Need Lua help here, no programer
Posted: Sunday 27 October 2024 13:47
by Droll
Got some ideas, but I don't know if it work, or if there is a better way..
Not new to Domoticz, but scrips are not my language :? .
Running linux, on a Pc, Ubuntu, SSD harddrive.
About Domoticz
Version: 2024.7 (build 16297)
Build Hash: 85e28226f
Compile Date: 2024-10-26 09:19:44
dzVents Version: 3.1.8
Python Version: 3.8.10 (default, Sep 11 2024, 16:02:53) [GCC 9.4.0]
This is a cut/paste schript, doesn't work.
-- script_device_text.lua
local virtualcounter_idx = "1887"
local MaxUse = 3000 -- adjuseble, might be a UserVariable ?--local MaxUse = toInteger(uservariables['MaxUse'])
AMS strøm forbruk = tonumber(uservariables['AMS strøm forbruk'])-- string ?, 3460.0;73711400 0/3460.0;73711400---3460
Effekt bruk varmtvann = tonumber(otherdevices_svalues['Effekt bruk varmtvann'])--string ?, 12.8;0.0;0.0 0---log "2024-10-22 14:45:00";0"2024-10-22 14:50:00";3057
Varmt Vann Bereder = tonumber(otherdevices_svalues['Varmt Vann Bereder'])--string ? , 77.1 0/77.1---77,1
Volt 1 = tonumber(otherdevices_svalues['AMS Spenning L1'])--string ?,237.30 0/237.30
Volt 2 = tonumber(otherdevices_svalues['AMS Spenning L2'])--string ?,237.60 0/237.60
Volt 3 = tonumber(otherdevices_svalues['AMS Spenning L3'])--string ?,236.70 0/236.70
Volt = (AMS Spenning L1 + AMS Spenning L2 + AMS Spenning L3) / 3 -- volt = 235 ?
Varmt Vann Bereder W = volt * Effekt bruk varmtvann -- Think it's Ampere, need watt.
MaxUseDevice = AMS strøm forbruk - Varmt Vann Bereder W -- exs 2100 = 5100 - 3000 or 3100 = 6100 - 3000, here 460 = 3460 -3000
If "MaxUseDevice" < "MaxUse" then commandArray['Power bereder']='Off'else commandArray['MyOtherDevice']='on'-- If MaxUsaDevice is higer than MaxUse then Do...
if Varmt Vann Bereder <= 50 then commandArray['MyOtherDevice']='on'-- ignore 'MaxUse', if 'Varmt Vann Bereder' is lower temp 50 than, leave on..
--Write to TextDevice, Dummy.
-- line 1, MaxUse
-- line 2.
-- line 3, status off "myOtherDevice" ON/OFF
-- line 4, AMS strøm forbruk
-- Update virtual counter device
ts = virtualcounter_idx .. "|0|" .. string.format("%.3f", tostring(countvalue)) -- copy/paste
commandArray['UpdateDevice'] = ts --copy/paste
It's a cut/paste script, not supposed to work, but you should get the picture on what I want to achieve :-)
Some parts do work, but not as I want.
The math parts is OK, I guess, not pretty..
But how to get the values from the different sensors, format them to numbers ?
And the there is the layout of the script itself, make it the RIGHT way..
Droll
Re: Need Lua help here, no programer
Posted: Sunday 27 October 2024 15:38
by HvdW
When you're on Edge use CoPilot AI (the sign in the upper right corner)
Ask your question in your own language, give some clues - the input you have - ask for the output you want and see what happens.
I suggest you ask CoPilot to write the script in dzVents, which is easier to handle and understand.
Posted: Sunday 27 October 2024 17:33
by Droll
First.. I have never used a MS browser, ecept to install another..
