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "4.081",
"v2" : "7.060"
"c1" : "6844.699",
"c2" : "0",
"c3" : "8489.084",
"c4" : "0",
"d" : "2024-11-01",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.611",
"v2" : "6.408"
"c1" : "6846.310",
"c2" : "0",
"c3" : "8495.492",
"c4" : "0",
"d" : "2024-11-02",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.959",
"v2" : "0.000"
"c1" : "6853.269",
"c2" : "0",
"c3" : "8495.492",
"c4" : "0",
"d" : "2024-11-03",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "8.950",
"v2" : "0.000"
"c1" : "6862.219",
"c2" : "0",
"c3" : "8495.492",
"c4" : "0",
"d" : "2024-11-04",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.988",
"v2" : "7.157"
"c1" : "6864.207",
"c2" : "0",
"c3" : "8502.649",
"c4" : "0",
"d" : "2024-11-05",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.782",
"v2" : "4.012"
"c1" : "6865.989",
"c2" : "0",
"c3" : "8506.661",
"c4" : "0",
"d" : "2024-11-06",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.770",
"v2" : "6.042"
"c1" : "6867.759",
"c2" : "0",
"c3" : "8512.703",
"c4" : "0",
"d" : "2024-11-07",
"p" : "0.0000",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.788",
"v2" : "0.577"
"resultprev" :
"d" : "2023-10-07",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "4.876",
"v2" : "0.000"
"d" : "2023-10-08",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.577",
"v2" : "0.000"
"d" : "2023-10-09",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.525",
"v2" : "4.323"
"d" : "2023-10-10",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.567",
"v2" : "4.258"
"d" : "2023-10-11",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.238",
"v2" : "4.152"
"d" : "2023-10-12",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.054",
"v2" : "4.905"
"d" : "2023-10-13",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.960",
"v2" : "5.450"
"d" : "2023-10-14",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "7.426",
"v2" : "0.000"
"d" : "2023-10-15",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.231",
"v2" : "0.000"
"d" : "2023-10-16",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.399",
"v2" : "5.603"
"d" : "2023-10-17",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.200",
"v2" : "4.241"
"d" : "2023-10-18",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.408",
"v2" : "4.916"
"d" : "2023-10-19",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.584",
"v2" : "5.410"
"d" : "2023-10-20",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.255",
"v2" : "6.926"
"d" : "2023-10-21",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "7.270",
"v2" : "0.000"
"d" : "2023-10-22",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.807",
"v2" : "0.000"
"d" : "2023-10-23",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.524",
"v2" : "5.021"
"d" : "2023-10-24",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.038",
"v2" : "5.096"
"d" : "2023-10-25",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.362",
"v2" : "4.467"
"d" : "2023-10-26",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.301",
"v2" : "5.104"
"d" : "2023-10-27",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.202",
"v2" : "5.828"
"d" : "2023-10-28",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "4.917",
"v2" : "0.000"
"d" : "2023-10-29",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.681",
"v2" : "0.000"
"d" : "2023-10-30",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.473",
"v2" : "3.923"
"d" : "2023-10-31",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.622",
"v2" : "4.197"
"d" : "2023-11-01",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.254",
"v2" : "4.164"
"d" : "2023-11-02",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "2.686",
"v2" : "4.882"
"d" : "2023-11-03",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.512",
"v2" : "7.575"
"d" : "2023-11-04",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "7.520",
"v2" : "0.000"
"d" : "2023-11-05",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "6.854",
"v2" : "0.000"
"d" : "2023-11-06",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.388",
"v2" : "5.315"
"d" : "2023-11-07",
"r1" : "0.000",
"r2" : "0.000",
"v1" : "1.367",
"v2" : "4.991"
"status" : "OK",
Posted: Thursday 07 November 2024 9:03
waltervl wrote: Thursday 07 November 2024 7:50 Additional: as I see a last week graph in your 2024.7 screenshot it indicates to me it is a browser cache issue as that graph is deleted in 2024.7!!!
Perhaps you missed this?
Posted: Thursday 07 November 2024 10:27
by jacobh
Thanks for the reminder. Didn't miss it. Checked my browser settings (reckoning this is what you meant) and deleted complete cache.
Also tried changing Domoticz to stable version. No difference visible. :(
Posted: Thursday 07 November 2024 10:44
Delete more browser cache (google how to do it with your browser)
Posted: Friday 08 November 2024 7:47
by jacobh
I deleted ALL browser cache, cookies, etc now. Still two empty panes showing no data available in the Power log screen.