But it gave me a working code, sort of
Need to figure out what the output there is on "local AMS_strom_forbruk", it's a textdevice updated from MQTT from a HAN plug on my meter..
https://www.amsleser.no/
--Absolutely! Here's your script with the syntax fixed and the necessary conversions from strings to numbers:
--To view the log in Domoticz from the code you pasted, you can add logging statements to your Lua script. This will help you track the values and flow of your script. Here's an updated version of your script with added logging:
--```lua
local MaxUse = 3000 -- adjustable, might be a UserVariable
-- local MaxUse = tonumber(uservariables['MaxUse'])
-- Convert string inputs to numbers
local AMS_strom_forbruk = 222 --tonumber(string.match(uservariables['AMS strøm forbruk'], "%d+%.?%d*")) -- extract and convert to number
local Effekt_bruk_varmtvann = tonumber(string.match(otherdevices_svalues['Effekt bruk varmtvann'], "%d+%.?%d*")) -- extract and convert to number
local Varmt_Vann_Bereder = tonumber(string.match(otherdevices_svalues['Varmt Vann Bereder'], "%d+%.?%d*")) -- extract and convert to number
local Volt1 = tonumber(string.match(otherdevices_svalues['AMS Spenning L1'], "%d+%.?%d*")) -- extract and convert to number
local Volt2 = tonumber(string.match(otherdevices_svalues['AMS Spenning L2'], "%d+%.?%d*")) -- extract and convert to number
local Volt3 = tonumber(string.match(otherdevices_svalues['AMS Spenning L3'], "%d+%.?%d*")) -- extract and convert to number
local Volt = (Volt1 + Volt2 + Volt3) / 3 -- average voltage
local Varmt_Vann_Bereder_W = Volt * Effekt_bruk_varmtvann -- calculate wattage
local MaxUseDevice = AMS_strom_forbruk - Varmt_Vann_Bereder_W -- example: 2100 = 5100 - 3000
-- Log values for debugging
print("AMS strøm forbruk: " .. AMS_strom_forbruk)
print("Effekt bruk varmtvann: " .. Effekt_bruk_varmtvann)
print("Varmt Vann Bereder: " .. Varmt_Vann_Bereder)
print("Volt1: " .. Volt1)
print("Volt2: " .. Volt2)
print("Volt3: " .. Volt3)
print("Average Volt: " .. Volt)
print("Varmt Vann Bereder W: " .. Varmt_Vann_Bereder_W)
print("MaxUseDevice: " .. MaxUseDevice)
if MaxUseDevice < MaxUse then
    commandArray['Power bereder'] = 'Off'
    print("Power bereder set to Off")
    commandArray['MyOtherDevice'] = 'On' -- if MaxUseDevice is higher than MaxUse then do...
    print("MyOtherDevice set to On")
if Varmt_Vann_Bereder <= 50 then
    commandArray['MyOtherDevice'] = 'On' -- ignore MaxUse if Varmt Vann Bereder is lower than 50
    print("MyOtherDevice set to On due to Varmt Vann Bereder <= 50")
-- Write to TextDevice, Dummy.
-- line 1, MaxUse
-- line 2.
-- line 3, status of "MyOtherDevice" ON/OFF
local ts = virtualcounter_idx .. "|0|" .. string.format("%.3f", MaxUseDevice)
print("UpdateDevice: " .. ts)
--With these `print` statements, you can view the log output in the Domoticz log to see the values of your variables and the flow of your script. This should help you debug and understand how your script is working. Let me know if you need any further assistance!
--This script should now be syntactically correct and include the necessary conversions from strings to numbers. Let me know if you need any further adjustments or explanations!
From the log in Domoticz..
2024-10-27 16:53:00.117 Status: LUA: Volt1: 235.6
2024-10-27 16:53:00.117 Status: LUA: Volt2: 234.5
2024-10-27 16:53:00.117 Status: LUA: Volt3: 233.6
2024-10-27 16:53:00.117 Status: LUA: Average Volt: 234.56666666667
2024-10-27 16:53:00.118 Status: LUA: Varmt Vann Bereder W: 0.0
2024-10-27 16:53:00.118 Status: LUA: MaxUseDevice: 222.0 My manuell input as this part didn't read the sensr right! AMS_strom_forbruk
2024-10-27 16:53:00.118 Status: LUA: Power bereder set to Off
2024-10-27 16:53:00.118 Status: LUA: UpdateDevice: 1887|0|222.000
2024-10-27 16:53:00.121 Status: EventSystem: Script event triggered: /home/domoticz/scripts/lua/script_time_text.lua
Some parts are working, maybe not in the correct script way or thinking..