Posted: Friday 08 November 2024 10:08
Perhaps something wrong with your update (eg not all files copied) because you should not see a week graph anymore.
run in a command line terminal:
cd domoticz
sudo ./updatebeta
Posted: Monday 11 November 2024 6:44
by jacobh
I'm actually running Domoticz from a docker container, not sure how to implement these commands?
And wouldn't I initiate an upgrade to latest beta-version iso stable?
Posted: Monday 11 November 2024 9:34
For docker according: https://hub.docker.com/r/domoticz/domoticz and you use docker compose, it will be something like
docker compose pull && docker compose up --force-recreate --build -d && docker image prune -f
The version is set in your docker compose configuration:
image: domoticz/domoticz:beta(will pull latest beta version)
image: domoticz/domoticz:stable(will pull latest stable version)
image: domoticz/domoticz:2024.2(will pull latest stable version 2024.2)
image: domoticz/domoticz:2024-beta.12345(will pull beta with build number 12345)
Edit: also check the following file in your Domoticz environment: <yourDomoticzInstallFolder>/www/app/log/CounterLog.html
There should be no week chart entry in that file.
Normally thinking it can only be a browser cache issue....
Posted: Tuesday 12 November 2024 7:13
by jacobh
I've stated the following in my docker compose yml:
image: domoticz/domoticz:2024.7
I ran the command and the restarted instance still shows the empty panels.
Also went inside the container to check the CounterLog.html file. It apparently DOES contain the month- and year-charts.
root@3fbd056f7fff:/opt/domoticz/www/app/log# cat CouterLog.html
cat: CouterLog.html: No such file or directory
root@3fbd056f7fff:/opt/domoticz/www/app/log# cat CounterLog.html
<counter-day-chart
class="device-log-chart"
device="::$ctrl.device"></counter-day-chart>
<counter-week-chart
device="::$ctrl.device"></counter-week-chart>
<counter-month-chart
device="::$ctrl.device"></counter-month-chart>
<counter-year-chart
device="::$ctrl.device"></counter-year-chart>
<counter-compare-chart
ng-if="::$ctrl.subtype=='energy-used' || $ctrl.subtype=='gas' || $ctrl.subtype=='water' || $ctrl.subtype=='counter' || $ctrl.subtype=='energy-generated' || $ctrl.subtype=='time' || $ctrl.subtype=='p1Energy' || $ctrl.subtype=='instantAndCounter'"
device="::$ctrl.device"></counter-compare-chart>
Posted: Tuesday 12 November 2024 7:23
by jacobh
Just by means of excluding I also tested by installing Safari browser on my primary laptop and by opening the page on a laptop that never used Domoticz before. Both panes are still there.
So the /opt/domoticz/www folder in docker is mounted on my local filesystem, so be removing the counter-month-chart and counter-year-chart tags, they are gone now. Still wondering however what causes this issue.
Let me say thanks for your patience with me and your ideas to get things solved and explaining things.
Posted: Tuesday 12 November 2024 8:26
I am no docker expert but t seems by mounting extra folders you hampered the update process. Can you post your complete docker compose file?
Posted: Tuesday 12 November 2024 8:55
by jacobh
networks:
default:
driver: bridge
ipam:
driver: default
monitoring:
services:
domoticz:
container_name: domoticz
restart: unless-stopped
devices:
- /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO3RW0UN-if00-port0:/dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO3RW0UN-if00-port0
ports:
- "9080:8080"
volumes:
- /home/pi/docker/volumes/domoticz/config:/opt/domoticz/userdata
- /home/pi/docker/volumes/domoticz/config/www:/opt/domoticz/www
- /home/pi/docker/volumes/domoticz/config/backups:/opt/domoticz/backups
- /home/pi/docker/volumes/domoticz/www/templates:/domoticz/www/templates
- /home/pi/docker/volumes/domoticz/config/plugins:/opt/domoticz/plugins
environment:
- TZ=Europe/Amsterdam
- LOG_PATH=/opt/domoticz/userdata/domoticz.log
- EXTRA_CMD_ARG= -loglevel normal,status,error,auth
Posted: Tuesday 12 November 2024 10:54
Again, I am not a docker expert but mounting opt/domoticz/www does not seem correct.
Normally only /opt/domoticz/userdata needs to be mounted.