Need to figgure out the missing parts
Arne Kjetil
Posted: Sunday 27 October 2024 19:31
by Droll
There is something in the line below.
local AMS_strom_forbruk = (string.match(uservariables['AMS strøm forbruk'], "%d+%.?%d*")) -- extract and convert to number
1691 2024-10-27 18:43:37 AMS strom forbruk 3796.0;73721888 0/3796.0;73721888
I want the 3796,0 part, in number.
But it's somewhat a progress 8-)
Arne Kjetil
Posted: Monday 28 October 2024 23:48
by Droll
Got something I think will work, probably not the prettyest, but it does do the simple task I want it to do...
Still some bug in the programming....
local virtualMeterValue = otherdevices_svalues['AMS strom forbruk']
local extractedValue = tonumber(string.match(virtualMeterValue or "", "%d+%.?%d*"))
Works
local extractedValue = tonumber(string.match('AMS strom forbruk' or "", "%d+%.?%d*"))
In my mind, it shoud work, but doesnt..
And the distane between line on the TextDevice..
It's like:
Text 1
Text 2
Text 3
I want:
Text 1
Text 2
Text 3
https://domoticz.com/forum/download/fil ... w&id=33247
But this is one off my few codes, acceally made by CoPilot AI....With some inout from me
--local virtualcounter_idx = "1887"
--local MaxUse = 3000 -- adjustable, might be a UserVariable
local MaxUseDevice = extractedValue - Varmt_Vann_Bereder_W -- example: 2100 = 5100 - 3000
print("extractedValue: " .. extractedValue)
    commandArray['Rele varmt vann virt'] = 'Off'
    Status = Off
    commandArray['Rele varmt vann virt'] = 'On'
    print("Power bereder set to On")
    print("Rele varmt vann set to On due to Varmt Vann <= 50")
local Tekst1 = "<font color='Aqua'>Strom Inntak: </font><font color='Yellow'>" .. extractedValue .. "</font>\n"
local Tekst2 = "<font color='Aqua'>Effekt bruk varmtvann: </font><font color='Yellow'>" .. Varmt_Vann_Bereder_W .. "</font>\n"
local Tekst3 = "<font color='Aqua'>Status rele: </font><font color='Yellow'>" .. otherdevices['Rele varmt vann virt'] .. "</font>"
-- Combine the text values into one string
local displayText = Tekst1 .. "\n" .. Tekst2 .. "\n" .. Tekst3
-- Update the text device with the combined text
ttidx = otherdevices_idx['TextTest']
print('TextTest idx '..ttidx)
commandArray['UpdateDevice'] = ttidx..'|0|'..displayText --newtext
Arne Kjetil
Posted: Tuesday 29 October 2024 0:53
by HvdW
Beautiful!
Posted: Tuesday 29 October 2024 17:55
by Droll
Started with some ideas, roughly put together, mostly wrong code...
Got some experience with Basic (Bascom), Lua (Domoticz) and basic Excel.
But nothing advance...n
Will let it run for some time, find some bugs :lol:, and eventually put together some hardware
local MaxUse, NedreVannTemp = tonumber(uservariables['MaxUse']), tonumber(uservariables['NedreVannTemp'])
local extractedValue = tonumber(string.match(otherdevices_svalues['AMS strom forbruk'] or "", "%d+%.?%d*"))
local Volt = (Volt1 + Volt2 + Volt3) / 3 -- average voltage, skkert n�ye nok med 235V ??
local MaxUseDevice = extractedValue - 3000 -- example: 2100 = 5100 - 3000
if MaxUseDevice <= MaxUse then
commandArray['Rele varmt vann virt'] = 'on'
Status = ON
--if Varmt_Vann_Bereder <= Nedre VannTemp then
local Tekst1 = "<font color='Aqua'>Strøm Inntak: </font><font color='Yellow'>" .. string.format("%.2f", extractedValue) .. "</font> W<br>"
local Tekst2 = "<font color='Aqua'>Effekt bruk varmtvann: </font><font color='Yellow'>" .. string.format("%.2f", Varmt_Vann_Bereder_W) .. "</font> W<br>"
local Tekst3 = "<font color='Aqua'>Status rele: </font><font color='Yellow'>" .. otherdevices['Rele varmt vann virt'] .. "</font><font color='Aqua'> " .. string.format("%.2f", MaxUseDevice) .. "</font> W"
--local displayText = Tekst1 .. "\n" .. Tekst2 .. "\n" .. Tekst3
local displayText = "<div style='margin-bottom:-4px;'>" .. Tekst1 .. "</div>" ..
"<div style='margin-bottom:-3px;'>" .. Tekst2 .. "</div>" ..
"<div style='margin-bottom:-4px;'>" .. Tekst3 .. "</div>"
Arne Kjetil
https://domoticz.com/forum/download/fil ... w&id=33249
Posted: Thursday 26 December 2024 10:46
by Droll
Sometime have gone by, A HD has crashed, new install of Domoticz/Z-wave.
Still working on this script, it's working, but I want more ;)
At the moment in LUA..
  • Is it possible to dynamically change icon bases on a value ?
    Is it possible to remove or adjust "Last seen xx.xx.xxx. "
    Is it possible the remove or adjust the "Type, General, Text"
The answer is maybe hidden somewhere in the wiki/forum ..
The idea behind this script is to save electricity, as some part is based on the usages peak in a month, so it's wise to turn off the water heater when we are cocking food or using electricity...
AK
Posted: Saturday 15 February 2025 16:41
by Droll
I am doing some small simple scripts in Lua, mainly to learn something, asked before but never got any answers.
What exactly can be done with a text device ?
where can I find more deeper info about the different devices in Domoticz ?
Maybe how to program some other devises too??
I learned that a text device:
  • Can display 4 or more lines.
    Can use http formatting on the text, colours, sizes, different text, bold++
    Can change icons, It would be nice if I could do this in pure Lua? not that into dzVents, more help to find in Lua..
    (got It working whit some 8080/json.htm?type=setused&used=true&name=*** code, thanks to and old post from warrenviewtopic.php?p=266340&hilit=change+icon+script#p266340 Thanks :)
And some help from https://domoticz-icon.aurelien-loyer.fr/, I say some help because the zip file doesn’t work right out of the ”box”, have to add the small file manually? but maybe I do something wrong?, it's a great help as long I know how to make it work.
Arne Kjetil
Posted: Saturday 15 February 2025 19:32
by HvdW
https://wiki.domoticz.com/DzVents:_next ... _scripting
And example
    active = true,
        timer = { 'every 1 minutes' }
        local currentDate = os.date('%Y-%m-%d %H:%M:%S')
        local line1 = "Text 1"
        local line2 = "Text 2"
        local line3 = "Text 3"
        local line4 = "Text 4"
        local line5 = "Text 5"
        local line6 = "Text 6"
        local message = string.format(
            "Current Date and Time: %s\n" ..
            "Text for the first line %s\n" ..
            "Text for the second line %s\n" ..
            "Text for the third line %s\n" ..
            "Text for the fourth line %s\n" ..
            "Text for the fifth line %s\n" ..
            "Text for the sixth line %s",
            currentDate,
            line1,
            line2,
            line3,
            line4,
            line5,
            line6
        local textSensor = domoticz.devices('TextSensorName')
        if textSensor then
            textSensor.updateText(message)
            domoticz.log('Text sensor updated with the new message.', domoticz.LOG_INFO)
            domoticz.log('Text sensor not found!', domoticz.LOG_ERROR)
